Old 02-04-2005, 05:58 AM   #531 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 2Bret Brinkmann Level 2Bret Brinkmann Level 2
Default Re: Getrag 440/446 parts.
Be sure to find out exactly what comes in that kit. Some poeple will say kits come with all the bearings but usually that means "all the tappered bearings at the end of the shafts and not the needle bearings for the gears". Assuming you would need any bearings to begin with of course.
Once you know what is included in the kit compair the cost of the kit to the prices given by all our current suppliers. I have found that some times it is cheaper to buy the parts individually through a different supplier than to a get a kit from a newer parts source. You should find out if they are OEM brand.
250 RWHP
Old 02-04-2005, 04:40 PM   #532 (permalink)
b@$tard guy!
aerOvr-4gto3k's Avatar
Drives: on one wheel
aerOvr-4gto3k is an unknown quantity at this point
what prices from our suppliers would i expect for all the the syncronizer sets and bearings? from what ive gathered ive seen people spending 600 bucks on just 2 sets of synchros, unless i read wrong...possibly
chris
_______
-1992 mitsubishi 3000gt vr4 - sandstone grey
just want to throw out a thanks to eveyrone that helped make up a part of the autocross event, you all did great!
1992 mitsu. 3000gt vr4 santsone on sandstone/grey - aka "the dirty wh0re"
1999 chevy silverado z71 ext. cab - red - "chevy"
2006 yamaha roadstar midnight warrior - "black betty"
1985 nissan 300zx GLL - "b1tchin' betty" needs some attention.. any takers?
-wouldnt you know, every one of them should eventually have a turbo
aerOvr-4gto3k is offline   Reply With Quote
Old 02-04-2005, 04:41 PM   #533 (permalink)
b@$tard guy!
chris
Old 02-04-2005, 06:35 PM   #534 (permalink)
3/S Guru
Drives: 90 Buick Century
Trader Rating: (8)
A/V dude is an unknown quantity at this point
The tranny i just finished came in at around $650 and that was for all syncros and all taper roller bearings.
Everything came from crs except a few bearings
A/V dude is offline   Reply With Quote
Old 02-04-2005, 06:46 PM   #535 (permalink)
b@$tard guy!
hey does anyone know if the synchros we can get from whomever have a patent on them? beating around the bush... possibly a bite here if there isnt a patent
Chris
Old 02-06-2005, 10:23 AM   #536 (permalink)
Now with 100% more NSX
leet's Avatar
Drives: 95 NSX-T
Trader Rating: (24)
leet Level 1leet Level 1
I'll post this question here since it went un answered in the other thread would Kormex sell a 6-Speed tranny with the JDM gears already installed?
I need a tranny rebuild sometime this summer and really want to get the JDM 6-speed
the stealth is officially for sale, PM for info
leet is online now   Reply With Quote
Old 02-06-2005, 03:21 PM   #537 (permalink)
The New Super Pimp
maddog's Avatar
Drives: FASTER THAN VIPERS
Trader Rating: (7)
maddog Level 1maddog Level 1
call him and find out. easiest way to see if he will. so far i know he's only sold the gears by themselves.
93 Sandstone VR4
11.66 @ 117.48mph with Maddog Performance Engineering 13T's
This weeks specials:
CUSTOM RUBBER INTERCOOLER PIPING AT 50% OFF!!!
28 HOUR ENGINE REBUILD ONLY $700
maddog is offline   Reply With Quote
Old 02-09-2005, 10:02 AM   #538 (permalink)
Gear Head
aerOvr-4gto3k - That $600 you were told was probably from a supplier that was not listed on the first post of this thread. There are other suppliers out there but they all get them from one of two sources. A used tranny or Getrag. It's just a matter of how many middle men you want to pay. For example, CRS gets their stock straight from Getrag. Thus their wholesale pricing on most parts most of the time. Getrag will hold all the patents on all of the parts for these transaxles.
l33t - It seems I remember Frank answering this question for another memeber a while ago. If I remember correctly he can, BUT you have to call him and let him know exactly what you want so there is no mix up on accident which will result in drivetrain damage. You don't want to pay for the right gears and get the wrong gears on accident so DEFFINATELY call Kormex and talk to them.
Old 02-09-2005, 11:38 AM   #539 (permalink)
MilkyClr69's Avatar
Trader Rating: (11)
MilkyClr69 is an unknown quantity at this point
I had been searching for a full synchronizer set and I stumbled upon the following list. By the way this is for a 5 speed...
Would this list be considered a "complete synchorizer and gasket/sealent list"?
Also, for the "1st/2nd set of three rings", i'm guessing this is just the set of the first 3 items above it? (outer, inner, and blocking rings). Also, it says "Times 2" do we need 2 sets of these???
List:
C46 1st/2nd Outer ring 31.13
C47 1st/2nd Blocking ring 15.03
C48 1st/2nd Inner ring 23.93
C45 1st/2nd Set of three rings 70.09 Times 2????
C11 3rd/4th Synchro ring 22.95
C63 5th Synchro ring 65.40
C74 Reverse synchro ring 68.00
296.53
There are no actual case gaskets. Case joints are filled with sealant, Mitsubishi P/N MD997740.
B06 Output shaft seal 10.25
B07 Driveshaft seal, driver's side 4.60
B31 Driveshaft seal, passenger side 4.40
B32 Oil fill plug 1.18
B33 Oil fill plug gasket 0.05
B52 Oil drain plug 3.08
B53 Oil drain plug gasket 0.05
B59 Rear plug(Input shaft plug) 1.18
24.79
That the complete list?
Thanks
96 SL
MagnaFlow Catback, K&N Intake, 18 x 8 ADR Sterling, 245 40 18 Ecsta Supra, Limo/15% window tint, Cross-drilled and slotted rotors, 12" sealed IDMAX w/ 1000 Watt Hifonics amp. Infinity & JBL speakers powered by Hinfonics amp, Alpine 7893.
TT engine/tranny swap
Fixing a few problems and she'll be back on the road!
MilkyClr69 is offline   Reply With Quote
Old 02-10-2005, 02:34 AM   #540 (permalink)
Time traveler
DocEBrown's Avatar
Drives: The 1st of the Last
DocEBrown is an unknown quantity at this point
1st and second are the same part, so effectively you need two sets (one for first and one for second) If you can find them for $70 for the set I will buy like 10 of them. I got mine from a buddy who vacationed in Japan and he paid $170 for each one.
BTW this thread is getting way to long to read. Brett, can you update the first post a little? I haven't looked at it in a while but the last few recent posts have been review on topics covered like a gazillion pages back.
Also, has there been any activity on the rebuild guide? I haven't had time to search and look, but someone witha link to it (if started) would be nice on the front page of this thread.
Thanks to all for input on this topic!
DocEBrown is offline   Reply With Quote
