Old 12-03-2004, 03:22 PM   #481 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7
Default Re: Getrag 440/446 parts.
A/V dude - The springs are different bewteen the two.
vr4_rider - That price for all of the six speed synchros is about right. Remember that their prices do change fairly often. Some times the prices go up and some times down. Last I checked the synchro rings for reverse gear was pretty expensive compaired to the rest. The 3/4 ring is also a little higher priced than it used to be. Some of the others are a little less right now though.
250 RWHP
Old 12-03-2004, 05:23 PM   #482 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (12)
vr4_rider Level 1vr4_rider Level 1
Bret, are you refering to 250 for the first gear set, or for the WHOLE 1-6?
I bought 1-3 and Reverse for a little over 600 dollars!
Thanks,
Trung
vr4_rider is offline   Reply With Quote
Old 12-04-2004, 09:10 AM   #483 (permalink)
Gear Head
When AutoCraft/CRS has everything in stock you can get a set (1-6+reverse)for around that price. If they don't have all the rings for 1/2 then you can get a set through Mentor Mitsu between $200-$250 for just one set of rings for 1st or 2nd depending on which design rings you have. 91-92.5 or 92.5-99 but both sets are interchangable as I am currently running 91-92.5 rings in my 1st and 2nd gears for my 94 transaxle.
Old 12-04-2004, 09:26 AM   #484 (permalink)
3/S Guru
Drives: 90 Buick Century
Trader Rating: (8)
A/V dude is an unknown quantity at this point
Anyone have an extra 1-2 syncro spring laying around??
A/V dude is offline   Reply With Quote
Old 12-07-2004, 05:54 AM   #485 (permalink)
Gear Head
I just PMed a guy about them. I know he used to had some. I'll get back to you when I hear a reply.
Old 12-07-2004, 01:06 PM   #486 (permalink)
Senior Fanatic
Drives: 1992 Stealth R/T TT
Jeff Lucius Level 3Jeff Lucius Level 3Jeff Lucius Level 3Jeff Lucius Level 3
Originally Posted by Bret Brinkmann
To clearify a few things, there are not steel synchro rings or hardened rings available nor where they ever. I do not know how this rumor got started but I do have an idea how it came about.
I have a complete set of synchros for my W5MG1 as seen on http://www.stealth316.com/2-awd4.htm . As I mentioned *all* synchro parts are steel except the reverse ring. There is a friction coating on one or both sides of the rings.
Jeff Lucius is offline   Reply With Quote
Old 12-07-2004, 01:15 PM   #487 (permalink)
3/S Guru
Trader Rating: (8)
Thanks
Old 12-10-2004, 03:29 PM   #488 (permalink)
3/S Guru
Trader Rating: (8)
The spring i got from Miguel from his 6 speed is not the same as the 5 speed (it is the same as the 5 speed 3-4 spring though, but we are not 100% sure the one he sent was in fact the 1-2 spring)
So anyway, i still need these, and now that i have the springs removed, i find there are 2 broken not just 1
Thanks
Old 12-10-2004, 05:09 PM   #489 (permalink)
The Codebringer
Gatecrasher's Avatar
Drives: 81 Fiat Panda
Trader Rating: (7)
Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7
With all of the people and resources this board has, we can't source a few springs?
Gatecrasher is offline   Reply With Quote
Old 12-11-2004, 01:02 PM   #490 (permalink)
Gear Head
I should have been more specific with my respronce. I was refering to the friction coatings. The friction coatings are not steel. Some of the synchro rings used in newer Getrag applications look to be solid steel though. They have no friction coatings at all.
We found a source for the springs. It just isn't a very practical source. they are out of a $65 chevy over haul kit. Sixty five dollars for a set of springs doesn't sound too good to me but it is better than $200+ for a synchro assembly. If any one knows of an alternitive source let me know.
