AWD Transmission seals 93 VR4 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 02-15-2011, 04:53 PM   #1 (permalink)
OneRedVr4's Avatar
Drives: '93 3000GT VR-4
OneRedVr4 is an unknown quantity at this point
Feedback Score: 3 reviews
Default AWD Transmission seals 93 VR4
Alright well it seems the seals on the transmission are leaking. I could see after removing the T-case that the input shaft to the T-case seal on the trans was leaking is this common?
I think these are the only seals on the transmission to be replaced from the outside, please correct me if I am wrong or I word them incorrectly.
Driver side output shaft seal ( axle )
Passenger side output shaft seal ( axle )
T-case input shaft seal
Transmission input shaft seal ( the main spline the cltuch rides on )
Where can I get these from? Any local parts stores? I don't really want to go on 3sx.com right now may take awhile to get.. if I do have to I guess I do.
Thanks everyone!! Any other info would be great.
-Stock '93 VR4- 89,000 Miles-
OneRedVr4 is offline   Reply With Quote Quick reply to this message
Old 02-15-2011, 05:20 PM   #2 (permalink)
striker3's Avatar
Drives: 93 VR4
striker3 Level 1striker3 Level 1striker3 Level 1
Feedback Score: 4 reviews
Default Re: AWD Transmission seals 93 VR4
cherry hill might be the fastest and cheapest.
btw, I thought you had sold the VR4 and were working on the S2000, how is that coming along?
striker3 is offline   Reply With Quote Quick reply to this message
Old 02-15-2011, 06:04 PM   #3 (permalink)
OneRedVr4's Avatar
I have the S2000. Coming great. This car is my old one the guy just want that leak taken care of.
Old 02-15-2011, 08:04 PM   #4 (permalink)
phantomrt's Avatar
Drives: fast
phantomrt is an unknown quantity at this point
Feedback Score: 0 reviews
That transmission output shaft seal (the shaft sticking out of the transmission to go into the transfer case) cannot be replaced without disassembling the transmission. It is a serious F*** YOU when that thing starts leaking.
Its an 18+ year old seal probably. There aren't a lot out there in any application that is still sealing after this many years.
92 Stealth R/T TT 75k (sold)
92 Daytona ES 2.5 Turbo / A523 104k
92 Lebaron GTC Conv. 2.5 Turbo / A568 173k
91 Daytona ES 3.0 V-6 / A543 193k
93 Geo Metro 1.0/5spd 204k *OPEC bitch-slapper* But only after it burned up 2 sets of exhaust valves!
phantomrt is offline   Reply With Quote Quick reply to this message
Old 02-16-2011, 05:14 PM   #5 (permalink)
OneRedVr4's Avatar
AHHH!!!! Are you serious!!? ? I am not happy now, iv never taken apart a transmission before
Old 02-16-2011, 07:55 PM   #6 (permalink)
OneRedVr4's Avatar
So. To put these transmissions back together what is the best sealant? I have the entire transmission apart now. I will post pictures a little later too.
Old 02-16-2011, 09:13 PM   #7 (permalink)
phantomrt's Avatar
Drives: fast
Wow. You're fast. I can't say what the BEST sealant is, and there is some controversy on issues like it HAS to be anaerobic sealer or whatever, but in my experience, between two machined surfaces like this, I've never had to use anything other than a thin bead of RTV of your choice. I use the black stuff in the aerosol cans since it is just so much easier to dispense and literally lasts me years and the stuff in the tube always dries out on me long before I get to use all of it.
I've sealed up at LEAST 6 manual transmissions over the years using whatever RTV I had sitting around and not once I've ever had an issue. And it lasts, too. The 543 trans in my Daytona was sealed up 10 years ago with Permatex Ultra Copper and it has zero issues. I've used the blue stuff, the orange stuff, the black stuff and never, ever an issue yet.
Old 02-16-2011, 09:19 PM   #8 (permalink)
phantomrt's Avatar
Drives: fast
But anyways, isn't that seal just the biggest **** *** that you have ever seen?
Old 02-16-2011, 09:32 PM   #9 (permalink)
striker3's Avatar
Drives: 93 VR4
yeah, its supposed to be an anaerobic sealant. however what i use is a tiny bead (maybe 2mm) of black RTV and then make sure that it sits at least 24 hours before its moved or fluids are put in it to make sure the sealant has time to cure properly. never had a trans leak doing it that way.
Old 02-16-2011, 10:00 PM   #10 (permalink)
OneRedVr4's Avatar
It was not hard to take apart. I have to bring the one part of the case where the seals I am replacing to a shop. There is a pressed in bearing and that seal is behind it. I don't know if I can take out the nose cone thing that protrudes out. I took a Snap ring off it before I took the trans apart. it's where the output shaft comes out of. Anyone know?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
