#81 (permalink) |
Yours sounds a bit like mine. I will get a bit of clunking and jerking while trying to cruise at really low throttle levels, but it is nothing compared to the clunk I get when I go from decel to hard accel. I always chalked up the low throttle clunking and jerking to be related to compressor surge and/or misfires in closed loop (I'm pretty sure I have an exhaust leak on the front bank causing this misfire problem).
'91 VR4 - Rebuild in progress: Mods TBA.
#82 (permalink) |
When you`re cruising the car`s going from slight accel to slight engine breaking (unless you`re on an incline) so this would show up any slack in the drivetrain, from engine breaking to hard acceleration is probably the worste case for any play in the drivetrain. I`m baybying mine until I find out what it is, gently taking acceleration up after engine breaking/ from a stop start does the trick, when its rolling you can give it some grief!.
#83 (permalink) |
I have been having the same problem and I really really hate it. Mine is the worse in 1-2 and gets alittle better from 2-3 and is pretty much gone in 3-4 and never clunks 4-5. Mine comes from the rear end. It is pretty obvious. However it does not clunk going from engine breaking to accelleration which everyone here is saying theirs does. Mine exhibits all other characteristics except that one. I did find that the only way to get it to go away is if you perfectly engage/slip the clutch or you pop the throttle alittle between gears. Anyone else experince this? Is there something we are overlooking? JeffWvr4 replaced freaking EVERYTHING and its still there. Are we over looking something. Could this really be rear end bushings? No one has replaced those yet and if the rear end moved arould alittle could it cause these problems? As you guys know its very fustrating. I would love my car a 100 time more if it didn't do this.
#84 (permalink) |
You really need to get hold of the CD manual, it has a section on stripping, inspecting, setting up the the rear diff. From what IŽve seen you pull the driveshafts and oil seals, take out a circlip on eack side and then wind one side in/ wind one side out to set the clearance between the gears.
There`s a post on here about it too, sure I`ve read a diy tutorial. For mine, I`ve not noticed my clunk as much after I fixed my ecu (caused the car to buck slightly at part throttle), either that or I`ve learnt how to drive around the problem? I`m going to check my free play again when it`s on the ramp for engine and tranny oil change, but won`t get time to pull it apart this year.
JDM GTO TT, Emanage Blue - 450`s Hotwired Walbro - K&N - Blitz SSBC Port Methanol Injection - E85 - 12.4@115 |
#85 (permalink) | |
Certified Car Nut
Jeff W.
Red '92 VR4 215,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy ![]() Big 16G Turbos w/IPS headers and pre-cat eliminators, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS Stage 5 clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PowerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior. |
#87 (permalink) |
Certified Car Nut
Here's some pics. (from JRC's site. Hope you don't mind John.)
The first one shows the 2 brackets near the bottom of the pic. The 2nd one shows the brackets near the top of the pic. The 3rd pic shows the brackets laid out next to the diff. Last edited by JeffWVR4 : 02-27-2008 at 12:56 PM. |
#88 (permalink) |
Just an update for my clunk problems, had the car on a lift to do the clutch and checked the prop shaft carrier bearings, loads of play in them so I believe this is my problem (going to strap them with jubilee clips for the time being). Would have sorted it there and then but it was 3.30am before we got the car finished, started it after a full days work so I`d lost the will to live at that point..
#90 (permalink) |
I grabbed hold of the prop shaft and pulled it up and down near the carriers, there`s a little play even in new bearings but not an inch worth!. I think the rubber mount around the bearing has broken down with old age/ abuse..
| Thread Tools | |
