Old 03-19-2006, 01:39 PM   #51 (permalink)
Mellon's Avatar
Drives: 91 TT Stealth 05 EVO
Trader Rating: (18)
Mellon Level 4Mellon Level 4Mellon Level 4Mellon Level 4Mellon Level 4
Default Re: 6-Speed Bellhousing beef-up plate installed (pics)
you run meth and c16? what benefit does meth give you on top of what c16 can do when mixed together? is it just to lower the IDC's?
- Chris
05 EVO and 91 Stealth R/T TT
**video**
Upload your 3/S videos here http://3svideo.vidiac.com and post www.racevideoforums.com
Intake: E16G turbos, DR Stage III heads, DR Race cams, Unorthodox Cam gears, Stock MAS, 6" K&N air filter, HKS SSBOV, Vacuum Reduction, custom 2.5" intake pipes and Dejon FMIC
Ignition: MSD 8.5mm spark plug wires, NGK non-resistor non-projected R5671A-8 gapped at .026, HKS Twin Power DLI
Electronics: Greddy Turbo Timer, Greddy E-Manage Blue, Greddy Profec E-01, MMCD and Palm, LM-1 Wideband + RPM Converter
Fuel: Blitz 720cc injectors, Denso 310lph fuel pump, Fuel pump Hotwire , relay bypass, IPO SX Fuel Pressure Regulator and Kenne Bell Boost-a-pump
Exhaust: Titan TD05 Headers and 02 housings, EGR Blockoff Plates, ATR downpipe, Twin Borla mufflers
Driveline: RPS MAX 6-Puck Clutch and RPS Flywheel, 17" Enkei RPF1 (16lbs each), Nitto 555 Extreme, TEIN S-Tech springs and KYB GR2 Struts
Other: Unorthodox Underdrive Pulley, Krankvents
Mellon is offline   Reply With Quote
Old 03-19-2006, 02:11 PM   #52 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (13)
Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7
Yep. I may not need the octane but its still a chemical intercooler and an EGT reducer.
96 Dodge Stealth R/T TT w/58k
10.396 @ 138.94 (C16+Meth)
10.898 @ 130.00 (91+Meth)
05 Mercedes Benz C230 6-Speed Sedan
06 Dodge Magnum SRT-8
Trevor is offline   Reply With Quote
Old 03-19-2006, 02:39 PM   #53 (permalink)
Mellon's Avatar
Trader Rating: (18)
any negative side effects from mixing the two?
Old 03-19-2006, 04:21 PM   #54 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (13)
None that I've noticed.
Old 03-19-2006, 05:11 PM   #55 (permalink)
king of ghetto
Highboosted's Avatar
Drives: '94 Stealth Turbo
Trader Rating: (28)
Highboosted Level 2Highboosted Level 2Highboosted Level 2
And it cleans the combustion chambers......
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Official member of the "I upgraded everything in my car and now it's slower than stock" club.
Highboosted is offline   Reply With Quote
Old 03-19-2006, 05:24 PM   #56 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (224)
RobBeck Level 3RobBeck Level 3RobBeck Level 3RobBeck Level 3
so is the snow performance one the best one to get? I have considered trying out a setup, just not sure what the ideal one to get is...
RobBeck is offline   Reply With Quote
Old 03-19-2006, 06:35 PM   #57 (permalink)
Mellon's Avatar
Trader Rating: (18)
I'm also in the market for a setup but I'm lost with all of the choices
Old 03-21-2006, 04:27 PM   #58 (permalink)
Panda Master
maTT's Avatar
Drives: with one foot.
Trader Rating: (19)
maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7
Wow! looks great Trevor.
I no longer work for 3SX however I still strongly recommend them for your 3S parts and service needs!
maTT is offline   Reply With Quote
Old 03-23-2006, 03:44 PM   #59 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (13)
I finished the trans install today and drove the car to work. Everything seems to be A-OK!
Tomorrow I've gotta re-torque the new ARP head studs/nuts, wash the car, and pick up some C16 before work. Hopefully I'll make the track on Saturday.
As a side note I picked up the last couple harnesses for my Emanage Ultimate setup. I'll put it on after I'm sure I've maxed out on the MAP ECU and stock timing.
Old 03-24-2006, 07:10 AM   #60 (permalink)
Mellon's Avatar
Trader Rating: (18)
nice, it'll be interesting to see how much you'll pick up with advanced timing
