Old 04-22-2008, 10:18 PM   #11 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g is an unknown quantity at this point
Default Re: All Whel Steering model years?
i dont think my 92 stealth tt has it. im not really sure how to tell tho because there really isnt a difference.
1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, Southbend Stage 4 DXD-B Clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, y-pipe, borla catback, ATR downpipe, highflow cat, Lowered, Nitto tires.
In the future: intercooler hard pipes, hopefully close to 500 horsepower after a good tune.
When im rich: A second gen TD-05 VR4 monster.
92stealth15g is offline   Reply With Quote
Old 05-01-2008, 12:37 PM   #12 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Blue94VR4 is an unknown quantity at this point
I think none of the Stealth have it. Neither ECS. That's why it was cheaper.
Speaking of which, do anyone have a link for a AWS delete? I think I want to take mine out.
BTW, it's easy to tell if you have AWS or not. Does your car have rear steering rack? You cannot miss it, it's big
Blue94VR4 is offline   Reply With Quote
Old 05-01-2008, 01:17 PM   #13 (permalink)
Apache's Avatar
Drives: '97 3000GT VR-4
Apache is an unknown quantity at this point
3000GT VR-4s have had AWS steering since day one. All of them.
The Stealth R/T Twin Turbos also had it up until late '95 and '96 models which had it removed.
Any pre-95 Stealth TT and all VR-4s have AWS unless it has been removed by one of the owners.
R/T Twin Turbos have also always had ECS since day one just like the VR-4s. Up until '96 anyway.
The '99 VR-4s have AWS but it is a slightly different setup according to CAPS than the previous years. Don't really know what the difference is though.
*edit*: For the guy looking for a link to a 2WS conversion here ya go.
Removing 4WS from my 92
Apache is offline   Reply With Quote
Old 05-01-2008, 01:19 PM   #14 (permalink)
|RLII Photography|
VR4Rob's Avatar
Drives: 94 VR-4 - 04 Silv.SS
Trader Rating: (13)
VR4Rob Level 1VR4Rob Level 1
Holy misinformation...
All VR-4s had AWS. 91-94 Stealth TTs had AWS. 95-96 Stealth TTs did not.
The easiest way to tell is by chassis code. Z16 cars have AWS, Z15 cars do not.
2004 Onyx Black Chevrolet Silverado SS - 6.0L V8 AWD
1994 Mariana Blue Pearl Mitsubishi 3000GT VR-4
Feb. 2006 3SI ROTM - Best AWD BRG 2007 - 3rd Place 2G 2007 3/S National Gathering
(Hers) 1992 Panama Green Pearl Mitsubishi 3000GT VR-4
www.VR4Rob.com - RLII PaintWorks - RLII Photography
VR4Rob is offline   Reply With Quote
Old 05-29-2008, 09:13 PM   #15 (permalink)
Now a VR-4 driver
boardFreak5's Avatar
Drives: 94 VR-4, 93 fwdtt.
boardFreak5 is an unknown quantity at this point
actually there is a noticeable difference. when going over 70 mph. Its actually pretty cool how it works, makes everything very smooth.
Gewalt evoII's
boardFreak5 is offline   Reply With Quote
Old 05-30-2008, 07:24 AM   #16 (permalink)
phantomrt's Avatar
Drives: fast
phantomrt is an unknown quantity at this point
I never driven a non AWS turn turbo 3/s, but when you're doing 90+ mph down the interstate and hop over four lanes at once, its really a pleasant experience. The service manual states 1.5 degrees maximum turning. At 50-60 mph, 1.5 degrees isn't enough to do squat, but once you get to 120+, you will feel the difference.
My '92 TT Stealth DOES have ECS AND AWS. They do come with it.
92 Stealth R/T TT 70k
92 Daytona ES 2.5 Turbo / A523 103k
92 Lebaron GTC Conv. 2.5 Turbo / A568 153k
91 Daytona ES 3.0 V-6 / A543 190k
95 Grand Prix SE 3.1 / 4T60E 202k
phantomrt is offline   Reply With Quote
Old 05-31-2008, 05:35 PM   #17 (permalink)
In Training
etecnifibre's Avatar
Drives: 1995 Stealth R/T TT
Trader Rating: (57)
etecnifibre Level 2etecnifibre Level 2etecnifibre Level 2
Yeah I'm not sure which Stealths didn't have it. I know that 96 stealths do not have it, and I also know some or all 95 stealths also don't have it. However, I know that Mellon's stealth (a 91 or 92) also did not have it ... but most do. So, I have no idea about that.
I have a build date of Jan 1995, my car is a Z15. Of course, my car my be the exception, since it's ungodly.
On point one, read above.
On point two, as VR-4 Rob said, holy misinformation. Mine doesn't have digital climate control either.
K/N FIPK ll 3SX Downpipe ll Joe P. MBC ll Vac. Redux ll Precat Elims ll NGK 8MM Plug Wires ll Evo 8 BOV ll Test Pipe ll 99 Lifters ll FP Hotwire ll Bilstein Struts ll H&R Springs ll Blitz Turbo Timer w/boost gauge ll SS brake lines ll '99 Headlights and Turns ll Hybrid Datalogger ll 3SX 2" Core Radiator ll ACPT 1pc CFDS ll F/R Solid Mounts ll Side Poly Mounts
Stealth owners....Get vinyl lettering for your calipers!
etecnifibre is offline   Reply With Quote
Old 05-31-2008, 06:02 PM   #18 (permalink)
DC 95VR-4's Avatar
Drives: 99 VR4
DC 95VR-4 is an unknown quantity at this point
If you hold a tight turn at high speed it will activate after a few seconds. It has to be a hard turn where you are moving the steering wheel 1/4 turn sideways or more before you will feel it.
Mine scared the shit out of me yesterday when I took an off ramp too fast. The rear was right on the limit of kicking out when the AWS activated and I crabbed around the turn. Cool but really strange feeling. Without it I would have been sliding.
DC 95VR-4 is offline   Reply With Quote
Old 06-07-2008, 05:53 PM   #19 (permalink)
Drives: 1997 red vr4
VR4Exige is an unknown quantity at this point
jw, but is the aws suppose to activate, but in the opposite direction, when going at low speed to help with parking? my friend told me it is suppose to but the 97 vr4 i have isnt doing so.
VR4Exige is offline   Reply With Quote
Old 06-07-2008, 06:00 PM   #20 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (76)
Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7
It doesnt work at low speed.
