Old 09-09-2006, 04:18 PM   #31 (permalink)
keithmac is an unknown quantity at this point
Default Re: Backlash in the Transaxle?
Don`t know but I`ve got a similar clunk, can`t see any reason why they machine them to give 2mm of play, it`s boviously going to wear the holes out eventually!
Have you a lot of radial play when you turn the prop shaft with all wheels stationary, I have a fair amount in mine and I`ll be looking into wether it`s from the rear diff or from the front. It`s just going to get worse as every time it clunck something is wearing out somewhere..
keithmac is offline   Reply With Quote
Old 09-09-2006, 09:15 PM   #32 (permalink)
Drives: '91 VR4
Trader Rating: (13)
Now that I have the new VCU there seems to be much less radial play in the propeller shaft. I have yet to take the car out for a spin, so I can't comment on whether or not the new VCU has fixed the clunking.
Declan
'91 VR4 - Modlist: DR650R turbos, Snow stage 2D alky kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Dual feed fuel system with Aeromotive FPR & filter, Hotwired Supra pump, ek2mfg plenum spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP downpipe, Vac/EGR delete, Gutted precats and test pipe, Maximal solid mounts, 300m 18 spline output shaft, Centerforce Dual Friction clutch, RPS flywheel, GC coilover conversions with helper springs, Powerslot slotted rotors, Goodridge SS brake lines, Hawk pads (front), Stillen metal matrix pads (rear)
Old 09-09-2006, 09:32 PM   #33 (permalink)
Drives: with 1g clears
Trader Rating: (20)
brattesani is an unknown quantity at this point
please do soon! i have the clunking from decell to acell and would like to know. =)
brattesani is offline   Reply With Quote
Old 09-11-2006, 06:43 AM   #34 (permalink)
Drives: '91 VR4
Trader Rating: (13)
Bad news. I still have a pretty major clunk. However, its not as bad as the old clunk.
The clunking is greatly improved in 1st, 2nd and 3rd. It used to be most noticecable in 2nd, but now it is almost non-existent. In 4th it starts to get noticeable and in 5th it is just plain disgusting.... what a POS.
Declan
Old 09-11-2006, 10:44 PM   #35 (permalink)
Trader Rating: (20)
check carrier bearings and U-joints in the driveshaft.
Old 09-12-2006, 08:21 AM   #36 (permalink)
KORMEX's Avatar
Trader Rating: (10)
KORMEX is an unknown quantity at this point
Declan
Try to eliminate the engine (crank walk) and motor mounts by doing this :
1.) put the car in 1st then speed up
2. ) press the cluth and put it in neutral
3.) with the car still coasting and the clutch depressed put it in 1st .
Now if you get a clunk , its comming from the transmission back to the differential , If you don't then its from the clutch forward
I hope that helps
Frank
KORMEX is offline   Reply With Quote
Old 09-12-2006, 09:55 AM   #37 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 Level 3JeffWVR4 Level 3JeffWVR4 Level 3JeffWVR4 Level 3
I've had the same problem for years. I've tried and adjusted 2 rear diffs, adjusted shims in the transfer case, replaced the VCU, installed 3 different output shafts, replaced the transfer case input spool, and had the transmission rebuilt and checked for slack. I also installed a 2 pc aluminum driveshaft and a new carrier bearing, and new front halfshafts. Each time I did one of the above, the clunking improved for a few weeks or months, but eventually came back. The biggest improvement was when I replaced the VCU. But now it's worse than ever, so I've resigned to the fact that it's just terminal at this point and have gotten used to it.
Jeff W.
Red '92 VR4 213,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PwerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 09-12-2006, 12:03 PM   #38 (permalink)
Drives: '91 VR4
Trader Rating: (13)
Man, that's depressing. Maybe I should just put my car down and out of its misery...
With that being said, I don't want to give up on it just yet. Are you able to turn your propeller shaft or your output shaft by hand to elicit the backlash? It seems as though you've replaced pretty much every component of your driveline. Where do you think your backlash is coming from?
Declan
Old 09-12-2006, 12:17 PM   #39 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Yes I can. And the thumping and banging seeems to be coming from the rear of the car. It makes noise during both when you get on the throttle and when you let off. Maybe it's time to adjust the rear diff again. Don't mean to hijack this thread, but I'm just letting Dr.Dex know he's not alone.
Old 09-12-2006, 01:44 PM   #40 (permalink)
The New Super Pimp
maddog's Avatar
Drives: FASTER THAN VIPERS
Trader Rating: (7)
maddog Level 1maddog Level 1
i know its a pain but have you tried replacing all of the rear suspension bushings including the ones that hold the rear diff
when i was rwd i would get all sorts of noise from the rearend becasue all of the bushings were done.
the fact that it comes back irks me thou
93 Sandstone VR4
11.66 @ 117.48mph with Maddog Performance Engineering 13T's
This weeks specials:
CUSTOM RUBBER INTERCOOLER PIPING AT 50% OFF!!!
28 HOUR ENGINE REBUILD ONLY $700
maddog is offline   Reply With Quote
