#201 (permalink) | |
POLYCHRONOPOULOS
If the forks never break that is way cool
And dont get me wrong, there definitely is no point in making something custom for something that rarely breaks... and even if it did break it would be easily replaceable for a marginal cost. I still think a billet aluminum fork would be a lot better suited to the occasion, but if the cast ones are trouble free then who cares. I dont know enough about this particular gearbox to really speculate all of its capabilities... but from the way it sounds it is terrific. I have never heard of it busting gears or clustershafts, etc... that could get pricey It really sounds to me that if you keep it well lubricated, keep you clutch adjusted properly, and make positive shifts that it will last you forever.Rob Quote:
#203 (permalink) | |
POLYCHRONOPOULOS
Theo... Thanks! Yes that shift fork would be easy to make out of billet. But from what I have been told they never break so its pointless to fabricate
The only broken component we should have trouble with in this trans is the synchros... if the fork doesnt break its usually will just eat a synchro. It is most lkely that a synchro will be replaced if a fork breaks anyhow so who cares. I think I may find that I could have a bad 3/4 shift fork when I pull mine apart I guess the forks really should never break provided good maintenance and shifts take place, but again it comes down to price and availability if they do take a shit. Anyone got pricing or availability on them yet?Rob Quote:
#205 (permalink) | |
POLYCHRONOPOULOS
Ouch. What kind of damage was done from the fork debris going thru the gear?
Any idea on if we can replace these forks from CRS or Kormex and for how much? Rob Quote:
#206 (permalink) |
Gear Head
Theo_VR4 - That looks just like my broken 1/2 fork. If only the clutch wasn't draging my poor fork wouldn't have broken on me. Oh well. I needed an excuss to work on my car.
If you break a fork then you loose both gears. First AND second, third AND fourth, you get the idea. You may still be able to put the shifter into that spot but you won't have those gears. I was surprised the pieces of my fork didn't get cought up in my gears and take some thing out with them. I really dodged a bullet on that one. Last I heard neither CRS nor Kormex had any forks. Never hurts to check up on them though.RobBeck - If you do end up needing a fork let me know. I have a buddy who is parting out an 18 spline transaxle.
![]() 250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#207 (permalink) | |
POLYCHRONOPOULOS
Bret,
Dont kid yourself you can break a shift fork by missing a gear with an otherwise healthy trans and properly engaging clutch, especially when powershifting. It all has to do if you let out on the clutch before the trans is completely in gear while at WOT and how aggressive you are as a shifter (accidents will and do happen ). Of course if your clutch is dragging then the probability will go up, but that is not the only reason it could happen.Also, Pending on the degree of the break (the ones in the pic look very severe and this doesnt apply to them), you could still get into gear but only feel a synchro like grinding sensation. This maybe moreso when a part of the little rail on the shift fork breaks and/or cracks that rides in the hub assembly/slider. I broke one before on a T5 (wouldnt ya know it 4th gear) where I swore it was the synchro but low and behold it was a minor shift fork breakage upon disassembly. Of course I replaced the synchro anyway... but the fork obviously wasnt completely doing its job. Time will tell if I need that 3/4 shift fork, I certainly hope I do not. I do know I heard no noises in the trans after it happened. Actually tho, if it did survive.. I will be really impressed. Also I have a 6 speed anyway, so I am not for sure they are the same part number. Rob Quote:
#209 (permalink) | |
Gear Head
)The forks in the 5 and 6 speed transaxle are slightly different. Different enough to not be interchangeable anyway. |
#210 (permalink) |
The Chaosbringer
I've finally started to build my website into something a little more useful. You guys can check for diagram updates and news on parts availability at www.xtreme3s.net. Try to ignore the crappy design right now. It's very much a work in progress.
