Old 10-01-2009, 09:38 PM   #1 (permalink)
Paid Member
bilz12's Avatar
Drives: 1994 GTO
bilz12 is an unknown quantity at this point
Red face 6speed tranny GTO
hey guys i have an issue with my tranny, its not going into reverse and as far as i know it wont go in 5th or 6th either and 2nd to 3rd grind a bit going into gears, its parked in my driveway becausei have a steed downhill driveway i cant get it out without towing it out i just need your thoughts on it i`m thinking its the shift cables stretched but im open to any thoughts i need it fixed asap
thanks
bilz12 is offline   Reply With Quote
Old 10-13-2009, 10:33 PM   #2 (permalink)
pearlwitestealth is an unknown quantity at this point
Default Re: 6speed tranny GTO
i had the same problem with my stealth with 5sp. wouldnt go into 5th and revearse. i just had to change the trans. but best luck withya in finding this out!
pearlwitestealth is offline   Reply With Quote
Old 10-14-2009, 01:59 AM   #3 (permalink)
Paid Member
bilz12's Avatar
Drives: 1994 GTO
well i should have edited this... it goes into 5th and 6th fine now shifting from 3rd to second grinds unless i jam it in to 2nd really fast.. reverse is like a 50/50 chance it will actually get in gear and not grind... i have no idea what to do..
Old 10-14-2009, 07:05 AM   #4 (permalink)
I'm a Member
Drives: 1996 geteoh
MichaelMR2 is an unknown quantity at this point
change fluid, make sure the shifter is aligned correctly (sitting central etc)
FMIC is CRAP, CRAP IS CRAP, Jeff Lucius/1UZ-FE/VQ35HR Rocks, Privvy?
MichaelMR2 is offline   Reply With Quote
