#111 (permalink) |
Вanned
john did mine within a week. 300 bucks plus return shipping.
edit: and he did mention that he does heat up the workpiece before welding, to keep the cooling rate (and residual stress/warp) in check.
![]() HOLY COW I'M TOTALLY GOING SO FAST OH FUCK give him the stick DONT GIVE HIM THE STICK. Last edited by i3igpete : 01-22-2008 at 12:32 PM. |
#112 (permalink) | |||
Drive it hard
What's the best way to get the rings out of the bell housing that the bearings ride in? I still have a whirring noise after the plate was welded in so I'm replacing them all.
#113 (permalink) | |
I would recommend against a torch...just be patient with a heat gun...assuming your trans has the same bearing fits I did, it doesn't take much.
1997 Black 3000GT VR4-7 K&N, Accel plug wires, Borla Exhaust, MBC, boost + A/f gauge, GREDDY BOV, S-AFC, rewired fuel pump, SBC clutch, Stainless Dpipe, gutted cats; Awaiting install: 15g's, 450injectors, walbro pump, front mount oil cooler, wideband 02, greddy profec b
#114 (permalink) | |
Corn Its whats for boost
The best way to remove them is with a 3 prong puller and a slide hammer. They pop right out.
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#115 (permalink) |
Mike's Sleeper
Has anyone done this to a 5 speed? Got the money for the trans from 3SX and more to spare for the plate weld if I need it. Probably 600-890awhp range at the wheels. I would think that the 5 will have problems without a plate or something to strengthen it up a little.
#116 (permalink) |
TPW: The Prophet
The 5 speeds aren't know for having problems with the bell housing cracking under high torque applications like the six speeds to the best of my knowledge.
Slightly Modded! --> 1994 Dodge Stealth R/T Twin Turbo <-- Slightly Modded! ![]() 1994 Dodge Stealth R/T Twin Turbo (Slow) My slow car-->13.097sec at 107.73mph<--My slow car 1996 Chevrolet Camaro Z28 Convertible (Even slower) 2001 Jeep Grand Cherokee Limited 4x4 (Don't ask) 2007 Honda CBR600RR (Fast enough) |
#117 (permalink) | |
Mike's Sleeper
"3SX T4 947AWHP 806TQ New TQ Record?" There is actually a problem with it doing to exact same thing. From what I have read, not as often unless you are pushing some serious torque though. I am worried about mine, and would like to know if throwing the plate in it, will help. DR said that they had the plate welded into their 5 speed, and I asked by whom, but no reply yet in the other thread. Just trying to find out if any one has done it other than DR, and if so; what torque made the original 5 questionable, how much, where, and so forth? |
#118 (permalink) |
TPW: The Prophet
I knew DR had some problems but I haven't really kept up with what was going on with it (last time I followed what was going on with their race car was when Matt lost the oil pump and burned up the engine). Anyhow, I'm sure if you want it done that someone will do it.
#119 (permalink) | |
But i heavent tested it yet obviously =)... turbos iam using can handle about 900-1100 (not awhp, they have been dynoed to 600bhp each on other cars)
11,7 sec. with td04HL 16T 7cm2 (on e85)
xx,x sec. with twin Holset HX-35 (still on e85) |
#120 (permalink) |
Mike's Sleeper
Okay, I have to know what turbos you are going to use (PM Me). As far as the 5 speed plate weld, are you having a machine shop do it, a trusted fried, or yourself? Post pics when you are done (timeline).
