#141 (permalink) |
Update: Got the transaxle back together (with the custom planetary dowel pins) and I installed some solid F/R motor mounts. The clunk has improved to some degree. It used to be a loud thud that would shake the car and you could feel it in your seat. Now it is less noticeable and I don't think it would bother me if I wasn't so sensitized to the problem. With that being said, I don't know if I'd recommend it as a worthwhile modification. It does take up some extra slack, however, I still have some slop in my transaxle and I think the only way to fix it is to buy a new one.
#142 (permalink) |
i had a problem like yours i replaced my motor with poly mount that i custom made. the front and back mounts cost me 50 and i can make one more.. i ordered a tube i belive it is 3.25 i remove the old rubber mounts and insert i had to light press it in because the stock mount are 3" and then i cut the rest off and drill the center and insert the round metal part after all that i don;t have no no clunk noise at all and i lunch my car all the time...i hope this help some one that don;t want to spend lots of money for the mount
1992 3000GT VR-4 Figi Blue 4-bolt main • 15g turbos • 550cc injectors • hotwired walbro 255 • front mount intercooler • spec stage 3 • stillen downpipe • 3" custom catback • ngk bcp7es .029 • intrax springs • apexi safc-2 • mbc • etc... 1/4 mile: 12.4 @ NG06 dyno: 320awhp @ 11psi before FMIC ![]() |
#143 (permalink) |
Breaks all but Xfer case
YOU DONT WANT TO KNOW WHAT A NEW PLANETARY GEARSET COSTS! I FRAGGED MINE AND ENDED UP BUYING A USED ONE.
HEre are some pics and illistrations of teh center diff, vcu and my F-up Top This!!!
![]() Black 93 VR-4 12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage 11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's ??.?? @ ??? w/ 14b's (26psi) ??.?? @ ??? w/ 14b's (24psi) + NOS (35shot) Show and Go: 98 rear garnish, EGR block off plates, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, 720cc's, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, 50HP NX Wet Kit, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Prosport gauges, Boomslang harness, Corbeau LG1's, Yogurt's 4" cat-back, dual feed fuel system |
#145 (permalink) |
I`ve got solids all round and have the clunk, having said that full solids are a worth while upgrade.
Did you take any pics while you were in the gearbox?.
JDM GTO TT, Emanage Blue - 450`s Hotwired Walbro - Gutted MAS - K&N Blitz SSBC - Aquamist Water Injection |
#147 (permalink) |
Tranny end cover off:
http://www.3si.org/forum/attachment....1&d=1207606223 DSC00087.JPG Bar in the end of the intermediate shaft. Used to pry the gears away so you can get the VCU/planetary assembly out: http://www.3si.org/forum/attachment....1&d=1207606223 DSC00088.JPG Slide hammer, used to pull off the end cover (much easier than using blocks of wood and a hammer): http://www.3si.org/forum/attachment....1&d=1207606223 DSC00089.JPG |
#148 (permalink) |
Bolts/springs/ball bearings that need to be removed to get the end cover off:
http://www.3si.org/forum/attachment....1&d=1207606452 DSC00090.JPG VCU with Sun gear installed: http://www.3si.org/forum/attachment....1&d=1207606529 DSC00094.JPG New custom "shouldered" VCU pin (left) and OEM pin (right): http://www.3si.org/forum/attachment....1&d=1207606529 DSC00096.JPG Last edited by DoctorDex : 04-20-2008 at 02:10 PM. |
#149 (permalink) |
Pics of the shouldered pins installed in the planetary gear set:
http://www.3si.org/forum/attachment....1&d=1207606755 DSC00100.JPG VCU - sun gear - planetary gear set unit fitted together: http://www.3si.org/forum/attachment....1&d=1207606755 DSC00103.JPG Broken intermediate shaft oil guide (don't do this). I had a nightmare of a time trying to find a new/used one. It ended up costing me an arm and a leg: http://www.3si.org/forum/attachment....1&d=1207606755 DSC00107.JPG |
#150 (permalink) |
Like I said before, I can't say for sure if this was a worthwhile upgrade. I still do have a clunk and I can't say for sure if it was the motor mounts that helped or if it was the new pins. What I can say for sure is that it has taken up all slop between the planetary and VCU, which is how this part should have been designed in the first place.
If someone wanted to make their own, they'd need about 10 inches of 5/8'ths 4340 HTSR steel and they'd have to approach a machine shop with their parts in hand. Last edited by DoctorDex : 04-14-2008 at 04:53 PM. |
