Old 04-05-2008, 02:11 PM   #1 (permalink)
Wheels In Hand...
grtn316's Avatar
Drives: 95 TT
Trader Rating: (11)
grtn316 Level 1grtn316 Level 1
Default Bearing Sleeve - Intermediate Shaft
I was looking at the manual an it said to heat it up to 230ish degrees before installing. Will it need to still be pressed on or will it slide on? Also, if it needs to be pressed on, does anyone have a suggestion on what tool to use along with my press to get it on? I'm considering getting the mistu part but wanted to check here first.
Personal Best:
1995 Stealth TT - 11/17/2006 - 1.759 60' / 11.978 @ 116.08 MPH - UNDER CONSTRUCTION
Building the 19T record!
grtn316 is offline   Reply With Quote
Old 04-05-2008, 02:46 PM   #2 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
Trader Rating: (6)
RealMcCoy Level 1RealMcCoy Level 1
Default Re: Bearing Sleeve - Intermediate Shaft
I have an old deep fryer that I use to heat parts like that up to 350deg. I seldom have to press anything on when that is done.. If I'm pressing on a new bearing, I often use the inner race from the old bearing as an impromptu driver..
Because One broken Stealth just wasn't enough... I made twins..
RealMcCoy is offline   Reply With Quote
Old 04-14-2008, 12:29 PM   #3 (permalink)
I'm a dude.
Toni's Avatar
Drives: 13geed 92 rt tt
Trader Rating: (44)
Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7
I used a heat gun and heated my sleeves up to 130F and they slid right on but you have to do it quick cause they cool pretty quickly. If you need to press it on then a steel pipe with cap works nicely to press it. The dia won't be perfect so use the press to bend the pipe end into an oval until it works.
-Antoni
My site, tons of pics/faqs(Added LED faq!)
DIY LED Kit for Sale
Speed Factor 2nd place best interior modified
'92 pearl white stealth Rt TT: Mitsu 13gs, Black Racing pro n1s, LC1/LM1 logging (rpm, tps, map, dual egt), RPS street disc/fly,255 Walbro, high flow filter, -6an from tank, AFPR with RobBeck adapter, Apexi el2 5 gauges, maximalperformance tcase bracket/adjustable arms/powdercoating, Tein S-Tech, Greddy Type S bov, Custom exhaust, poly motor mounts, short shifter, led interior.
'06 ninja 500r
'08 vw rabbit
Toni is offline   Reply With Quote
Old 04-14-2008, 04:06 PM   #4 (permalink)
Bruhaba's Avatar
Drives: 97 VR4
Bruhaba is an unknown quantity at this point
go to autozone and buy an exhaust coupler that will work...I keep everything I've ever used to press something on near my press so usually I can cobble up a couple things...exhaust pipes and old trans parts usually fit the bill. Don't heat the sleeve too much when installing as it will temper back if you go over ~325-350F. Usually, when heated, they slide most of the way on but if you are not quick about it and get it seated, you will need a press.
1997 Black 3000GT VR4-7 autophysics filter, Accel plug wires, Borla Exhaust, MBC, boost + A/f gauge, GREDDY BOV, S-AFC(450's in garage), rewired fuel pump, SBC clutch, Stainless Dpipe, gutted cats
1997 VFR750F
2004 KTM625SMC
2003 CRF450R .........I like momocycles
Bruhaba is offline   Reply With Quote
