Old 08-13-2004, 07:28 PM   #341 (permalink)
Mentor Mitsu's Avatar
Drives: Slowly due to ticket
Mentor Mitsu is an unknown quantity at this point
Default Re: Getrag 440/446 parts.
[quote=Dflex]There are two different output shaft seals since the 25 and 18 spline has different diameters. MR110306 seems to be for the 25spline and as far as I can see, CAPS gives the same part number for -91 and -95 which obviously can't be right. Does anyone know the partnumber for the 18 spline seal?[/QUOTE
Daniel,
I believe the part# is MB837027 used from the 1st week of April of 1990 to the first week of November of 1991. List price is $25.20 and available from U.S. Dealers.
Though I am backtracking from your part# and don't have access to my jpeg files at the moment to confirm its application. Hope this helps.
Thanks,
Howard
BTW- My price is $18.90
Last edited by Mentor Mitsu : 08-14-2004 at 06:18 PM. Reason: I forgot to include my price.
Mentor Mitsu is offline   Reply With Quote
Old 08-21-2004, 10:27 PM   #342 (permalink)
Mike F
mike21b is an unknown quantity at this point
Thumbs up Re: Getrag 440/446 parts.
Day 22: I finally have the transmission parts that I need - either on hand, or on the way. Kormex had the parts that CRS did not (thanks, Frank, I know you watch this thread): 18 spline output shaft and 9 bearings.
The rest have finally shipped from CRS. I would rather replace the synchro assembly for 1st and 2nd gear, but CRS does not have the Inner Ring (C48). CRS had all the rest of the parts that usually wear out.
The most worn part of my 160,000 mile transmission was the bearing on the output shaft: the rollers were flattened.
No wonder no one wants to work on these transmissions, they are easy to rebuild but parts are hard to obtain.
I'll post a full chronicle when it's all back together.
Mike
92 RT/TT
mike21b is offline   Reply With Quote
Old 08-26-2004, 11:13 AM   #343 (permalink)
yeanchie's Avatar
Drives: VR4, T78supra & GSR
yeanchie is an unknown quantity at this point
Hi i need a little help on ordering parts for my tranny. my 1st and 2nd are grinding. so I was wondering if anybody knows what are the parts to order to complete the rebuild. I mean everything such as seals and synchros. Thanks in advance for all the helps.
or point me to the link that you know where I can get the info.
yc
Sports car? who needs a sports car? I know I want a FAST car.
yeanchie is offline   Reply With Quote
Old 08-26-2004, 11:22 AM   #344 (permalink)
Mike F
Send me an email: mike21b@dejazzd.com.
If you have a 1991 or 1992 (early models) with 18 spline output shaft, I have a list of all the part numbers that you (probably) need.
As I write this, day 26, the last of my trans parts arrived from CRS just minutes ago.
Mike
92 RT/TT
160,000 miles on original trans
Old 08-26-2004, 11:28 AM   #345 (permalink)
yeanchie's Avatar
thanks I have a 1992 with a 93 5speed. I sent you an email too. Anybody has the part list for 1993 5speed? thanks
Old 08-26-2004, 12:38 PM   #346 (permalink)
Mike F
Exclamation Re: Getrag 440/446 parts.
As far as I know, no one has the COMPLETE parts list - and Getrag cross reference list - for the 5-speed. I've compiled most of it, but don't have Getrag numbers.
The 6-speed lists are more complete.
These transmissions are easy to rebuild, if you have the parts.
Old 08-27-2004, 09:28 PM   #347 (permalink)
Drives: 97 SOHC 6spd
mugget is an unknown quantity at this point
mike21b, how much did the 9 bearings from Kormex run you? Not sure if I should replace mine along with the rest of the synchros yet..
Conversions:
1.) Auto to 6 Spd
2.) Digital Climate Control
3.) 99 Sails
4.) Custom Interior
mugget is offline   Reply With Quote
Old 08-27-2004, 09:38 PM   #348 (permalink)
Mike F
9 Bearings from Kormex is $250
Output shaft $250
From CRS, $330 total:
Full set of syncro rings
Bearing with seal B02
3 seals and rear plug
Mike
92 RT/TT 18 spline
Old 08-31-2004, 05:01 PM   #349 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (228)
RobBeck Level 5RobBeck Level 5RobBeck Level 5RobBeck Level 5RobBeck Level 5RobBeck Level 5
Ok Guys If you are not aware I am about ready to do the MR (RobBeck) gearswap. I am looking to see if ANYONE knows what the Transaxle Pinion Preload/endplay (whatever you wanna call it) is so I can confirm its all good before I reassemble. If I get no answer i will have to check my stock arrangement and guestimate which sucks nuts, it will also take a lot of time when I know someone has to have some literature on this. Its for the Getrag 6. Maybe CRS has it?
Thanks to anyone who can answer this,
Rob
RobBeck is offline   Reply With Quote
Old 08-31-2004, 05:30 PM   #350 (permalink)
Warning: I'm an asshole
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (10)
SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7
Rob
Call CRS. They usually have the best prices.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit.
--Daily Driver: 98 Malibu, 4cyl, auto
SkortchGT is offline   Reply With Quote
