Old 05-02-2008, 05:31 PM   #1 (permalink)
Drives: 3000gt VR4
Trader Rating: (16)
Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7
Default 6spd reverse, 1st, and 2nd gone
Just happened out of the blue, the transmission has been smooth and never had any problems. I got home today and was going to back into my parking space, and reverse wouldn't go. So I tried to shift into 1st and it goes straight into 3rd, no grinding, its just that 1st, 2nd, and reverse are not accessible. The only thing I here is a slight whine coming from the transmission when the cluth is not pressed. Any ideas?
Edit#1 O.k. let the car cool off and had some dinner before I got pissed at it, went out played with the gears, found reverse, but the throw is extra long it seems. Also no matter where you try to shift, the gear lever returns the the center position, whether you push it forward or backwards, it just returns to center. Its almost as if you have to manually hold the shifter in place for it to engage a gear otherwise it just returns to the center. I'll be able tear into it some more tomorrow when I have some day light.
1998 VR4: SS Downpipe, Borla Cat-Back, Open Element Air Filter, ACPT CFDS, DN Intake Pipes, Front & Rear Strut Tower Bars, Deftracing 575 Hood, Blitz DSBC, Vacum Redution, Krank Vents, KOYO Aluminum Radiator
Patryn is offline   Reply With Quote
Old 05-02-2008, 08:37 PM   #2 (permalink)
jackstransmissions.com
JackM is an unknown quantity at this point
Default Re: 6spd reverse, 1st, and 2nd gone
I would check all of the cable brackets and connections at the top of the trans. Sounds like something came loose under there. If that is not it, you might have an intermediate shaft bearing failure...
Jack
www.jackstransmissions.com EVO VIII, DSM, 3S tranny rebuilding.
JackM is offline   Reply With Quote
Old 05-02-2008, 08:44 PM   #3 (permalink)
Drives: 3000gt VR4
Trader Rating: (16)
Will do I gave it a cursory look and noticed just odd movement in the shifer assembly, but it was getting dark. Hopefully, it is something simple in the shifter cables. The transmission has been wonderful only 80K on it. No grinding and always strong.
Old 05-02-2008, 09:03 PM   #4 (permalink)
phantomrt's Avatar
Drives: fast
phantomrt is an unknown quantity at this point
Jack
^^^what he said.
92 Stealth R/T TT 70k
92 Daytona ES 2.5 Turbo / A523 103k
92 Lebaron GTC Conv. 2.5 Turbo / A568 153k
91 Daytona ES 3.0 V-6 / A543 190k
95 Grand Prix SE 3.1 / 4T60E 202k
phantomrt is offline   Reply With Quote
Old 05-03-2008, 07:52 AM   #5 (permalink)
Drives: 3000gt VR4
Trader Rating: (16)
O.k. turned out to be something rather simple. I started checking the shifter cables and when I came to the lower bracket that the shifter cable connects to it was missing a part. By that there is a plastic rectangular piece that fits on on a pin from the bracket. Apparently it had fallen off. Luckily I had another around, put it on an problem solved.
