#3 (permalink) |
Here for the tuna.
You will need a 6speed transmission, second gen transfer case, 6 speed driveshaft, and second gen rear diff.
If you find a JDM 6spd, or a 6spd with JDM ring & pinion gears, you will use your 5speed rear diff but still need the 6speed TC & DS.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts p.s. buy my stuff ![]() |
#6 (permalink) |
Well lol
I shift quick and like to take curves quick. lol Itll be a daily driver with quarter mile racing every 2 weeks. I heard that the 5 speed is better because the gears are longer. But i would like to know the top speed on a 5 speed and 6 speed. |
#7 (permalink) | |
Here for the tuna.
Stealth 316 - Gear Ratios Top speed of 5 speed is a hair over 200, top speed of a 6 speed is around 240 I believe. |
#8 (permalink) |
Staying in the Family
Top speed of either is limited by horsepower not gearing, unless you are running a dr800 or Evo 3 and up, you won't be seeing the end of your 5 speed gears. On very fast cars going to a 5 spd can save them a shift netting a slightly faster 1/4 mile time, the six speed cruises at a lower rpm on the highway.
The sixspeed t case is stonger due to its iron case vs the aluminum case of the 5 speed but the bellhousing is weaker and needs reinforced. If you are just driving the car like everyone else there is no reason to move to a six speed, especially if your 92 has a 25 spline tranny. If it has an 18, I would throw a 300m output shaft in it and call it a day. What is the car? Stock? Modded?
![]() 95 RT/TT Stock 92 VR4 Blacked out with a 98 conversion dr900's Stage 3 Heads 98 Jeep TJ 35's Locked with all the toys Cheap, Fast, Reliable.... You can only have two |
#9 (permalink) |
Its gonna be stock for break-in and them im gonna put bolt ons on till next year where i will be putting on the same turbo that my buddy put on his GSX that made 600AWHP at 18psi
Of course i will go twin lol I have a 18 spline by the way |
#10 (permalink) |
"bakin" with a k
I have a 92, and a 94, and have raced both (with bpu upgrades) and found that the difference between 5/6spd for dragging is all about what power your putting out. For instance with my 94, i found i had to shift into 4th close to the finish line at around 100+ mph, but with my 92 5spd i could power threw 3rd and hit the "red-line" at finish line around 110 MPH
But as said above definitely get rid of the 18 spline i went threw a few of those just with minor mods I'm now into more of the "modded" category, and both my cars are about equal in HP. so im looking forward to seeing what the difference will be between the 5/6 speed now i fear i will have to get out of third just shy of the finish line with my 5 speed
1992 VR4- Forged, board, and more.......d
(3.1L w/crowers & ross's, A115's and all the goods )1994 VR4- My Alcoholic (TEC15's w/ alc injection,) 1993 MX6- Daily driver (speed dent modified) 1987 CJ7- Rock Crawler Screw the one name cars its all about the letters and numbers ![]() |
