Old 03-15-2006, 08:26 AM   #31 (permalink)
Drives: 99 VR4
Trader Rating: (88)
SHiVeR-91VR4 is an unknown quantity at this point
Default Re: 6-Speed Bellhousing beef-up plate installed (pics)
Originally Posted by pyun
Trevor, would I have to send them a TOB and the 5 speed TT release fork if I wanted that done to my 5spd AWD tranny just so they know how thick of a plate they can install?
Brian
No, this is on the INSIDE of the bellhousing.
The only thing that I would be concerned about the 5 speeds is gear clearance. I'm not sure if it's the same as the 6 speeds, but it's probably the same.
SHiVeR-91VR4 is offline   Reply With Quote
Old 03-15-2006, 10:28 AM   #32 (permalink)
3SX FTL
Turbo Tension's Avatar
Drives: the smokey behind u
Trader Rating: (8)
Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7
I wasn't aware that the 6-speed trannys had problems inside the bell housing?
1993 "dove gray metallic" Stealth R/T Turbo
Car is FOR SALE - 15k - PM me
6-speed transmission conversion, 2g front brake conversion, AWS delete with SK VR4 radius rod mod(BIG thanks to Joe G.'s website! )Kormex front LSD, Port matched Upper Intake -> Ported and port matched lower intake -> DR stage ]l[ heads, DR650Rs, ARC2 w/ 87mm MAF $ ARM1, Denso 255 hotwired, 720cc inj. fed by a Home made dual feed system for $800 w/ single hotwired intank pump, DR Weldin DSM sidemounts, DNP Y-pipe, 3SX poly motormounts, Vac hose reduction,, Chipped stock ECU -9000rpm rev limiter, Blitz DSBC in stock tape deck, VDO boost gauge, GREDDY EGT gauge, ATR downpipe - Borla catback w/ custom 3" flanges (3" all the way through), RPS flywheel, RPS clutch, Tein S-tech springs, Saner front and rear sway bars, Cusco adj. rear sway bar, 3SX adj. upper control arms, STEDEBANI front poly suspension bushings, 1995 VR4 front brake caliper conversion, Stillen Rotors,SCE extended wheel studs WELDED IN - THANKS SUPERCAR ENGINEERING! in NEW OEM hubs, Porterfield R4S pads, SILKOLENE brake fluid, Pro N1s w/ S03 Potenzas, 17x9 FNCRO1NFC01RN 5Zigens w/ NITTO 555Rs, POR15 on everything and a ton of new stock stuff...
Turbo Tension is offline   Reply With Quote
Old 03-15-2006, 10:31 AM   #33 (permalink)
"The Fisherman"
pyun's Avatar
Drives: around scaring birds
Trader Rating: (74)
pyun is an unknown quantity at this point
Thanks Chris. That makes the photos soooo much easier to understand now I've been confused for the last day looking at these pics
pyun is offline   Reply With Quote
Old 03-15-2006, 12:30 PM   #34 (permalink)
Drives: 99 VR4
Trader Rating: (88)
It's an issue with the material around the intermediate shaft's bearing race not being structurally sound enough to handle the power we're putting down.
The shaft tries to separate itself from the input shaft gears when they mesh together, it's a pushing motion that only increases with torque.
big dumps and repeated launches will cause the bellhousing to crack and spill it's guts.
Old 03-15-2006, 04:19 PM   #35 (permalink)
3SX FTL
Trader Rating: (8)
Holy F'in shit. I'm delighted that I'm going to have to do this mod some time.
Old 03-15-2006, 04:40 PM   #36 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (12)
Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7
When will you have it tested at the track?
Maybe Saturday. The tranny itself is still at my local trans shop getting one new bearing, Supercar Engineering shift forks, and a quick inspection to make sure I didn't miss any damage from the old piece of shift fork bouncing around in there. I looked pretty hard and didn't see any damage besides the front output shaft bearing cage that took a hit. I told the shop I needed the trans back today but I didn't get a call. I'll get ahold of them in the morn and tell them I'm going to miss the NOPI race this weekend if they don't get it back to me tomorrow.
I still have to replace the rear head bolts with ARP studs too...the front head is done though.
96 Dodge Stealth R/T TT w/58k
10.396 @ 138.94 (C16+Meth)
10.898 @ 130.00 (91+Meth)
05 Mercedes Benz C230 6-Speed Sedan
06 Dodge Magnum SRT-8
Trevor is offline   Reply With Quote
Old 03-18-2006, 12:34 AM   #37 (permalink)
I have an ego problem
mitsuman03's Avatar
Drives: TRUE 99 3000GT VR-4
mitsuman03 Level 2mitsuman03 Level 2mitsuman03 Level 2
Ya..6spd's have issues..here is my 3kmile trans.....inside look to further explain what Trever is attempting to prevent....
^ Looking from the inside of the bell housing (notice were the cracks are?)
^ Closer shot of the backside of the bell housing^
^Side shot, cracked up through both sides of the stater housing^
^Complete cut away of the broken parts..
^Center body of the bell housing...cracked all the way across...
Trevor, im hoping this work's out, , however it may still crack along the side's of the welds. Weld's are only as stong as the material you are welding it too..even with the billet reinforcement......Didn't mean to seem like im high jacking your thread, just giving members the idea of were the 6spd crack,..that looks awsome tho.........
True 99 vr-4 modded to all hell... GT-37s-- 3.7L Strokaaaa
mitsuman03 is offline   Reply With Quote
Old 03-18-2006, 06:46 AM   #38 (permalink)
Mellon's Avatar
Drives: 91 TT Stealth 05 EVO
Trader Rating: (18)
Mellon Level 3Mellon Level 3Mellon Level 3Mellon Level 3
that's cool trevor, I hope that does the trick.
- Chris
05 EVO and 91 Stealth R/T TT
**video**
Upload your 3/S videos here http://3svideo.vidiac.com and post www.racevideoforums.com
Intake: E16G turbos, DR Stage III heads, DR Race cams, Unorthodox Cam gears, Stock MAS, 6" K&N air filter, HKS SSBOV, Vacuum Reduction, custom 2.5" intake pipes and Dejon FMIC
Ignition: MSD 8.5mm spark plug wires, NGK non-resistor non-projected R5671A-8 gapped at .026, HKS Twin Power DLI
Electronics: Greddy Turbo Timer, Greddy E-Manage Blue, Greddy Profec E-01, MMCD and Palm, LM-1 Wideband + RPM Converter
Fuel: Blitz 720cc injectors, Denso 310lph fuel pump, Fuel pump Hotwire , relay bypass, IPO SX Fuel Pressure Regulator and Kenne Bell Boost-a-pump
Exhaust: Titan TD05 Headers and 02 housings, EGR Blockoff Plates, ATR downpipe, Twin Borla mufflers
Driveline: RPS MAX 6-Puck Clutch and RPS Flywheel, 17" Enkei RPF1 (16lbs each), Nitto 555 Extreme, TEIN S-Tech springs and KYB GR2 Struts
Other: Unorthodox Underdrive Pulley, Krankvents
Mellon is offline   Reply With Quote
Old 03-18-2006, 07:54 PM   #39 (permalink)
15G's are not big!!!
Drives: 95' Grand Cherokee
gofastman is an unknown quantity at this point
did you decide to get the Kormex LSD?
-David C.
my Jeep WILL HAVE a 408
gofastman is offline   Reply With Quote
Old 03-19-2006, 07:03 AM   #40 (permalink)
Mellon's Avatar
Trader Rating: (18)
not yet, I just started a new job and it wasn't a lateral move so I'm watching my money.
