Old 10-05-2004, 09:26 AM   #361 (permalink)
KORMEX's Avatar
Trader Rating: (11)
KORMEX Level 7KORMEX Level 7KORMEX Level 7KORMEX Level 7KORMEX Level 7KORMEX Level 7KORMEX Level 7
Default Re: Getrag 440/446 parts.
Originally Posted by Alan92RTTT
Wasn't your ring a higer quality than the CRS OEM ring?
I recall that being the justification of the higher price.
The price of the product is determined (by us anyway) by
How much investment for develpment :
1.)Reverse engineering -this is usually very simple but this part was particularly expensive.
2.)Minimum buy (you need to buy at least 1000 pcs.)
In our case we also had a failed run that cost quite a bit (parts where to spec but material was not satisfactory) this happens often when developing anything. Imagine trying to build a webpage where you cannot change anything once you build it . And expect it all to work flawless.
3.) What do we want back for the investment
this number is a product of projected sales,and determines the price .
We do not price things according to : "how much are they willing to spend"
that question is weighed before developing anything .
As for the quality , we did some initial testing (after the investment) that determined that they were better then what was available at the time (good used) . There are some that swer by them ,and there are others that wouldn't want them for free (Ray R.) . All in all it was a good deal for us (we are not here to come out even ) And the only complaint that I have is that some beleive that somehow we are ripping people off but hey
things alwys have a way of turning out for the best ,and we all move on .
KORMEX is offline   Reply With Quote
Old 10-05-2004, 05:04 PM   #362 (permalink)
Time traveler
DocEBrown's Avatar
Drives: The 1st of the Last
DocEBrown is an unknown quantity at this point
uhm let me do the math on this one... The inner ring (the part really needing replace ment the most, correct?) is only $80. The whole brand new synchro assembly is $224 from Howard and takes 4-5 weeks to come in. *sniff sniff* I smell a deal. If you had to make like a 1000 of these then that means that you must have a pretty good stockpile left no? Are they available for the 6 speed?
Commenting on your other parts (forgive the hijack) Those all sound like excelent ideas for parts. I'm sure there will be enough demand for them in the very near future if there isn't already.
Anyone have troubles getting on to gatecrasher's website recently? I can't even get a hold of him to find out if his syncros worked out or not.
DocEBrown is offline   Reply With Quote
Old 10-06-2004, 12:20 AM   #363 (permalink)
[3L] is an unknown quantity at this point
Once your current stock runs out do you plan on making a better than new OEM version?
[3L] is offline   Reply With Quote
Old 10-07-2004, 10:59 AM   #364 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7
Where did you get $80 from for the inner ring? When CRS had them in stock they were about $25 each if I remember correctly. Getting through Howard (AKA Mitsu) is deffinately a higher cost and it takes longer to get them in but at this time is our only option. Don't get me wrong, a set of synchros for any other car will cost about that much too (the triple set for the Supras is also about that price through the dealer) but it's going to be pretty hard to beat CRS prices for the most part.
I have bought a lot of parts through CRS (including synchros) and they work just fine. They get them through Getrag, the OEM manufacturer. Good luck getting on Gate's web site.....
250 RWHP
Old 10-07-2004, 01:25 PM   #365 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (228)
RobBeck Level 5RobBeck Level 5RobBeck Level 5RobBeck Level 5RobBeck Level 5RobBeck Level 5
Have we lost all the Getrag data since Gatecrasher took it down? That was really nice stuff its a shame if so.
RobBeck is offline   Reply With Quote
Old 10-07-2004, 01:27 PM   #366 (permalink)
ViperGTS2002's Avatar
Drives: '92 3000GT VR4
ViperGTS2002 is an unknown quantity at this point
What info was that, all of the parts diagrams/drawings? If he took it down due to space/bandwith concerns, I'd be more than happy to host it as well. Someone with more info let me know, I'm not on the computer much but I check in every day after school/work.
ViperGTS2002 is offline   Reply With Quote
Old 10-07-2004, 03:06 PM   #367 (permalink)
Mike F
mike21b is an unknown quantity at this point
Exclamation Re: Getrag 440/446 parts.
CRS price for the 1/2 ring was, as of August 11, actually only $15.03 each.
It's item C47 on the drawing, CRS part number 0408004805
Since I am posting, I will also thank Kormex again, for getting the parts that CRS did not have: bearings and the output shaft.
Too bad I toasted the engine less than a week after getting the transmission rebuilt!
(See "Installing 1997 VR4 Engine into 1992 TT" thread in AWD section.
Mike
mike21b is offline   Reply With Quote
Old 10-08-2004, 11:10 AM   #368 (permalink)
Gear Head
All of Jeff's information was aquired doing countless hours of reaserch on CAPS as well as speaking personally to many many individuals. Most of the pictures and info you can get your selves by looking in the Japanese version of CAPS.
Old 10-08-2004, 02:09 PM   #369 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Right.
So are you saying its back to square one?
Old 10-09-2004, 02:30 PM   #370 (permalink)
This space for rent.
38 Cigarette's Avatar
Drives: a 1600 hp canoe
38 Cigarette is an unknown quantity at this point
I called CRS for a 1-2 shift fork just now, for my 446 6-spd, I got his voice mail. My tranny shop called Kormex first but they are temporarily out of them.
Pearl Yellow DR Stealth TT M6
And Others.
Buy my book: Goat Rodeo's for Dummies
38 Cigarette is offline   Reply With Quote
