Old 04-24-2007, 02:11 PM   #1 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (13)
SkortchGT Level 1SkortchGT Level 1
Default Car is finally running, after a year being down!
Well as most if you know, my car died last year on the way back form ECG06. A valve lock popped off one of my valves which caused a roller rocker to come loose and a valve to hit a piston. After just turning over 160k miles on the way down to ECG06, I decided it was time to re-build almost the entire car. I did this in my driveway, as my 2 car garage has to much stuff in it to fit another car in. Before you read all the below items, keep in mind I plan on keeping this car until I die or become so old I am no longer able to push in a clutch, which is why I replaced everything I did. I also wanted a reliable street car with good power, nothing crazy. I'm going to list everything that I replaced since April of 2006, since the car only ran for about the month of April06 into ECG06, then died. I bought this car on March 8th, 2003. I had an SL before it.
NEW parts (not used or rebuilt)
-New Gaskets, Seals, etc......
-New Short block
-New oil pump
-New oil filter housing
-New oil cooler lines
-New water pump
-New pulleys (All of them except the actual A/C compressor pulley)
-New timing covers
-New belts
-New battery wiring harness (positive & negative cables)
-New Exhaust manifolds
-New Clutch Master Cylinder
-New Clutch Slave Cylinder
-New Brake Master Cylinder
-New Clutch fork
-New Fulcrum ball
-New Throwout bearing
-New 2nd gen Rotors all around
-New Brake Pads all around
-New 2nd Gen Calipers all around
-New hoses
-New Radiator
-New Coolant temp sensors (all of them)
-New Thermostat
-New Oil pressure low level sensor
-New Knock sensor
-New Oil pan
-New axles (front)
-New wheel bearings (front & rear)
-New transfer case input spool
-New control arms (front)
-New Thottle body (includes new FIAV, IAC & TPS)
-New Sparkplugs (NGK BCP7ES)
-New 3rd Gen Lifters
Rebuilt Items
-DR Stage I Heads (pretty much just like stock, just a valve job)
-Rebuilt Power Steering Rack
-Rebuilt Tranny by Northbend Tech (shifts like butter, includes new syncros, seals, new cryotreated OS, cryotreated shift forks & rails)
-Rebuilt Alternator
-Rebuilt Starter
Mods (New)
-New RPS Flywheel
-New RPS Streetmax clutch
-New Ebay Downpipe (really good quality for cheap, you should get one)
-New PTE 550cc injectors
-New 3SX clutch booster delete kit
-New Autometer C2 gauges (boost, EGT, oil pressure, water temp)
-New AEM wideband
-New Greddy Profec Spec-S Boost Controller
-New Solid Shifter Bushings
-New Engine dress-up kit
-New Maximal performance adjustable control arms & solid mounts
-New TEIN FLEX coil over suspension
-New IPO Hotwire kit
-New AEM FPR
-New 3SX Fuelrail loop
-New Underhood FP Gauge
Other new & pre-existing & Misc mods/parts
-TD04L 13gs
-Apexi SAFC
-Apexi SITC
-Walbro FP
-DSM ICs
-3SX SS braided clutch & brake lines
-Pocketlogger
-Vac delete
-Maximal performance powder coated upper & lower intake malifolds, fuel rails, thermostat housing, valve covers.
-5Zigen 18x8.5 FN01RCs (bronze, +30 offset)
-PS Pump replaced with a used one (although this used one is making noise now)
-New coils and PTU about 2 years ago
-MSD spark plug wires
-Ground wire kit
-Borla Catback
-PST 1pc CFDS
-ARC2 w/ big mas
I'm probably forgetting some things, but you get the idea. There are still 4 things I REALLY want to get which are a 1 pc CFDS, cat back, a paint job, and new interior leather and foam, however those will have to wait. I am extremely happy with this car, and it will be alot of fun. I dynoeed 364awhp so far at 16 psi with a very conservative tune (rich) and no knock. I'll try and post some pictures this weekend after she is clean & ready for ECG. She's really dirty right now, especially the engine bay.
