Old 03-02-2008, 06:03 AM   #31 (permalink)
'96 VR4
tachyon_ftl's Avatar
Drives: It's spos'd to move?
Trader Rating: (12)
tachyon_ftl Level 4tachyon_ftl Level 4tachyon_ftl Level 4tachyon_ftl Level 4tachyon_ftl Level 4
Default Re: Driveshaft Help please!!!
Hm. Are they for a VR4? CAPS doesn't show the universals as replaceable; in fact, CAPS dosn't even show any of the three shafts as replaceable. The only way to get new shafts/universals from Mitsu is to buy an entire new driveshaft.
tachyon_ftl is offline   Reply With Quote
Old 03-02-2008, 08:10 AM   #32 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6
Originally Posted by phantomrt View Post
Hmmmm, I just went to Mentor Mitsubishi's web site, and I looked up Universal joints... it says $189.17. What are these for? They're in the "propeller shaft" section.
Yeah, I saw that too. I'm guessing that's the Lobro joint that connects teh middle and rear sections of the driveshaft. It's kinda like a CV joint sort of.
Jeff W.
Red '92 VR4 214,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Big 16G Turbos w/IPS headers and pre-cat eliminators, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS Stage 5 clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PowerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 03-02-2008, 08:11 AM   #33 (permalink)
phantomrt's Avatar
Drives: fast
phantomrt is an unknown quantity at this point
a Non-VR4 wouldn't have U-joints anywhere. I am pretty sure they are not intended to be serviceable as well. If I get some spare time on Monday, I might call them to see what in the world they are talking about.
92 Stealth R/T TT 73k
92 Daytona ES 2.5 Turbo / A523 103k
92 Lebaron GTC Conv. 2.5 Turbo / A568 158k
91 Daytona ES 3.0 V-6 / A543 190k
93 Geo Metro 1.0/5spd 126k *resurrecting*
phantomrt is offline   Reply With Quote
Old 03-02-2008, 09:17 PM   #34 (permalink)
stans3000gt's Avatar
Drives: 1992 VR-4x2, 1993 SL
stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7
Thats some good info I am still looking for a good driveshaft no luck so far. I might just be forced to buy a new one soon since I cant have this car down anymore.
stans3000gt is offline   Reply With Quote
Old 03-02-2008, 09:51 PM   #35 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (26)
Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7
call mne at gtpro tommorow. i will take care of you with your budget that you have because your in need. i have several in stock so i can make you a great deal on a low milage vr4 DS (oem)
Denis 714 447 1697 ext 266 at gtpro. it will leave tommorow if you call early enough. i will take care of you on the price.
AEM EMS INVENTOR TRAINED JEDI MASTER CERTIFIED NINJA TUNER
www.gtpro.com
Dj4play is offline   Reply With Quote
Old 03-02-2008, 09:59 PM   #36 (permalink)
OH hey thanks a lot!!! I will be in touch!
Old 03-02-2008, 10:32 PM   #37 (permalink)
Hey guys LOOK WHAT AI FOUND!! I dont know if anyone else purchased this but the price is pretty good compared to all the other companies. What do you think??
link
http://www.extrememotorsports.com/ca...t-p-33811.html
Old 03-02-2008, 10:43 PM   #38 (permalink)
Just found it even cheaper
http://www.ultrarev.com/product.php?productid=45528.
I do still think I am better off getting a used one just because of financial reasons.
Old 03-31-2008, 09:48 PM   #39 (permalink)
So I am just wondering to who had the driveshaft off before is it normal to get this little click in the middle of the U joints on the driveshaft when moving it back and forth the front one doesnt do it but the back two do it just about evenly it still moved pretty freely and feels nice and tight, I am in the process of installing it but I am jw if anyone knows???
Old 03-31-2008, 09:49 PM   #40 (permalink)
And by back anf forth I meant to say that I am holding the rear piece in my hand and I am moving just the joint not the whole driveshaft, just figured I would clarify myself. Thanks
