Old 12-14-2007, 03:49 PM   #21 (permalink)
keithmac is an unknown quantity at this point
Default Re: Bad Thud in drivetrain, videos.......help
Cheers, a summer job then!.
JDM GTO TT, Emanage Blue - 450`s
Hotwired Walbro - Gutted MAS - K&N
Blitz SSBC - Aquamist Water Injection
keithmac is offline   Reply With Quote
Old 03-30-2008, 07:29 PM   #22 (permalink)
Drives: '91 VR4
Trader Rating: (13)
Originally Posted by Phattlard View Post
resizing the dowel pins or welding it, the tranny needs to come out, pretty sure. I admit its a bitch. But after doing it about 5 times on a 3000gt, it gets easy.
The dowel pins can be changed with the tranny still in the car. I just finished getting mine back together. The thud is gone, but I still have a bit of a clunk. I am assuming this clunk is coming from inside the transaxle (ie. worn VCU discs) or perhaps the driver/tranny mounts. I'm going to try changing these mounts next as I already have F/R solid mounts.
'91 VR4 - Modlist: DR650R turbos, Snow stage 2D alky kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Dual feed fuel system with Aeromotive FPR & filter, Hotwired Supra pump, ek2mfg plenum spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP downpipe, Vac/EGR delete, Gutted precats and test pipe, Maximal solid mounts, 300m 18 spline output shaft, Centerforce Dual Friction clutch, RPS flywheel, GC coilover conversions with helper springs, Powerslot slotted rotors, Goodridge SS brake lines, Hawk pads (front), Stillen metal matrix pads (rear)
Old 05-20-2008, 08:55 PM   #23 (permalink)
Drives: 93stealth-91vr4
93stealthman is an unknown quantity at this point
you can take up half of this slack by re orienting the planetary dowel pins as they get beat along with the slots in the vcu
93stealthman is offline   Reply With Quote
Old 05-20-2008, 09:26 PM   #24 (permalink)
Livin' the dream
chargerx3's Avatar
Drives: 92 dodge stealth TT
chargerx3 Level 1chargerx3 Level 1
subscribed for the archives...
1967 Dodge Charger (440)... 1969 Dodge Charger SE (383)... 1972 Dodge Charger (400)...
1992 Dodge Stealth R/T TT (Daily Driver) 1992 Dodge Stealth R/T TT
chargerx3 is offline   Reply With Quote
Old 05-21-2008, 07:17 AM   #25 (permalink)
Wrench Pimp
Drives: 93 Base, 91 VR4
Phattlard is an unknown quantity at this point
That is cool you did it with the tranny still in the car. So far I have about 450 miles on my welded dowel pins. The large clunk is defiantley gone, Although I did swtich from a stage 3 clutch to a factory clutch during the process, so idk if the less aggressive clutch also helped absorb some of the shock. idk. But i do still have a mystery clunk that is intermitant(can't spell). Only if I accelerate quickyl or change gears quickly it clunks in the rear. But it makes the same clunk when I go over a bump so im thinking it suspension/bushing related. Its a 91 with original suspension components. But I'm glad I got the initial huge thud gone, it was like a earth quake. When I ever I hit the gas it wou thud, now I can slap the gas pedal without makign it thud like it used to. Now just have to hunt down my body rattles and cluncks lol. Thanx for everyone reading and adding to this thread.
Free Image Hosting at www.ImageShack.us
Phattlard is offline   Reply With Quote
