#162 (permalink) |
Gear Head
Gatecrasher - No problem. You guys seemed as though you both were headed that way any way.
Robert Duncan - It's not the tranny as a whole that gives us problems, it is certain individual parts. Even then there are other parts that will wear out regaurdless or cryo teatment or what ever. To date no one has ever broken a gear. The only shaft we have broken is the 18 spline output shaft. That is sovled by buying a 300m 18 spline shaft. The 25 spline shafts may strip if there is a build up or rust or corrosion. You can prevent this by applying some greese to the splines. If you want to know anything else about common failures or drive train weaknesses feel free to send me an e-mail. davidX - Komrex sell a NON-OEM middle (AKA friction ring) synchro ring for 1/2. The issue is that CRS will not offer any more of the inner blocker rings for 1/2. These rings have been known to break. As is the case for my transaxle and one other customer of mine. Every one should note: At some point we WILL need more than just synchros. We will need internal componants to the TCs and other random gears, shafts, houseings what ever. CRS informed me that they will stop makeing several other parts for these transaxles not just the inner blocker ring for 1/2. We have one other member who needs a pinion shaft for his six speed. Neither CRS or Kormex have one and it doesn't look like one will show up soon. I need a 1/2 shift fork for my six speed. Any one got a spare? I'd be surprised if you did. My point is this. We really need a PARTS supplier not a SYNCHRO supplier. We shouldn't forget that...
![]() 250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#163 (permalink) |
Boom Boom Sucky Sucky
Well whatever happened to buying parts from getrag, my offer still stands to buy in bulk from them, if they will sell to me..
-Geoff
'92 Blue Eagle Talon Tsi AWD
ProStreet Race Engine Hacked MAS SAFC2 Big 16G Full 2.5" Exhaust w/High Flow Cat UICP w/SSQV Friends Car: '92 Panama Green 3000GT VR4 (??? miles) Matrix Intake Blitz DSBC Spec-R (Indigo) ESP "Race" Downpipe 3.0" Test Pipe Gutted Pre-Cats Custom Cat-Back 3560 lbs (No Driver, Empty Tank) |
#164 (permalink) | |
BUILDING CRAZY 3S's
wonder who's that is?!?!? so are we haivng any more luck with the blocker rings, the porshe info is not panning out at any pace faster then a turtles crawl would love to see us have a new parts supplier as my spare tranny is not keeping up with the one that is in the car anymore |
#165 (permalink) |
The Chaosbringer
Ok friends, I've finally uploaded the 6-speed cross reference.
I cannot promise that it is perfect! If you find an error, please tell me. I'll get a proper web page up soon, but I didn't want to leave everyone hanging until then. Diagram: http://xtreme3s.net/images/getrash/6...%20Diagram.jpg 946K. BIG SOB I have no idea how to print this on any normal printer I'll play with the orientations and see if I can't make it look better.I also included the charts at ths bottom as an Excel spreadsheet. This way you can add prices or notes for yourself, and use Excel's search to find a PN instead of trying to eyeball it on the graphical list. http://xtreme3s.net/images/getrash/6...0reference.xls I'll start work on the 5 speed soon.
#166 (permalink) | |
Warning: I'm an asshole
1992 3000GT VR4
![]() ![]() --Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579 --First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon) --Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit. --Daily Driver: 98 Malibu, 4cyl, auto |
#167 (permalink) | |
POLYCHRONOPOULOS
Gatecrasher you kick ass bro.
Rob Quote:
#168 (permalink) |
The Chaosbringer
I'll go one better. Here's a downsized version of the chart edited and cleaned up by Mike Meskill (krusaderx) It's black and white and 600k. The actual image size is still the same.
http://xtreme3s.net/images/getrash/6...aster%20BW.gif |
#170 (permalink) | |
