#521 (permalink) |
3/S Guru
I just picked up a tube, on the back it says "use when mitsu specifies MD997740", so i guess it's the preferred...........
Would have been nice to use the high temp red that i have half a caulk tube full of, but i don't want to take any chances (high temp red works great on oil pans)
#522 (permalink) | |
POLYCHRONOPOULOS
I use that gray on everything that IMO needs sealant, never any troubles. Throw all the other garbage away.
Rob Quote:
#524 (permalink) | |
Drive it hard
#525 (permalink) |
The Chaosbringer
Buy the new pneumatic tubes they have at Pep Boys. They cost about $8 and you can work the trigger with one fingertip. I've sealed up 3 transmissions and one rear differential and I still have plenty left in the tube.
Definitely one of the bests inventions I've seen lately. |
#526 (permalink) | |
Gear Head
I bought my GM synchromesh through the local GMC dealer for about $12 and some change a bottle plus tax. One bottle was not one quart either.... I have noticed that this dealership seems to charge more for their stuff. That would explain the big bucks pricing. I can get MTL for about $8 a qt including tax at local store. I know on line stores have better prices but not after I include shipping. As for bearings, me and another memeber have been working on TCs lately and found all of our bearings at www.applied.com. Find a dealer near you. They were much cheaper than the local parts stores and are an autherized distributor for Timkin and Torrington bearings. I was working on a bearing number list for the five and six speeds as well as the TCs. But I need more time to complete the task.... Much much more time.... And a pay check or three...
![]() 250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#527 (permalink) |
Slowed by traffic
i thought synchroshift was gl-4 and synchromesh (Penzoil or GM) is a completely different product. I wish I still had a bottle of synchroshift around to see, but switched to synchromesh over the summer. I'm lucky, there's a repair shop in town that sells GM synchromesh cheaper than the local gmc or chevy dealer, but unlucky as nobody in town sells the penzoil version.
1991 Red JDM Mitsubishi GTO SR - Daily Driver Dec 2001 - May 2002. SOLD
RHD, AWD/AWS, Aero, Automatic, Naturally Aspirated _________________________ 1993 Panama Green Pearl Mitsubishi 3000GT VR4 - Daily Driver July 2002 - April 2006 & May 2007. Totalled by drunk driver who hit it while parked on a 25mph street May 20 2007 10:30pm. STOP/GO: Southbend DXD 6-puck Clutch, K&N Filtercharger Injection Performance Kit (FIPK), ProBoost Manual Boost Controller (MBC), M-Spec Vacuum Reduction Kit, Stillen Downpipe. Powerslot Front Rotors w/Hawk HPS Pads. SUSPENSION/DRIVETRAIN: Intrax Springs, Bilstien Rear Shocks, KYB GR2 Front Struts, 5Zigen FN01RC 18x8.5 +30 & 18x9.5 +35 Wheels with Nitto Extreme Performance 245/40/18 & 285/35/18 Tires (summer), 245/45/17 Bridgestone Blizzak WS50 on Spyder Chromies (winter), PST Carbon Fiber Drive Shaft (CFDS), Unorthodox Racing Aluminum Flywheel. LOOKS: 5% Tint, Snakeeyes, Niteshades, Mobo Leathers Lower Door Inserts, 3KGT Concepts Aluminum Defroster Vents, Speedhut EL-Glo Gauge Faces AUDIO/VISUAL: JBL GTO220s, Pioneer TS-A1646 2-ways & Stock 6x9s all powered by Phoenix Gold Octane-R 5.1 Dolby Digital Amp, Infinity 1032W 10" Fiberglass Mounted Subs powered by Rockford Fosgate 501bd Amplifer, 7" Motorized LCD DVD/TV/FM/MP3 Deck, SWIX Steering Wheel Control Interface COUNTERMEASURES: Blinder M10 Twin Laser Jammer, Scorpion Ultimate KA Radar Jammer, Radio Shack PRO-2067 Mobile Scanner Radio SECURITY/CONVENIENCE: Compustar 2-Way Spread Spectrum Alarm/Autostart/Turbo Timer/Keyless Entry. _________________________ 1992 Black Dodge Stealth R/T Turbo - Project car, currently off the road with unsolvable problem. _________________________ 1995 Black VR-4 Spyder - Current Daily Driver, purchased March 2005. PST Carbon Fiber Driveshaft, Southbend TZ Clutch, K&N FIPK, DNP Y-Pipe, Stillen Downpipe, Ohio Spyderman short shifter, Mobo leather shift boot, manual leather seats from an SL. |
#528 (permalink) |
b@$tard guy!
Im burned out on reading through all these posts. man there are alot of them...
These blocker rings that have been discussed, they are the same thing as the inner and outer synchronizer ring as labeled in the FSM right? On 1,2, and reverse gears there are rings that seem to be pressed on, are there replacements for thoes or do we have to buy new gears? The teeth on thoes rings are worn much worse than anything else. Sorry if you already covered this, ive just been reading and searching for about 4 hours now. Chris
_______
-1992 mitsubishi 3000gt vr4 - sandstone grey just want to throw out a thanks to eveyrone that helped make up a part of the autocross event, you all did great! 1992 mitsu. 3000gt vr4 santsone on sandstone/grey - aka "the dirty wh0re" 1999 chevy silverado z71 ext. cab - red - "chevy" 2006 yamaha roadstar midnight warrior - "black betty" 1985 nissan 300zx GLL - "b1tchin' betty" needs some attention.. any takers? -wouldnt you know, every one of them should eventually have a turbo |
#529 (permalink) |
Gear Head
aerOvr-4gto3k - Blocker ring is one of many names for the same part. Yes they are the same thing. First and second gear accually have three synchro rings. An outer metal ring, middle friction ring (made of brass/bronze?), and an inner metal ring. The dog teeth that are worn will have to be replaced with the whole gear as an assembly. Nine times out of ten I have found the mating teeth on the synchronizer slider collar are also worn and also need to be replaced. Not much sense in replaceing one and not the other. The bad set of teeth will just wear out the good set.
#530 (permalink) |
b@$tard guy!
hmm... not what i was hoping to hear about the dogs an gears... probably going to cost alot more on this rebuild than i thought. Im going to get ahold of kormex and see if they have thoes gears, otherwise i dont know where else to go. suggestions? - i may be able to get ahold of a tranny rebuild kit from someone i know, bearings and synchros. they said "wow,thats an extensive kit"... hopefully that means the collars will come with.
My main concern right now are thoes dogs being all chewed up. Im suprised someone hasnt made replacement dogs. i mean machining the old ones off and pressing on new ones wouldnt be hard at all. Only thing i could think that might cause a problem is if they need to be pressed on in a certain position Chris |
