Old 05-09-2008, 03:41 PM   #1 (permalink)
kyskater's Avatar
Drives: 1994 stealth base
kyskater is an unknown quantity at this point
Default auto awd to fwd conversion
what do i do to convert this and if it involves the vcu where is it located and what is the steps to remove this and where to weld it. i will later find a good vcu and install it if i ever descide to do a full awd conversion
Was going to be built and boosted... nissans are addicting it is for sale>Photobucket[/IMG]
kyskater is offline   Reply With Quote
Old 05-10-2008, 12:52 AM   #2 (permalink)
kyskater's Avatar
Default Re: auto awd to fwd conversion
to the top i need help with this i am ordering it soon
Old 05-10-2008, 09:24 PM   #3 (permalink)
kyskater's Avatar
bump i need to know this asap
Old 05-10-2008, 09:29 PM   #4 (permalink)
Isnt this a CAR SITE?
1Forest1's Avatar
1Forest1 Level 31Forest1 Level 31Forest1 Level 31Forest1 Level 3
Explain your title. Auto AWD? Have you dicovered some elusive JDM Automatic Turbo transmission?
1Forest1 is offline   Reply With Quote
Old 05-11-2008, 10:23 AM   #5 (permalink)
kyskater's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...222969210&rd=1
it is out of the gto sr its a n/a tranny
Old 05-11-2008, 10:47 AM   #6 (permalink)
99 SLut
Adollarwodbnice's Avatar
Drives: 99 SL
Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7
That's badass I don't think they made it for turbo gtos though.
Adollarwodbnice is offline   Reply With Quote
Old 05-11-2008, 11:10 AM   #7 (permalink)
Volunteer FireFighter
jpyounis1's Avatar
Drives: 95'3000GT/99'Galant
Trader Rating: (7)
jpyounis1 is an unknown quantity at this point
there were a few VR4's that were auto if i remember reading right. most in japan tho and the awd n/a's that came along with it.
thats cool...very interesting. your going to need the drive shaft and the rear end + axle and diff. from a vr4 at the very least...maybe someone else can chime in
Mods- 4" Intake, Modded Throttle Body, Re-Grind Cam Shafts, Big Tyla's Ground Wire Kit,
Eibach Pro Kit Lowering Springs, NGK Copper Plugs, Accel Thundersport 300+ Red Spark Plug Wires,
6000k HID Kit, 99 Garnish, Prosport Gauges, Evolke 17" Wheels, Hella Optilux Fog's,
Custom Exhaust, Clear Corners
jpyounis1 is offline   Reply With Quote
Old 05-11-2008, 11:49 AM   #8 (permalink)
kyskater's Avatar
yes but does it have a vcu to weld or anything at the moment and where is it for now i will only be using it in fwd configuration
Old 05-11-2008, 01:06 PM   #9 (permalink)
99 SLut
Drives: 99 SL
Eh dunno about that but I know you're gonna need the subframe your car should have the studs sticking outfor it but there's alot of work involved in making fwd to awd.
trans seems really cheap though that's pretty awesome.
EDIT: Check this out very cheap too...
eBay Motors: 3000GT / Stealth Twin Turbo VR4 TT AWD Rear End Comes (item 330235240113 end time May-16-08 19:57:02 PDT)
Old 05-11-2008, 02:26 PM   #10 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7
Wrong, there were no TT autos. There were some test cars that were rumored, but no production ones. Some people have already used this transmission to convert to AWD auto. It is essentially an auto DSM trans with a different bell housing.
He wants to convert this AWD Auto trans to work with just FWD, not convert his FWD to AWD.
To the original poster, what do you have done to you car? Do you have an auto right now? Do you have a TT conversion done (I'm assuming not). If you are not sure if you are gong to convert to AWD then don't buy this trans, just get a FWD trans to start with. If you already have an auto, just repair it.
I have an 18 spline VCU for sale. -375 shipped.
aaronatstate is offline   Reply With Quote
