Old 04-11-2008, 06:54 AM   #11 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
Default Re: Does this output shaft look ok?
Originally Posted by My92Stealth View Post
Dont mean to jack the thread but i dont want to make a new one since this one is here...I suppose this one is no good?
That one is bad. It has begun to twist the splines. On the next few hard launches the shaft will twist off. Mine was tweaked less than that I bought a 300m because I was replacing some syncros anyway.
Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops MAXED out, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, 17" chromies, Nitto 555s
Drivetrain: RPS Street Max, M.W. 300m O/S
Etc: Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
JEDI MASTER SAFC NARROWBAND BASED TUNER, LORD OF THE DANCE ALSO
cbehnken is offline   Reply With Quote
Old 04-11-2008, 05:53 PM   #12 (permalink)
My92Stealth's Avatar
Drives: 91RT/TT,92Base
Trader Rating: (34)
My92Stealth Level 1My92Stealth Level 1
Weak. I'll be ordering an upgraded one tomorrow.
Thanks.
1991 RT/TT Pearl White/Porn Red 15g's + supporting, other mods. 92 Stealth Base DD.
My92Stealth is offline   Reply With Quote
Old 04-11-2008, 08:07 PM   #13 (permalink)
Forest Gump
cbehnken's Avatar
Trader Rating: (42)
Thanks.
300m for the win. Confidence in your driveline is priceless.
Old 04-11-2008, 10:49 PM   #14 (permalink)
Trader Rating: (34)
I dont have the $$ for a 300M so I'm going with quadco
Old 04-12-2008, 12:44 AM   #15 (permalink)
Paid Member
kid-k's Avatar
Drives: 91 GTO TT
kid-k is an unknown quantity at this point
you guys wanna compare fucked up output shafts? . check this bad boy out , pulled my clutch and got this as a gift .
new one from ebay will be here monday .
kid-k is offline   Reply With Quote
Old 04-12-2008, 04:23 AM   #16 (permalink)
Someone else's mistakes
venetrex's Avatar
Drives: 1992 3000GT VR4
venetrex is an unknown quantity at this point
This is such a damn common problem, you guys have clunking noises that soundede like they came from you rear end from this too???
venetrex is offline   Reply With Quote
Old 04-12-2008, 09:02 AM   #17 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7
I did. After I replaced my worn one with a 300M most of the clunk went away. Now I have to replace my mildly warn spool
92 Stealth RT/TT BPU
13.72@102.8 with a 1.95 60' and short shifting
1978 Cessna 172-N
160HP
Max Speed 123 Knots at sea level
Max Range 687 Nautical Miles
Service Ceiling 13,500 Feet
Max Takeoff Weight 2,450 Pounds
[Today 12:20 AM] Melis: aaron rock my socks! so there
[Today 12:25 AM] Melis: I ROCKED AARONSTATE SOCKS! thert you go
aaronatstate is offline   Reply With Quote
Old 04-12-2008, 12:22 PM   #18 (permalink)
Paid Member
kid-k's Avatar
Drives: 91 GTO TT
I actually didn't notice any clunking noises. Mine literally had so much rust in there that it was effing tight on the coupler , I actually think thats one of the reasons it never completly stripped, after cleaning all the rust off , I bet if I put it back in it would be clunking like hell and it would probably be completly stripped within a week .
but on monday the trans will go back together with a new output shaft / clutch , pressure plate , throwout bearing , slave and master cylinders.
soooo hooray
Old 04-12-2008, 08:05 PM   #19 (permalink)
loosescrew's Avatar
Drives: 92 vr4
Trader Rating: (6)
loosescrew is an unknown quantity at this point
Hey Venetrex, does that combo from mantrans look pretty good? I just bought that one but I haven't got it yet. I pulled my tranny out and found out my os and input sleeve are shot.
Have any of you guys had your tc looked at cause of the recall? I don't think my car ever made it in for that. It sat for the last 5 years until I bought it. Just curious because I wonder what the dealer would if I brought it in?
loosescrew is offline   Reply With Quote
Old 06-25-2008, 12:36 AM   #20 (permalink)
Drives: GTO
OLS_Faust_17 is an unknown quantity at this point
Hey, my 90' model GTO is in the shop at the moment. Initially it was in for some new synchros and bearings in the gearbox but then the the mechanic told me the output shaft was worn too. Through much turmoil the shaft is now being resplined which shouldn't cost too much. I am a little worried though that this shaft may break at some point in time as I do intend on upping the power. If it breaks, could someone give me an indication as to what happens if You're travelling along the road? Does it just keep rolling to a stop or is it something considerbly worse (all 4 wheels locking up etc.)?
OLS_Faust_17 is offline   Reply With Quote
