6G74 Magna AWD - Manual Conversion - 3000GT/Stealth International Message Center
Old 09-30-2008, 03:13 AM   #1 (permalink)
MGNTZD is an unknown quantity at this point
Feedback Score: 0 reviews
Default 6G74 Magna AWD - Manual Conversion
Hey guys,
I currently own a 2003 Mitsubishi Magna AWD. They have the 6G74 engine in them, with drivetrain parts from the Evo 6 and 7. More Specifically:
- Front diff - open unit from the Evo 6 RS/Evo 7
- Centre diff - viscous coupling unit from the Evo 6
- Rear diff - LSD from the Evo 6 RS/Evo 7
Now for some reason, Mitsubishi Australia decided to only to produce the AWD version in automatic, so I want to convert it to manual to release some more potential.
I was hoping someone on here has already done something like this, as you have an AWD drivetrain and have perhaps done a 6G74 swap or something along those lines...
There have been a few people from Australia who are in the process of doing this conversion, however they keep running into problems. They have been trying to use an Evo 7 gearbox, but have issues with the diff ratio in the gearbox and the shape of the bell housing. Hopefully they will get this working, but it will require quite a bit of customisation.
An easier answer for me would be to find a manual 5 or 6 speed gearbox from a suitable JDM model mitsubishi. So does anyone have any recommendations as to which gearbox would be suitable for me to use??
- Sam
MGNTZD is offline   Reply With Quote
Old 09-30-2008, 04:20 AM   #2 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Drives: Mrs. Officer
Ondontii Level 1Ondontii Level 1
Default Re: 6G74 Magna AWD - Manual Conversion
Is your transmission on the drivers side or the passenger side?
We really have no such car here. I wish though.
Change the rear dif gear if that is a problem.
Seems that only the bellhousing would be a problem with the swap.
Brent - Great Depression Racing
1992 Duster 11.54@125 22psi BONE Stock 6g72 12 valve - -516whp 519ft/lb 20psi (Old 3.13L built shortblock) - Precision 6765
Now, Stock 10:1 diamante 12 valve shortblock with regapped rings. Stock heads/cams. Waiting.
1994 Spirit - 13.85@108.8 - SOHC - 10psi - Holset He341 & chrome rings.
1981 Starlet KP61
http://www.youtube.com/watch?v=AXF2c...saCIg4HZ3MmpVw
Ondontii is offline   Reply With Quote
Old 09-30-2008, 05:55 AM   #3 (permalink)
I'm a Member
Drives: GTO 1996
MichaelMR2 is an unknown quantity at this point
Feedback Score: 6 reviews
Magna is a Diamente for those not from australia...pretty similar to some of the US DSM community I think
Edit: and my apologies for the influx of Aussie's touting magna's (which are a great aussie whale mobile..yes..WORSE than the GTO is already )
Another Day Another Dollar
MichaelMR2 is offline   Reply With Quote
Old 09-30-2008, 07:54 AM   #4 (permalink)
Drives: 1990 GTO
aussie_will is an unknown quantity at this point
Feedback Score: 5 reviews
Well I couldn't resist chiming in here...
I've got a soft spot for Magna's - I had a TR and was seriously considering buying a supercharged TJ VRX or one of the AWD models. I bought a GTO instead.
I'm guessing that the transmission in the AWD Magnas are on the passenger side (of a RHD vehicle). Making it impossible to bolt up say a 6-speed getrag tranny. For the same reasons why those of us thinking of a 6G74 upgrade need to find one out of a Pajero instead of a Jspec Diamante.
Another option might be something out of the newer model Galant/Legnum VR4s or possibly the Eclipse.
aussie_will is offline   Reply With Quote
Old 09-30-2008, 08:34 PM   #5 (permalink)
Thanks for that! This might be a stupid question, but what exactly is the issue with taking a transmission from a motor which has it located on the opposite of the engine?
Old 09-30-2008, 08:38 PM   #6 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 2RealMcCoy Level 2RealMcCoy Level 2RealMcCoy Level 2RealMcCoy Level 2
Feedback Score: 35 reviews
nothing... If you like five or six reverse gears, and one very low forward....
Because One broken Stealth just wasn't enough... I made twins..
RealMcCoy is offline   Reply With Quote
Old 09-30-2008, 09:45 PM   #7 (permalink)
Ondontii's Avatar
Yeah, cant do it. But I could use any transmission you use because my Dodges have the transmission on the same side
So I would enjoy you finding a solution.
Old 09-30-2008, 11:19 PM   #8 (permalink)
haha, ditto!
Old 07-15-2009, 08:43 PM   #9 (permalink)
TUFFTR & JDMBBQ
TUFFTR's Avatar
Drives: Mitusbishi Magna
TUFFTR is an unknown quantity at this point
Feedback Score: 10 reviews
Sammy....I reckon look into getting a custom adpator plate made for an EVO Gearbox.
Although, Your car will be off the road for quite some time if you undertake something like this...
3.5L DOHC 24v
Fuel/Brake/Clutch lines all Stainless Steel.
5sp w/Exedy HD clutch
DR 272 camshafts and 99 lifters
Fidanza Adjustable Cam Gears
70mm throttle body
Custom Mitsubishi 380 intake manifold
Complete 3000GT VR4 brake upgrade (inc twin piston rears)
Full poly front end
Whiteline rear sway bar
Koni front struts, KYB rears.
EVO 6 rear spoiler
Diamante side skirts/Front bar/headlights, Sigma headlight washers/Ralliart Magna MOMO wheel/ GTO headunit.
Soon - Custom Extractors and 3" catback. - Tune - Sexytime with car
Me giving it the beans :P
http://www.youtube.com/watch?v=qJ6Qnhsn1eI
TUFFTR is offline   Reply With Quote
