Old 07-03-2009, 12:42 AM   #11 (permalink)
DocWalt's Avatar
Drives: 1994 3000GT VR4
DocWalt Level 1DocWalt Level 1
Default Re: "Clunky" Transmission
Just as an update on this, different trans fluid didn't help. I'm gonna flush it tomorrow and put in MT-90 and see what that does. I just hate wasting fluid because it leaks out the linkage.
Adjusting the linkage made it much easier to hit my gears correctly, but the notchiness is still there, and sometimes feels like it's scraping on the way into 3rd, no grind though.
edit: MT-90 made it shift a lot better, but maybe it was the 10W-30 I threw in on top.
<<3750 pound beast.
Forced Upgrades: IPS SS Shorty Downpipe, eBay Header (Front Only), 3SX Y-Pipe | Mods: Gutted Precats
Other Mods: DDM 35W 4500K HIDs
DocWalt is online now   Reply With Quote
Old 07-03-2009, 07:58 PM   #12 (permalink)
resident evil
wraith's Avatar
Trader Rating: (16)
wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2
Mine does a slight grind or more like a grr feeling in the shifter when it goes into 5th and high rpms at WOT, otherwise all my gears feel like a rifle. I have an OhioSpyder Bob short shifter with all other stock bushings. I love the way this tranny feels compared to my Tremec in the GTO. Locking you out of first happens more in the Tremec, then this car but I know the Tremec is tough so I dont worry as much with that car.
wraith is offline   Reply With Quote
Old 07-03-2009, 08:51 PM   #13 (permalink)
lvdonkey is an unknown quantity at this point
so you have fluid leaking out where the shifter cables attach? you can fix that easy if that is the case.
lvdonkey is offline   Reply With Quote
Old 07-03-2009, 08:59 PM   #14 (permalink)
DocWalt's Avatar
Even when it's leaking out the shaft? Not from under the plate. I see no way to pull the shaft out and fix the seal.
Old 07-04-2009, 03:18 AM   #15 (permalink)
That's a hard place for a tranny to leak from since that thing is around 1 o'clock on the tranny when it's bolted up, I wouldn't think fluid makes it up there very often.
I might try getting a very thin o-ring and cutting it to get it around the shaft and shoving it down with a small screwdriver.
Old 07-04-2009, 03:46 AM   #16 (permalink)
DocWalt's Avatar
Yea, exactly, but that's the ONLY spot it leaks from. Very annoying.
I have tons of o-rings, but I don't wanna mess with it, it doesn't leak horribly, but it still leaks.
Old 07-05-2009, 02:09 PM   #17 (permalink)
little Boss man
iguana's Avatar
Drives: 93 VR4
Trader Rating: (10)
iguana is an unknown quantity at this point
I only ever use Pensoil Syncromesh fluid. try searching for the part number for the Mitsubishi part "friction Modifier" it's a small bottle that you add to a filled tranny through the speed sensor hole. I've added it in the past and i think it helps shifting but ultimately worn syncros are not going to get better no matter what you add to the oil. Adjusting the cables under the shifter also can help. i lived with reverse jumping out for almost 2 years before i tried to fix it and all it took was a few minutes adjusting the cable length to get them centered when the shifter was in neutral.
Longwood Florida
DR500 turbos, ProfecB Spec II, No cats, Modified Stillen DP, 3" pipe with dual N1 cans, Walbro FP, TurboXS BOV, Stillen pads, Rotors, DXD clutch, Fidanza flywheel. MAFT, bigass KNN filter, 550cc injectors. 3SX lower mounts. Tien S springs. Jays93VR4 rear upper arms. Aluminum intake pipes, 3SX light pulley.
Still to install, Pre cat eliminators.
iguana is offline   Reply With Quote
Old 07-05-2009, 05:58 PM   #18 (permalink)
DocWalt's Avatar
I've put a few more miles on it today, and the fluid change fixed it. It wasn't bad synchros, I don't think. It would never grind unless I screwed up, it was only rough, like it would have to pop in one notch, and then another. It's hard to describe.
I also adjusted the cables, and that helped a LOT, but it was never perfect until I swapped to MT90.
I was using some crummy GL4 I could find locally. Not good :/
Old 07-05-2009, 07:29 PM   #19 (permalink)
little Boss man
iguana's Avatar
Drives: 93 VR4
Trader Rating: (10)
Pensoil or GM syncromesh is all i've ever used since i last had my tranny rebuilt which happened shortly after trying other oils and i swear the oils made it worse. Syncromesh and the Mitsubishi friction modifier additive are what our syncros need. any other oil is not going to be right for them and you can never repair any damage to a tranny once it's done unless you have it rebuilt.
Old 07-05-2009, 11:21 PM   #20 (permalink)
DocWalt's Avatar
I have some Pennzoil Syncromesh in the garage, and it's GL5. I would have used that, it's a lot cheaper, but I can't find any GL4.
I'll definitely look into the Mitsu Friction Modifier. I know Evos call for similar stuff, but theirs is pretty expensive.
