Old 06-20-2004, 01:28 AM   #311 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (228)
RobBeck Level 5RobBeck Level 5RobBeck Level 5RobBeck Level 5RobBeck Level 5RobBeck Level 5
Default Re: Getrag 440/446 parts.
You may want to make a new post about your problem, sounds like it could be something that is easier to fix.
Rob
Originally Posted by awesomedave
Alright, I read through this whole thing, but I haven't really been able to keep the part numbers straight. I want to replace all the syncros in my trans, but I'm not sure if I should replace anything else at the same time. It should be in good shape (besides the syncros) and the only reason they're acting up is because I forgot to put grease on my input shaft when I changed my clutch a month ago, and it hasn't shifted well since. Last week the first gear syncro went completely, and I don't know how long the others will last. Anyway, since I'm gonna have to take this friggin tranny out again anyway, I might as well make it perfect (and fix the first gear syncro that is ruined anyway). So I would appreciate it if someone would be kind enough to provide a list of recommended replacement bits I should look into getting. Thanks a bunch!
RobBeck is offline   Reply With Quote
Old 06-27-2004, 03:59 PM   #312 (permalink)
92 Dodge Stealth
Quijinn's Avatar
Drives: 92 Dodge stealth
Quijinn is an unknown quantity at this point
I know everyone is worried about the tranny and parts and what not. But I really dont think it is that horrid of a problem. There are alot of other options no one is commenting on. Like tranny conversions. I mean the awd tranny in our cars is a all in one unit with a not so well desined transfer case. Other then that its bassically the same as all other awd cars. I am not saying it would be cake, but if I ever blow the tranny and cant get parts I will figure a way to do a swap even if I have to make it rwd instead of awd. Haveing imporved parts and maybe some nice case bands would be great, but if we lose these trannys it wont take long for some of us to figure out a solution. Alot of stuff has been figured out/made by the ppl here. So don't think its the end of our cars. Maybe just a newpath.
92 Dodge Stealth; AEM EMS; Single channel AEM WBO2; K&N Filter. Denso 720 injectors, 3 bar map, Gm IAT, Type H-34 BOV, Denso 290lph in tank pump, 15g turbos, Spec stage 3 plus clutch. Custom exhaust, tein springs. Hardend Kormex trans output shaft, Poly motor mounts.
Balanced and blue printed motor, 20k on motor 2.5-3.5% leak down tested 2k miles ago. 83k miles on the car, BFG KDW2 tires. Car been maintained very well, Amsoil for the motor, Penz syncromesh for the trans.
8.08 (15 g 14.5psi) pump gas
86mph (15g 14.5 psi) pump gas
Quijinn is offline   Reply With Quote
Old 06-27-2004, 04:26 PM   #313 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Tooling/molds/metalurgy/etc would be a pretty expensive path to take to make these ourselves. We really need to hope Getrag keeps production up on these, or else we are screwed.
Rob
Old 06-27-2004, 04:47 PM   #314 (permalink)
92 Dodge Stealth
Quijinn's Avatar
Rob
You are thinking way to deep into it. Changeing mounts, and makeing an adapter would be the hard parts. You adapt the new tranny to the block. then adapt that transfear case to the drive shaft. Might have to get new front axles made but thats not to bad alot of companys do it for a decent price. Well better then 6k
Old 06-28-2004, 03:48 PM   #315 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7
The parts issue looks to be solved for the most part thanks to Mentor Mitsu and his "very special order parts". Thanks again buddy! Anything we can't get through CRS or Kormex we should be able to get through him at his dealership. It may take a while for shipping but we can get them.
If any one has questions about what parts to order feel free to get up with me. My contact info is in my sig. It may take me a while to get back to you but I will get back to you.
Mentor Mitsu - How about posting one last time the best way to get up with you about ordering some tranny parts. I'm sure every one would appreciate it.
250 RWHP
Old 06-28-2004, 10:31 PM   #316 (permalink)
Mentor Mitsu's Avatar
Drives: Slowly due to ticket
Mentor Mitsu is an unknown quantity at this point
Bret,
Thanks and I hope you received my PM. Lets hook up on the phone and compare notes as its faster and easier.
As far as the easiest way to contact me:
http://www.trademotion.com/partlocat...?siteid=213934
or call me at 1-877-44-MITSU. Please be patient as we are a bit shorthanded right now.
Thanks Again,
Howard
Mentor Mitsu is offline   Reply With Quote
Old 07-25-2004, 11:48 PM   #317 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Ok anyone know the easiest place to get driveaxle and output shaft seals and at what cost? Does the Mits dealer have the ability to get those since its such a service item or does this still fall under CRS, Kormex, or M&M?
Thanks,
Rob
Old 07-25-2004, 11:54 PM   #318 (permalink)
b@$tard guy!
aerOvr-4gto3k's Avatar
Drives: on one wheel
aerOvr-4gto3k is an unknown quantity at this point
Thanks,
Rob
i bought them all from my dealer..suprisingly they are much cheaper than any parts store.... regular service items such as seals will be available almost anywhere.. its the hardcore internals of the transmission that are the issue.
chris
_______
-1992 mitsubishi 3000gt vr4 - sandstone grey
just want to throw out a thanks to eveyrone that helped make up a part of the autocross event, you all did great!
1992 mitsu. 3000gt vr4 santsone on sandstone/grey - aka "the dirty wh0re"
1999 chevy silverado z71 ext. cab - red - "chevy"
2006 yamaha roadstar midnight warrior - "black betty"
1985 nissan 300zx GLL - "b1tchin' betty" needs some attention.. any takers?
-wouldnt you know, every one of them should eventually have a turbo
aerOvr-4gto3k is offline   Reply With Quote
Old 07-26-2004, 08:21 AM   #319 (permalink)
no speed limits here
BLACK94TT's Avatar
Drives: A109E
Trader Rating: (20)
BLACK94TT is an unknown quantity at this point
Cool Re: Getrag 440/446 parts.
Here ya go, Rob. Straight from CAPS:
O/S seal - MR110306
Left Axle - MB837028
Right Axle - MB837029
Steve
BLACK94TT is offline   Reply With Quote
Old 07-28-2004, 11:01 AM   #320 (permalink)
Gear Head
You can get those three plus the cap on the back of the input shaft from CRS for around $30 total last I checked. CRS seems to be the cheapest place for seals, bearings, and synchros. (With the exception of the inner blocker ring for 1/2 of course sense they no longer offer it.) Be sure to factor in shipping though.
