Old 12-16-2007, 09:11 AM   #1 (permalink)
Elina75's Avatar
Drives: 3000GT VR4 1993
Elina75 is an unknown quantity at this point
Default Clutch not disangeging
The clutch in my 1993 VR4 stopped working today.. almost hit a wall when after starting the car and holding the clutch down while in the first gear, the car suddenly jumped forward like if I had lifted the clutch pedal... jumped to the brake and managed to stop the car before hitting the wall.
The clutch is probably worn out, but has worked fine so far nevertlehess.
After the incident I pressed the clutch pedal and there was some stiffness and pressure left, but the clutch wasn't disengaging. After few presses there's now no pressure at all. the pedal goes down to the botton without any resistance, but comes back up when released. I checked there were no leaks showing, but still the clutch master cylinder was dry. No fluid at all showing.
I will try to bleed the clutch tomorrow, but does it sound like a slow leak somewhere or something else?? What could cause this sudden complete loss of clutch?
I have a new Fidanza clutch already waiting, but don't have time for that right now, so I would like to check everything else first...
EDIT: anyone have the part number for the slave cylinder, in case it turns out to be that.
Elina75 is offline   Reply With Quote
Old 12-16-2007, 03:40 PM   #2 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g Level 392stealth15g Level 392stealth15g Level 392stealth15g Level 3
Default Re: Clutch not disangeging
if your master is dry, put fluid in and bleed. you should be fine. Mine did exactly the same thing, but i had fluid. I replaced the slave and it was worn out but didnt really help the problem. It turns out it needed a new clutch. Since your master is dry im almost positive that putting fluid in and bleeding it will fix the problem. If it is leaking, you probably will want to replace the slave.. if you want a slave cylinder you can get it off 3sx.com:
http://www.3sx.com/store/comersus_vi...dProduct=24254
I personally just went to the parts store and ordered it. took a day to get it in and it was only $50.
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires.
"Knockin' Beater"
-1996 Mitsubishi Eclipse GS
Originally Posted by TitanGenesis View Post
"That thing got a hemi?"
"No, it's got a V6 TT with AWD sup?"
92stealth15g is offline   Reply With Quote
Old 12-16-2007, 04:23 PM   #3 (permalink)
Elina75's Avatar
Yeah I'll see tomorrow when I have time to take the intake, battery etc out, what is going on. Hopefully it's only the clutch hose or slave cylinder leaking, just it looks strange that the clutch went from "fine" to "dead" in one moment, if it's just a slow leak somewhere there.
Unfortunately the local shops have no 3KGT parts, any of them, and ordering takes a month or so. I have stuff from US (3SX among others), coming about every month, and will definitely order some clutch spare parts the next time (luckily I had one Fidanza clutch package, in case that is needed). Only now I need the car running next week, and it takes some time to get parts from US to over here...
Old 12-16-2007, 04:44 PM   #4 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6
Thsi sounds like a catastrophick hydraulic issue rather than a slow leak. sounds like you blew a seal in either the master or the slave cylinder, or the hose busted open. I doubt bleeding will solve the problem, but it may show you where the leak is. For Master cylinder leakage, the fluid will drain donw the insdie of the firewall and puddle up under the driver's side carpet. It's easy to miss if youre not looking for it specifically.
Jeff W.
Red '92 VR4 215,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Big 16G Turbos w/IPS headers and pre-cat eliminators, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS Stage 5 clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PowerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 12-16-2007, 08:39 PM   #5 (permalink)
Certified White Boy
yes, either way, its better to have to replace the slave or the master than replace the clutch. good luck.
Old 12-22-2007, 08:56 AM   #6 (permalink)
Elina75's Avatar
On the other hand there were no spilled or leaked fluid to be seen anywhere, if it was a sudden bust it should be visible somewhere...
Well, today had some time to investigate this, and everything looked fine and clean around both the cylinders. Bleeded it and the clutch was working, but something was definitely leaking as there were clear splashes of fluid in the firewall after this. Turned out to be the hose, a very small leak there. Made a quick fix and it's at least working and not leaking now. Should hold over the christmas time and then going to swap to a new ss-braided hose:
http://mitsu3000gt.qnet.fi/hose.jpg
Thanks for the hints everybody.
Old 12-22-2007, 09:40 AM   #7 (permalink)
1992 Stealth R/T
jbavousett's Avatar
Drives: N/A Beauty Queen
jbavousett Level 2jbavousett Level 2jbavousett Level 2
Broken fork...bad throwout bearing?
jbavousett is offline   Reply With Quote
Old 12-22-2007, 05:30 PM   #8 (permalink)
Certified White Boy
absolutly not if bleeding worked.
Old 12-27-2007, 07:26 AM   #9 (permalink)
Elina75's Avatar
Yeah, it was the hose. A tiny leak there, see the pics. With the pressure (anyone know how much there IS pressure, over 10 bar?) it spills fluids out quickly. It's kind of working now, but I need to replace the fixed hose asap anyway.