Currently I have a bad speed sensor that is causing my ABS light to come on, and my A/C compressor decided to stop working. It's always something, lol.
There are many people to thank for all of ther help, but mostly I would like to thank Hans (GZP), Greg (monochrome), Aaron (Good2go), and Jason (JR4) for all of their help and advice.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, cat back & CFDS, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, PST 1pc CFDS, Borla Catback, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, engine dress up kit, Bigtyla ground wire kit, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset.
--Waiting for me to install: ARC2 w/ 92mm MAS
--Daily Driver: 2000 Malibu, 6cyl, auto
SkortchGT is offline   Reply With Quote
Old 04-24-2007, 02:16 PM   #2 (permalink)
never a dull moment
DCIV's Avatar
Drives: 93vr4 & 92vr4
Trader Rating: (13)
DCIV Level 1DCIV Level 1
Default Re: Car is finally running, after a year being down!
damn, congrads. Looks like you have basicly a new car.
Coop
To many mods to list.
Old 04-24-2007, 02:31 PM   #3 (permalink)
BAWC: VP Sarcasm
CursedFish's Avatar
Drives: '93 VR-4
Trader Rating: (6)
CursedFish is an unknown quantity at this point
or too short ...
- '93 VR-4: RobBeck 13Ts, Emanage, etc
- '08 350Z Nismo: "Stock" for now.
CursedFish is offline   Reply With Quote
Old 04-24-2007, 03:20 PM   #4 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Trader Rating: (13)
Originally Posted by Novot
or too short ...
Lol, i'll let you have that one for cleverness.
Old 04-24-2007, 03:26 PM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Stock fuel pump dude? I'm guessing either I missed it on the list or you just forgot to list it.
Also, you sticking with the OEM FPR? What kind of IDC's will you be looking at DD'ing it? Just wondering how the timing&boost are gonna interract with 550's and an SAFC if you're only gonna DD ~400awhp at stock fuel pressure.
R.I.P.
Old 04-24-2007, 03:36 PM   #6 (permalink)
|RLII Photography|
VR4Rob's Avatar
Drives: 94 VR-4 - 05 LeggyGT
Trader Rating: (13)
VR4Rob is an unknown quantity at this point
Impressive list of new stuff! Also it's good to hear people with the "I'm stickin with it until they put me in the ground" attitude
1994 Mariana Blue Pearl Mitsubishi 3000GT VR-4
DR-650s and supporting, PST CFDS, Volk GT-Cs, among other things
Feb. 06 3SI ROTM - Best AWD BRG 07 - 3rd Place 2G 07 3/S National Gathering - People's Choice BRG 08
2005 White Pearl Subaru Legacy GT Lmt. Wagon 5MT - TommyKaira shoes
(Hers) 1992 Panama Green Pearl Mitsubishi 3000GT VR-4
VR4Rob is offline   Reply With Quote
Old 04-24-2007, 03:38 PM   #7 (permalink)
BAWC: VP Sarcasm
CursedFish's Avatar
Drives: '93 VR-4
Trader Rating: (6)
lol, thanks man. I'm honestly happy for you - that was probably the shittiest thing that could've happened to us on the way home. You'll have to take me for a ride, well, one day when I actually go out to PA on a Friday night haha
Old 04-24-2007, 03:41 PM   #8 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Trader Rating: (13)
Ryan: I have a hot-wired Walbro pump. Yes, still the stock FPR, thats new too lol. My IDC's were 80% at 364AWHP with a rich tune & no knock at 16psi.
VR4 Rob: A VR4 has been my dream car since I was 10. I'm sticking with it for a very very very long time.
Old 04-24-2007, 03:53 PM   #9 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
Did you log timing too? I'm just curious to see what all's going on in there.
As your IDCs increase as you turn up the boost, your ECU is going to retard the timing. I'm curious to see where timing starts to take power away, if at all - and what the magic SAFC settings turn out to be.
Old 04-24-2007, 03:54 PM   #10 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Trader Rating: (13)
Seriously, you need to come out more often. Starters was fun though. You should come out this weekend.
