Old 05-26-2008, 01:30 PM   #131 (permalink)
July 2003
Drives: '94 VR-4
Trader Rating: (16)
bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7
Default Re: 6-Speed Bellhousing beef-up plate installed (pics)
Originally Posted by reallyxxxxxxloud View Post
So I'm a bit out of my league here but why can you not just change the three gears to straight cut without dogboxing ( I showed a mates boss who makes Dog boxes here in Aus, SCEs box he says for the price its too cheap, Good on you guys ) is there a problem with using syncros and straight cut gears?
It's possible go straight cut synchronized gears if you want to. It's just that most folks who go to the trouble and expense of getting straight cut gears made are doing it to strengthen the tranny and they generally also want the advantages of a dogbox engagement (stronger since you have no synchros to strip, and faster shifting).
Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
bluemax_1 is offline   Reply With Quote
Old 05-27-2008, 03:27 AM   #132 (permalink)
reallyxxxxxxloud's Avatar
Drives: LS400/GTO vr4
reallyxxxxxxloud is an unknown quantity at this point
Ok I'm looking at it from my point... I'm aiming at 500-600AWHP (evo 3 setup) and had thought of going a dog box but being a daily driver (after its done its show circuit) I still want it totally driveable. Not sure how SCEs box would be as a daily used box or how long it would last. Some people hate the sound of straight cut but I love the sound. Also If I only used 1 2 3 straight high way use wouldn't be annoying. So what I'm asking is if I had the gears made up I wouldn't need the plate?
"Video games don't affect kids, I mean if Pacman affected us as kids, we'd all be running around a darkened room, munching pills and listening to repetitive music."
PIONEER-ODR RS-K1/C-100/C-200/RS-P50 X2/RS-P1/RS-M1
DIAMOND-AUDIO HEX 8" X2/HEX SILK DOME TWEETERS X4/D7-401 AMP X2/D7-402 X1/D7-152 AMP X1/D7-104 AMP X1 ETON 4-300/25HEX 4" X4 AUDIO-CONTROL EPIC-160
ECLPISE 10" TITANIUM (SUBSONICS) X2 SW9102
PHOENIX-GOLD 12" CYCLONES (INFRASONICS) X2 DC SERVOS http://www.phoenixgold.com/webfaq/cyclone.htm
FUSION 7 COLOUR L.E.D KITS X4 2 MODIFIED. Intergrated lighting through out install.
1994-MITSUBISHI-GTO-TWIN-TURBO-4WD-4WS-FULLY OPTIONED-SERIOUSLY being MODIFIED
reallyxxxxxxloud is offline   Reply With Quote
Old 05-27-2008, 03:04 PM   #133 (permalink)
July 2003
Drives: '94 VR-4
Trader Rating: (16)
First off, no one currently makes a straight cut 2nd and 3rd so you'ld have to get those made somewhere else.
As far as being daily driveable, a dogbox can be shifted up clutchless so you could say it would make driving even easier. The only caveat is that you'll need to double clutch the downshifts.
Now as to whether you need the bellhousing brace, if you're thinking of spending a few thousand on modding the tranny, why skimp on the $200-$300 to get a bellhousing brace? You could get Ray or PO Machine's brace shipped to Oz and have someone down under weld it on using pics from here as a guide to not overdo the welding. Wouldn't be that expensive. Although the straight cut gears will reduce the sideloading that cracks the bellhousing, it's still a weak point.
Max
Old 05-27-2008, 05:04 PM   #134 (permalink)
We can make it better!
Drives: 1996 GTO
MichaelMR2 Level 1MichaelMR2 Level 1
Originally Posted by bluemax_1 View Post
In theory, yes, straight cut gears would have much less side-loading than the stock helical cut gears, however....
There is only ONE current option for straight cut gears and it's only for 1st gear. This is from SCE and it's still not exactly available yet. It includes a straight cut, longer 1st (similar to 1st in a 1st gen 5-spd TT) and a semi-helical 2nd that is between the new 1st and the stock 3rd. It also includes a faceplate dogbox conversion for 1st through 4th IIRC, and the whole thing will be in the $3-$4k US region, so that vs. $300 for the bellhousing reinforcement...
Of course, if you have an inside line on a tranny builder that will build a dogbox with straight cut gears... I DO happen to know that there is a well-known Aussie company that has built straight cut dogboxes for Evos and WRX's, but no one else has yet done the ground work for a 3/S tranny
Max
Who? RPS?
MichaelMR2 is offline   Reply With Quote
Old 05-27-2008, 07:42 PM   #135 (permalink)
July 2003
Drives: '94 VR-4
Trader Rating: (16)
Originally Posted by MichaelMR2 View Post
Who? RPS?
If that question was regarding the dogbox builder in Oz, the company is called PPG Pfitzner Performance Gearbox
They've got built trannies for Scoobies, Evos, Skyline's and RX-7's but no one has thought it worth the development for a 3/S until SCE (SuperCarEngineering) stepped up.
Max
***BTW, RPS is a US-based clutch company. Were you thinking of the Aussie-based APS? APS = AirPowerSystems = specializing in Forced Induction turbo kits. Don't think they do anything for trannies.
Old 05-27-2008, 07:53 PM   #136 (permalink)
Drives: 1996 GTO
sorry, was thinking of RPW.com.au thanks for the link..migth have a word to them about straight cut 1st & 2nd..
Old 05-28-2008, 02:31 AM   #137 (permalink)
Find out what they will do two sets for - but I'm wanting 3rd as well... We may get a better price...
Old 05-28-2008, 03:06 AM   #138 (permalink)
Drives: 1996 GTO
yeah half tempted for 3rd...but I seem to spend a whole crapload of time in 3rd so I'm not sure I wanna have screamer....of course if your making double the power you could assume (that if you do it well and half a shitload more power down low) that you could leave her in 4th... anyway I'll let you know how chatty they are
Old 06-03-2008, 07:41 PM   #139 (permalink)
Drive it hard
Theo_VR4's Avatar
Trader Rating: (14)
Theo_VR4 is an unknown quantity at this point
Has anybody else had a whirring noise bell housing side after having the plate welded in? Ever since I had mine done I've had a whirring noise idle and driving. I replaced the input shaft bearing and still had it. Bret said sometimes the hole is mishapen from the welding so I ground it down and put the bearing back in, the input shaft fit much better but still makes the noise. Is it most likely still that input shaft bearing? I didn't think it would be any other bell housing side bearings because they shouldn't be moving enough at idle to make so much noise.
It's bell housing side, and not the throw out bearing. I have the tranny out again and just wanted to see if anybody else had experience with this type of noise before I just replace the input shaft bearing again. Since the hole was a little ovaled I guess the bearing could have been damaged and make noise even though the hole is now fixed... or maybe the hole needs a smidge more reshaping.
Red '94 VR4
- DR-800s (Sold DR-500s) - KB Boosted Denso Pump & 720's - Maf-T Pro & LC1 - RPS 6-puck - DSM SMICs - CFDS - Methanol - HKS DLI - NX 50 shot off @ 20psi
[2000 Yamaha yzf-r6] [White '92 Stealth r/t turbo (Sold 12/17/05)] [Bro 1 - Blue '01 Camaro SS] [Bro 2 - Blue '94 RX7]
PM me for tranny rebuilds - Dayton, OH.
Theo_VR4 is offline   Reply With Quote
