Old 03-25-2008, 07:15 AM   #1 (permalink)
rippin up lil FWD cars!!
twinturbvr4's Avatar
Drives: 93 3000GT VR-4
Trader Rating: (9)
twinturbvr4 is an unknown quantity at this point
Default Amateur Trans Rebuild
Hey fellas.. can anybody give me a rundown on what kind of equipment/tools are necessary to actually just get the trans apart? Not sure what I could be getting myself into, but I'd rather NOT BUY tranny #4, but possibly bring in one for repair and do it on the side... and oh yea.. NO EXPERIENCE lol.. did a swap! but thats about it..
thanks!
16Ts, ATR downpipe with high-flow cat, MBC (in cockpit), Kormex'd, 450cc's, Walbro Pump, MAFT GenII, 3.5" GM MAF Blow-through, HKS SSQV '07, EGR Blockoffs.
Coming soon: 680cc injectors?
twinturbvr4 is offline   Reply With Quote
Old 03-25-2008, 07:17 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (58)
Default Re: Amateur Trans Rebuild
10mm socket, 12mm socket, 14mm socket.
Gear puller, 10 ton press.
Vice.
Flathead screwdriver.
I think that's it .. haven't done one in a couple years.
2002 WJ -- 1994 VR-4 -- 1993 ZJ --Canon Rebel XTi
Old 03-25-2008, 07:32 AM   #3 (permalink)
Trader Rating: (9)
Any specifics on the gear puller? where can I get one? I think I would be able to find a press.. is the press needed to get the casing open? or just for putting back together..
thanks.. and yea.. it sucks that I'm looking into my 4th trans but thanks for the info before about the swap.. wasnt too bad
Old 03-25-2008, 07:42 AM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (58)
Just a normal gear puller from autozone or whatever ... don't need anything expensive.
You'll need a hammer too do get your cases apart. Take all the bolts out and take it apart. When you pull your sliders watch out for the balls / springs .. they are tiny and when lost they will never be found.
Old 03-25-2008, 09:48 AM   #5 (permalink)
Sure you don't, Scotty.
93RTTurbo's Avatar
Trader Rating: (18)
93RTTurbo Level 593RTTurbo Level 593RTTurbo Level 593RTTurbo Level 593RTTurbo Level 593RTTurbo Level 5
..."amateur transmission rebuild"...isn't that a contradiction in terms?
Good luck with that! I hope it ends up being more successful than "amateur parachute packing"...or "amateur snake milking"...or "amateur particle accelerator contruction"...
On your knees, wretch!
Originally Posted by Pavone
I don't just want the sex, if I just wanted the sex, I'd offer the sex.
93RTTurbo is offline   Reply With Quote
Old 03-25-2008, 10:55 AM   #6 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 3Colt45_GTO Level 3Colt45_GTO Level 3Colt45_GTO Level 3
its a pain but its doable, don't smack at the casing with a hammer or try to press the casing together you'll end up with new guts and fubar casing. it should all slide back together without effort, its just parting the old gaskets thats all.
oh if it seems like the bellhousing wont part from the case its possible you left a bolt in
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Old 03-25-2008, 05:27 PM   #7 (permalink)
phantomrt's Avatar
Drives: fast
phantomrt is an unknown quantity at this point
Its not my first choice of transmission to learn on, but all manual transmissions are basically the same.
Not much for special tools needed. Its just a lot of parts and taking several pictures with a digital camera along the way to help with re-assembly will be beneficial. There are some write-ups around the internet as well as the service manual which do a great job of showing what you're getting into. Its not that difficult, but can result in disaster when you forget what part goes where and how and why.
92 Stealth R/T TT 70k
92 Daytona ES 2.5 Turbo / A523 103k
92 Lebaron GTC Conv. 2.5 Turbo / A568 153k
91 Daytona ES 3.0 V-6 / A543 190k
95 Grand Prix SE 3.1 / 4T60E 202k
phantomrt is offline   Reply With Quote
Old 03-26-2008, 02:02 PM   #8 (permalink)
Drives: '91 VR4
Trader Rating: (13)
A slide hammer does wonders to take the case a part.
'91 VR4 - Modlist: DR650R turbos, Snow stage 2D alky kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Dual feed fuel system with Aeromotive FPR & filter, Hotwired Supra pump, ek2mfg plenum spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP downpipe, Vac/EGR delete, Gutted precats and test pipe, Maximal solid mounts, 300m 18 spline output shaft, Centerforce Dual Friction clutch, RPS flywheel, GC coilover conversions with helper springs, Powerslot slotted rotors, Goodridge SS brake lines, Hawk pads (front), Stillen metal matrix pads (rear)
