Old 12-27-2004, 04:24 PM   #511 (permalink)
b@$tard guy!
aerOvr-4gto3k's Avatar
Drives: on one wheel
aerOvr-4gto3k is an unknown quantity at this point
Default Re: Getrag 440/446 parts.
i third it in other trannys i have put it in.. how much were you paying a qt.? ive picked it up for half the cost of redline..
cj
_______
-1992 mitsubishi 3000gt vr4 - sandstone grey
just want to throw out a thanks to eveyrone that helped make up a part of the autocross event, you all did great!
1992 mitsu. 3000gt vr4 santsone on sandstone/grey - aka "the dirty wh0re"
1999 chevy silverado z71 ext. cab - red - "chevy"
2006 yamaha roadstar midnight warrior - "black betty"
1985 nissan 300zx GLL - "b1tchin' betty" needs some attention.. any takers?
-wouldnt you know, every one of them should eventually have a turbo
aerOvr-4gto3k is offline   Reply With Quote
Old 12-28-2004, 08:46 AM   #512 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (15)
mjannusch Level 1mjannusch Level 1
Originally Posted by fastmax
Ditto on the GM seceret sauce --- I tried it and there was no dectable difference in how the tranny felt or acted.
I switched from Redline to BG Syncroshift and that made a significant difference with reduced notchiness going into gears. Haven't tried the GM stuff - it is rumored to be the same as the BG product, but I've always used the BG with good results in many DSMs and 3S personal and customer cars.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'91 3000GT VR4 (Project for 2008)
mjannusch is offline   Reply With Quote
Old 12-28-2004, 09:02 AM   #513 (permalink)
no speed limits here
BLACK94TT's Avatar
Drives: A109E
Trader Rating: (20)
BLACK94TT is an unknown quantity at this point
Cool Re: Getrag 440/446 parts.
I made the same switch a few years back. I noticed an immediate improvement going into 3rd. I have to wonder if the rumor is related to the similiar sounding names.
Steve
BLACK94TT is offline   Reply With Quote
Old 12-28-2004, 09:35 AM   #514 (permalink)
3/S Guru
Drives: 90 Buick Century
Trader Rating: (8)
A/V dude is an unknown quantity at this point
Getting ahold of crs can be tedious at times. If anyone is looking for a source for bearings, NAPA has them. They are the same brand crs sells (german made SKF) They are packaged in a napa box, but in the fine print is skf. They are also around the same price as crs, but no cod charges, or freight if they have them in stock.
Front diff = 32008x & 32009x (1ea)
Front diff drive gear/shaft = 32009x (x2)
VCU rear brg = 32009x (x1)
Not sure about the vcu front, or the counter shaft
A/V dude is offline   Reply With Quote
Old 12-28-2004, 09:52 AM   #515 (permalink)
3/S Guru
Trader Rating: (8)
Ameture zone also has them in the "timken" brand, same part numbers and probably cheaper, but i choose german made parts for my german built tranny.
Old 12-28-2004, 12:52 PM   #516 (permalink)
BLACK94TT's Avatar
Drives: A109E
Trader Rating: (20)
Thumbs up Re: Getrag 440/446 parts.
good info
Old 12-28-2004, 02:24 PM   #517 (permalink)
Member in good standing
Jim Floyd is an unknown quantity at this point
I switched from Redline to BG Syncroshift and that made a significant difference with reduced notchiness going into gears. Haven't tried the GM stuff - it is rumored to be the same as the BG product, but I've always used the BG with good results.
Me too.
Jim Floyd is offline   Reply With Quote
Old 12-28-2004, 05:33 PM   #518 (permalink)
Senior Fanatic
Drives: 1992 Stealth R/T TT
Jeff Lucius Level 3Jeff Lucius Level 3Jeff Lucius Level 3Jeff Lucius Level 3
Originally Posted by Bret Brinkmann
I just switched from RED Line MTL to GM full synthetic Synchromesh just to see if they was much of a difference. There wasn't to tell the truth. Except for the price that is. Red Line is about three times as cheap. The Synchromesh did seem to help a little bit with my 2nd gear high RPM grinding but honestly, the difference is not large enough to warrent me spending the big bucks to put it in my tranny again. If any one needs Synchromesh to fix a grinding problem then they are just delaying the enevitable. Plus, Red Line is GL-4 and not GL-5 like Synchromesh. GL-4 is what the manual recommends and GL-5s decrease the life span of brass/bronze synchro material from what I remember.
I started with BG after the engine rebuild and switched to Red Line and didn't notice a difference. Then I switched to Pennzoil Synchromesh and noticed shifting was very noticeably improved. But "big bucks" for Synchromesh? It cost about $4.50 at Auto Zone (if available) and I bought a case of 12 quarts for $52 (includes 7%+ tax). Red Line is like, what, $6-7 a quart? Hardly worth the extra cost.
Also, Synchromesh has NO GL rating. It is NOT GL-4; nor is it GL-5.
And, yes, Quaker State, Texaco, and GM products are the exact same formulation.
More info:
http://www.stealth316.com/2-pennzoil-synchromesh.htm
Jeff Lucius is offline   Reply With Quote
Old 12-31-2004, 06:49 AM   #519 (permalink)
3/S Guru
Trader Rating: (8)
So is "permatex ultra gray" the preferred case sealant?
Old 12-31-2004, 08:08 AM   #520 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (219)
RobBeck is an unknown quantity at this point
ya
RobBeck is offline   Reply With Quote
