Old 08-13-2008, 09:37 PM   #1 (permalink)
Verified
jtvr4's Avatar
Drives: you insane
Trader Rating: (13)
jtvr4 Level 7jtvr4 Level 7jtvr4 Level 7jtvr4 Level 7jtvr4 Level 7jtvr4 Level 7jtvr4 Level 7jtvr4 Level 7jtvr4 Level 7jtvr4 Level 7jtvr4 Level 7
Default aws boot is torn. Replacement parts for it?
Anyone know the part number for the protective boot for the aws system? Im needing the rear passenger side, if that makes any difference. Mine is torn and leaking.
IPS TD05 E16G
AEM EMS
EVERYTHING ELSE. Seriously. 506.24awhp 511.83awtq 3300 pounds. Soon to be over 650awhp. I hope!
jtvr4 is offline   Reply With Quote
Old 08-13-2008, 10:17 PM   #2 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
Default Re: aws boot is torn. Replacement parts for it?
the boot isn't leaking, the racks seals are. All the boot does is keep dirt out. I have a rack that wasn't leaking I am about to throw away if you want it.
Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts, EK2 ExoCage
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcapsm Scanmaster 3
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
cbehnken is offline   Reply With Quote
Old 08-13-2008, 11:08 PM   #3 (permalink)
Verified
jtvr4's Avatar
Drives: you insane
Trader Rating: (13)
Well, that will work. ill PM you my shipping info.
Old 08-14-2008, 06:21 PM   #4 (permalink)
Forest Gump
cbehnken's Avatar
it is all pretty rusty though, have you looked at what you;ll have to do to replace it? I think you'll have to drop the subframe like I did which is quite a bit of work (almost like dropping the tranny)
Old 08-15-2008, 01:47 AM   #5 (permalink)
Verified
jtvr4's Avatar
Drives: you insane
Trader Rating: (13)
I havent looked into it, the oil is coming out of the hole in the right side boot. Dropping the subframe is going to suck, but ive got to fix the leak. lol
Old 08-15-2008, 02:59 AM   #6 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7
he is right about the seal. Its not an easy fix
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit.
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
Ondontii is offline   Reply With Quote
Old 08-15-2008, 03:00 AM   #7 (permalink)
Verified
jtvr4's Avatar
Drives: you insane
Trader Rating: (13)
Anyone have the part number for the rear steering rack? All I can find is the front rack, and I dont have caps.
Old 08-15-2008, 11:15 AM   #8 (permalink)
Forest Gump
cbehnken's Avatar
Let me get you some pictures of mine. It isn't leaking, but looks kinda rough, it just needs to be cleaned up. I'd probably need something like $130 shipped for it. Shipping is probably going to be about $30.00 and the part is $600 new.
I didn't realize anyone would have a use for this and I'm glad I didn't toss it.
Edit: you may SERIOUSLY try to get a rebuild kit if they make one. It isn't like mine came out of a brand new car or anything. Eventually it will leak too.
Old 08-15-2008, 01:17 PM   #9 (permalink)
Verified
jtvr4's Avatar
Drives: you insane
Trader Rating: (13)
Thanks for the offer, im trying to find a rebuilt unit. Ive only found one at parts.com, but it doesnt show me the part number They wanted $434 for it.
