Old 06-09-2006, 06:21 AM   #1 (permalink)
uhhh....Bankai?
Cecropia's Avatar
Drives: A turd...for now
Trader Rating: (10)
Cecropia Level 1Cecropia Level 1
Default Gear puller? to use or not to use
I had heard some ppl saying not to use a gear puller b/c of chipping gears/breaking teeth. Is this just an isolated few or should i not use the puller? I'm removing 1st and maybe second gear
Also(NOOB QUESTION), once all the components of the shaft are off how do i put them back on? I thought ppl said you don't need a press for 1/2nd gear work.
TN3S.......just say NO to 3.5Ls
Cecropia is offline   Reply With Quote
Old 06-09-2006, 12:11 PM   #2 (permalink)
pody3kgt's Avatar
Drives: '04 STi, '92 3kgt
Trader Rating: (6)
pody3kgt is an unknown quantity at this point
Default Re: Gear puller? to use or not to use
I know that I broke a tooth on my 5th gear. It's not worth using a puller, unless you have an actual bear splitter. By the way, a new 5th gear is $281....
pody3kgt is offline   Reply With Quote
Old 06-09-2006, 01:14 PM   #3 (permalink)
uhhh....Bankai?
Cecropia's Avatar
Trader Rating: (10)
gears 3 through 5 require a press though right?
Old 06-09-2006, 01:19 PM   #4 (permalink)
Drives: 92 TT Stealth
jjtump is an unknown quantity at this point
Well If you have a monster sized gear puller you could reach more then 1st gear but a press will make life so much easier. I originally tried to do mine with just a gear puller that I rented from auto zone. It was too small to do the job effectively and I ended up finding a press. You should be able to find a press at most auto/machine shops and It shouldn't cost that much if anything just to have em pressed off.
jjtump is offline   Reply With Quote
Old 06-09-2006, 01:20 PM   #5 (permalink)
uhhh....Bankai?
Cecropia's Avatar
Trader Rating: (10)
cool, what would you consider monster sized?
Old 06-09-2006, 01:22 PM   #6 (permalink)
uhhh....Bankai?
Cecropia's Avatar
Trader Rating: (10)
reason being the only place i know that has a press (local trans place) doesn't like me
Old 06-10-2006, 12:52 AM   #7 (permalink)
Well I guess anything over 8" might work. Do you live in a real small town? There has to be more then one place with a press. What about just walking in the door of an industrial wearhouse/complex pretending like you work there and then just ask around for a press?
Old 06-10-2006, 06:04 AM   #8 (permalink)
uhhh....Bankai?
Cecropia's Avatar
Trader Rating: (10)
lol they'll never fall for that, that's a pic of me in my profile. So any press will work? not just a transmission specific one? hmmm
Old 06-10-2006, 12:58 PM   #9 (permalink)
Just about any hydraulic press will work. The harder part for me was finding blocks of steel that fit the round shape of the gears. To spread the contact over a greater number of teeth. Do you know what I am saying? Sort of a big ( shape. One for each side. I never did find any that fit perfect. It did take quite a bit of force also. I was fortunate enough to use a press with a force gauge on it however I was too focused on catching the shaft when it fell to watch to see how many actual pounds of force was required. As long as that one c-clip ring is out the gears will come off even if it seems like it will break.
I would try some of the local auto shops or even a dealership just to see if they have a press. Or ask around for other backyard mechanics because presses aren't that expensive and more guys have them then you may think.
