Old 04-24-2007, 03:54 PM   #11 (permalink)
|RLII Photography|
VR4Rob's Avatar
Drives: 94 VR-4 - 05 LeggyGT
Trader Rating: (13)
VR4Rob is an unknown quantity at this point
Default Re: Car is finally running, after a year being down!
Originally Posted by SkortchGT
VR4 Rob: A VR4 has been my dream car since I was 10. I'm sticking with it for a very very very long time.
I can definitely relate. My car is paid for so I'm not going anywhere for a loooooong time. I tell people "I've owned my car for 3 years, going on 300"
1994 Mariana Blue Pearl Mitsubishi 3000GT VR-4
DR-650s and supporting, PST CFDS, Volk GT-Cs, among other things
Feb. 06 3SI ROTM - Best AWD BRG 07 - 3rd Place 2G 07 3/S National Gathering - People's Choice BRG 08
2005 White Pearl Subaru Legacy GT Lmt. Wagon 5MT - TommyKaira shoes
(Hers) 1992 Panama Green Pearl Mitsubishi 3000GT VR-4
VR4Rob is offline   Reply With Quote
Old 04-24-2007, 03:55 PM   #12 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (13)
SkortchGT Level 1SkortchGT Level 1
Originally Posted by lawdogg
Did you log timing too? I'm just curious to see what all's going on in there.
As your IDCs increase as you turn up the boost, your ECU is going to retard the timing. I'm curious to see where timing starts to take power away, if at all - and what the magic SAFC settings turn out to be.
It's only going to retard if I get knock. I don't remember off the top of my head what timing was, however I do remember it was fine, i wasn't loosing power and the ECU wasn't pulling any timing.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, cat back & CFDS, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, PST 1pc CFDS, Borla Catback, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, engine dress up kit, Bigtyla ground wire kit, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset.
--Waiting for me to install: ARC2 w/ 92mm MAS
--Daily Driver: 2000 Malibu, 6cyl, auto
SkortchGT is offline   Reply With Quote
Old 04-24-2007, 04:01 PM   #13 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Don't mean to throw this thread off the tracks - sorry! but I was under the impression that the ECU will base timing on IDCs. The lower the IDC, the more timing you'll get. The higher the IDC, the less timing you'll get. And then timing pulled due to knock is a completely separate issue. That's why, I thought, people running huge injectors on low boost with no timing control knock in the first place - wayy too advanced timing from the low IDCs. But it's not like 550's are too big - they're perfect for your power - so it's probably a mute point. Just curious, that's all!
R.I.P.
Old 04-24-2007, 04:12 PM   #14 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Trader Rating: (13)
Hmm, i didn't know that about IDCs. Where did you hear that from? All I know is I wasn't getting any knock so it's all good
Old 04-24-2007, 04:19 PM   #15 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
Tech: My take on injectors vs. timing control vs. HP with the stock ECU
Old 04-24-2007, 04:33 PM   #16 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Trader Rating: (13)
Oh yea i remember that thread. I'm not to worried about it.
Old 04-24-2007, 04:34 PM   #17 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
Sweet.
Go break 400awhp, jackass.
Old 04-24-2007, 05:05 PM   #18 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Trader Rating: (13)
Sweet.
Will do
Old 04-24-2007, 05:25 PM   #19 (permalink)
Supporting Vendor
Maximal's Avatar
Drives: '91 Stealth "ES"
Trader Rating: (201)
Maximal Level 1Maximal Level 1Maximal Level 1
Glad you got it up and running again. Looking forward to our rematch in a couple weeks.
Terry
1991 Dodge Stealth ES - 12.65 @ 112.71 - Not Exactly Stock
Maximal Performance
Maximal Performance Facebook
Maximal is offline   Reply With Quote
Old 04-24-2007, 05:43 PM   #20 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Trader Rating: (13)
Terry
Couple of weeks?? Try next Thursday!!
You're driving down with us this year right?
I seriously think it will be a really good race this year.
