Old 05-10-2008, 06:34 PM   #1 (permalink)
Trader Rating: (7)
aberabee is an unknown quantity at this point
Default buzzing when down shifting to 1st
When i downshift into 1st gear it buzzes/grinds and wont go in. Think syncros?
I have no prob shifting into it when the car is stopped
1991 VR4
87k
BONE STOCK
aberabee is offline   Reply With Quote
Old 05-10-2008, 09:36 PM   #2 (permalink)
jackstransmissions.com
JackM is an unknown quantity at this point
Default Re: buzzing when down shifting to 1st
Yep, the lining on the rings is probably worn completely out. When at idle the ring doesn't have to work very hard to stop the input shaft and clutch disk. When downshifting, it has to spin them up to RPM, so the rings have to work a lot harder. If they are weak, they will grind at that time.
Jack
www.jackstransmissions.com EVO VIII, DSM, 3S tranny rebuilding.
JackM is online now   Reply With Quote
