Old 06-07-2008, 06:32 PM   #21 (permalink)
Hubbell86's Avatar
Drives: 1992 Stealth R/T TT
Trader Rating: (7)
Hubbell86 Level 1Hubbell86 Level 1
Default Re: All Whel Steering model years?
lol why would that put all wheel steering to help for parking... its for handling man. Its only activated at 30mph+ is what i heard.
1992 Dodge Stealth R/T TT (41,700 original miles!)
Mods: 3sx TP, 3sx DP, Emanage Blue, 15gs installed, Running 20 Psi (Getting Tuned by Predator Performance!) Walbro 255, 450cc injectors, Meth inj.
1992 Dodge Stealth R/T NA
Mods: 3sx DP, 3sx TP, and Ebay Intake
Hubbell86 is offline   Reply With Quote
Old 06-07-2008, 07:13 PM   #22 (permalink)
Paid Member
jba3's Avatar
Drives: mitsu's stock up ^_^
Trader Rating: (15)
jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7
Originally Posted by VR4Exige View Post
jw, but is the aws suppose to activate, but in the opposite direction, when going at low speed to help with parking? my friend told me it is suppose to but the 97 vr4 i have isnt doing so.
Definitely not. It's designed for higher speed, and track usage.
If my posts have been helpful or informative, or even entertaining, rep is appreciated.
Old 06-07-2008, 09:59 PM   #23 (permalink)
rjt86's Avatar
Drives: 99 3rd gen GTO
rjt86 is an unknown quantity at this point
They didn't discontinue it in the JDM models, as i got a 99 GTO with 4ws/aws, however the MR's dropped this feature
rjt86 is offline   Reply With Quote
Old 06-08-2008, 02:51 AM   #24 (permalink)
1992 Stealth R/T
jbavousett's Avatar
Drives: N/A Beauty Queen
jbavousett Level 2jbavousett Level 2jbavousett Level 2
Originally Posted by Blue94VR4 View Post
I think none of the Stealth have it. Neither ECS. That's why it was cheaper.
Speaking of which, do anyone have a link for a AWS delete? I think I want to take mine out.
BTW, it's easy to tell if you have AWS or not. Does your car have rear steering rack? You cannot miss it, it's big
Wrong - My '92 Stealth RT (N/A) has ECS.
jbavousett is offline   Reply With Quote
Old 06-08-2008, 02:53 AM   #25 (permalink)
-Turb
Turbs3000's Avatar
Drives: '94 3000GT/'91 VR4
Turbs3000 is an unknown quantity at this point
Our cars wern't set up to have it help with parking and low speeds but other cars have been. A few years ago their was a truck that had it, helped with turn radius and parking but drivers who owned the truck kept hitting other cars in parking lots so they got rid of it.
Turbs3000 is offline   Reply With Quote
Old 06-08-2008, 04:02 PM   #26 (permalink)
July 2003
Drives: '94 VR-4
Trader Rating: (16)
bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7
A few things about AWS.
Yes, it only activates at high speed.
Yes, it was originally intended mostly for smooth highway lane change maneuvers.
Yes, the maximum change for the rear wheels is only 1.5 degrees.
Yes, it is same phase aws so the rear wheels turn in the same direction as the fronts.
Ours is hydraulic, not electronic. There is no significant delay. Basically, there is a pump/valve that basically controls when the rear wheels can turn based on the speed the car is going (can't remember where it's attached to the rear drivetrain). When the pump is turning fast enough, hydraulic pressure from the same circuit that the front power steering is connected to will turn the rear wheels will turn when the front wheels are turned.
NO, it does not take 4-5 seconds for the rear wheels to initiate the slight turn.
The shop manual's procedure for testing the AWS is to lift all 4 wheels off the ground, get the car up to 50-55mph with the wheels spinning in the air and then have someone turn the steering wheel. You should see the slight change in angle of the rear wheels. (I still wonder about this one. The idea of having my wheels spinning at 55 mph on jackstands...).
BTW, there were some Japanese cars that had opposite phase AWS where the rear wheels steered in the opposite direction the front wheels were turned. Nissan's Skyline GT-R's (where it was called HICAS and later, Super-Hicas) were probably he most well-known of these. Some 300ZX's also had this. There were also some Preludes that had a similar feature for a short run.
Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
bluemax_1 is offline   Reply With Quote
