Old 03-14-2006, 06:42 AM   #21 (permalink)
ray pampena's Avatar
ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7
Default Re: 6-Speed Bellhousing beef-up plate installed (pics)
that is awsome looking man! your gonna be fine now.
ray pampena is offline   Reply With Quote
Old 03-14-2006, 07:11 AM   #22 (permalink)
"The Fisherman"
pyun's Avatar
Drives: around scaring birds
Trader Rating: (75)
pyun is an unknown quantity at this point
kick ass!
pyun is offline   Reply With Quote
Old 03-14-2006, 07:20 AM   #23 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
Originally Posted by pyun
kick ass!
Brian,
we need this I wonder how tough it could be to get any machine shop to duplicate that so we dont have to ship it out.
Sam
wraith is offline   Reply With Quote
Old 03-14-2006, 07:35 AM   #24 (permalink)
"The Fisherman"
pyun's Avatar
Trader Rating: (75)
Originally Posted by wraith
Brian,
Sam
Sam, do you think this would be as crucial for the 5-speed bellhousings?
Old 03-14-2006, 07:36 AM   #25 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (219)
RobBeck is an unknown quantity at this point
Looks kick ass. Lets hope this cures all 6 speed integrity issues. Good thing the gears all clear the plate, though... suprised there is that much room in there.
Sam no point in going elsewhere... just ship it... that price and quality look incredible. Plus most shops dont want to deal with One Offs anyhow...
Rob
RobBeck is offline   Reply With Quote
Old 03-14-2006, 08:13 AM   #26 (permalink)
Drives: 99 VR4
Trader Rating: (88)
SHiVeR-91VR4 is an unknown quantity at this point
Yes, I believe 5 speeds are going to run into this problem as well...ONCE you have a billet t-case.
You probably only start needing mods like this and the LSD and shift forks once you start nearing 600awhp.
If you're a first gen and don't have a billet t-case, the t-case is probably going to go first.
If you're a second gen, this is going to become required once you start getting more power (td05's or bigger) and start trying to get some insane 60 ft's at the track.
If you use your car as a daily driver, I wouldn't recommend it. But for $300, that's a cheap peace of mind.
SHiVeR-91VR4 is offline   Reply With Quote
Old 03-15-2006, 07:12 AM   #27 (permalink)
"The Fisherman"
pyun's Avatar
Trader Rating: (75)
Trevor, would I have to send them a TOB and the 5 speed TT release fork if I wanted that done to my 5spd AWD tranny just so they know how thick of a plate they can install?
Brian
Old 03-15-2006, 07:23 AM   #28 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
I would do it in a heartbeat when I need to take it out to do a clutch, You can never have too much beefiness IMO no matter how much power you run. Besides, if torque is the number which is detrimental to the car, then even the smaller setups making less HP can produce significant torque figures. I see this as a very good mod for any 6 speed which sees alot of abuse. I cant think of a downside to running this 24/7 on a street car?
Sam
Old 03-15-2006, 07:30 AM   #29 (permalink)
3SX FTL
Turbo Tension's Avatar
Drives: the smokey behind u
Trader Rating: (8)
Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7
Originally Posted by Trevor
It had to be done
maybe I missed something but..why?
1993 "dove gray metallic" Stealth R/T Turbo
Car is FOR SALE - 15k - PM me
6-speed transmission conversion, 2g front brake conversion, AWS delete with SK VR4 radius rod mod(BIG thanks to Joe G.'s website! )Kormex front LSD, Port matched Upper Intake -> Ported and port matched lower intake -> DR stage ]l[ heads, DR650Rs, ARC2 w/ 87mm MAF $ ARM1, Denso 255 hotwired, 720cc inj. fed by a Home made dual feed system for $800 w/ single hotwired intank pump, DR Weldin DSM sidemounts, DNP Y-pipe, 3SX poly motormounts, Vac hose reduction,, Chipped stock ECU -9000rpm rev limiter, Blitz DSBC in stock tape deck, VDO boost gauge, GREDDY EGT gauge, ATR downpipe - Borla catback w/ custom 3" flanges (3" all the way through), RPS flywheel, RPS clutch, Tein S-tech springs, Saner front and rear sway bars, Cusco adj. rear sway bar, 3SX adj. upper control arms, STEDEBANI front poly suspension bushings, 1995 VR4 front brake caliper conversion, Stillen Rotors,SCE extended wheel studs WELDED IN - THANKS SUPERCAR ENGINEERING! in NEW OEM hubs, Porterfield R4S pads, SILKOLENE brake fluid, Pro N1s w/ S03 Potenzas, 17x9 FNCRO1NFC01RN 5Zigens w/ NITTO 555Rs, POR15 on everything and a ton of new stock stuff...
Turbo Tension is offline   Reply With Quote
Old 03-15-2006, 07:49 AM   #30 (permalink)
Drives: 99 VR4
Trader Rating: (88)
When will you have it tested at the track?
