Old 02-20-2008, 06:25 AM   #121 (permalink)
coz
Drives: 3000GT
coz is an unknown quantity at this point
Default Re: 6-Speed Bellhousing beef-up plate installed (pics)
Originally Posted by cplschneider View Post
Okay, I have to know what turbos you are going to use (PM Me). As far as the 5 speed plate weld, are you having a machine shop do it, a trusted fried, or yourself? Post pics when you are done (timeline).
I am using a pair of holset hx-35, turbinehousing #12.
I will cut it out of a 6-8mm aluminium plate and try to weld it myself.. if i suck to much on welding aluminium, ill have my friend weld it who works with welding.. (its his TIG i will be using)
11,7 sec. with td04HL 16T 7cm2 (on e85)
xx,x sec. with twin Holset HX-35 (still on e85)
coz is offline   Reply With Quote
Old 02-20-2008, 10:44 AM   #122 (permalink)
N2ostealth's Avatar
Drives: 92 stealth rt/tt
N2ostealth is an unknown quantity at this point
I had this done to my 5 speed.
there is a thread called 5 speed bellhousing plate.
the same guys who did trevors
John Redgate
1910 West Price Rd.
Tucson AZ 85705
1-520-888-4010
5 SPEED bellhousing plate
DR-800 Powered Street Beast
http://www.cardomain.com/ride/2535507
N2ostealth is offline   Reply With Quote
Old 02-20-2008, 03:40 PM   #123 (permalink)
ray pampena's Avatar
ray pampena Level 5ray pampena Level 5ray pampena Level 5ray pampena Level 5ray pampena Level 5ray pampena Level 5
this is the one i did for myself a few years back.. minimal welding keeps things straight and worked awsome.
im also making 5 speed ones like my 6 speed ones.
Pampena Motorsports Bellhousing braces CLEEEAAN INSTALL!
ray pampena is online now   Reply With Quote
Old 03-29-2008, 09:26 AM   #124 (permalink)
xwing's Avatar
Drives: 94 VR4, 01 GMC TDies
xwing Level 1xwing Level 1
P O Machine, John Redgate, just finished doing this Bellhousing Reinforcement for my 94 VR4's transmission yesterday, and is sending it back to Frank at Kormex Transmissions to go onto my tranny rebuild (synchros etc, Supercar Engineering billet shift forks, Supercar/Mark Williams output shaft too. Has the Kormex/LSD unit already).
Thanks to P O Machine, Kormex, and Supercar Engineering as well as all the others making/supporting the 3S, for making our stuff BETTER!
Jack Tertadian
xwing is offline   Reply With Quote
Old 05-23-2008, 06:54 PM   #125 (permalink)
TPW: The Prophet
AlmosN8kd's Avatar
Drives: without wearing much
Trader Rating: (40)
AlmosN8kd is an unknown quantity at this point
Here's some pics of my bell housing which I had beefed up by Ray; this is obviously his newer version/method:
Here's my bell housing next to another bell housing that belongs to Ross (a local member) which has been done up by PO Machine:
I just thought guys would like to see the difference.
AlmosN8kd is offline   Reply With Quote
Old 05-25-2008, 12:09 AM   #126 (permalink)
Ichibahn SLC's Avatar
Drives: 1992 3s
Ichibahn SLC is an unknown quantity at this point
Dang
Your going with some big turbos
I was gonna do the same thing
Thought i was gonna be original but you win lol
Ichibahn SLC is offline   Reply With Quote
Old 05-25-2008, 02:20 AM   #127 (permalink)
We can make it better!
Drives: 1996 GTO
MichaelMR2 is an unknown quantity at this point
anyone care to dump a CAD drawing of the largest beffiest plate for a 6 speed into my email? (michael@humedoors.com.au) I have a friend here that is brilliant with aluminium and would save me a fortune in shipping taxes / other stupid crap that it woudl take to get a part from the US into au...
MichaelMR2 is offline   Reply With Quote
Old 05-26-2008, 01:11 AM   #128 (permalink)
reallyxxxxxxloud's Avatar
Drives: LS400/GTO vr4
reallyxxxxxxloud is an unknown quantity at this point
If we used straight cut gears on 1 2 and 3 (yes can be a little noisy) wouldn't this stop the need for the plate? Isn't the torque load on the gears thats causing the shalfs to move busting the housing? Don't hurt me I'm only little ...
"Video games don't affect kids, I mean if Pacman affected us as kids, we'd all be running around a darkened room, munching pills and listening to repetitive music."
PIONEER-ODR RS-K1/C-100/C-200/RS-P50 X2/RS-P1/RS-M1
DIAMOND-AUDIO HEX 8" X2/HEX SILK DOME TWEETERS X4/D7-401 AMP X2/D7-402 X1/D7-152 AMP X1/D7-104 AMP X1 ETON 4-300/25HEX 4" X4 AUDIO-CONTROL EPIC-160
ECLPISE 10" TITANIUM (SUBSONICS) X2 SW9102
PHOENIX-GOLD 12" CYCLONES (INFRASONICS) X2 DC SERVOS http://www.phoenixgold.com/webfaq/cyclone.htm
FUSION 7 COLOUR L.E.D KITS X4 2 MODIFIED. Intergrated lighting through out install.
1994-MITSUBISHI-GTO-TWIN-TURBO-4WD-4WS-FULLY OPTIONED-SERIOUSLY being MODIFIED
reallyxxxxxxloud is offline   Reply With Quote
Old 05-26-2008, 01:42 AM   #129 (permalink)
July 2003
Drives: '94 VR-4
Trader Rating: (16)
bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7bluemax_1 Level 7
In theory, yes, straight cut gears would have much less side-loading than the stock helical cut gears, however....
There is only ONE current option for straight cut gears and it's only for 1st gear. This is from SCE and it's still not exactly available yet. It includes a straight cut, longer 1st (similar to 1st in a 1st gen 5-spd TT) and a semi-helical 2nd that is between the new 1st and the stock 3rd. It also includes a faceplate dogbox conversion for 1st through 4th IIRC, and the whole thing will be in the $3-$4k US region, so that vs. $300 for the bellhousing reinforcement...
Of course, if you have an inside line on a tranny builder that will build a dogbox with straight cut gears... I DO happen to know that there is a well-known Aussie company that has built straight cut dogboxes for Evos and WRX's, but no one else has yet done the ground work for a 3/S tranny
Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
bluemax_1 is offline   Reply With Quote
Old 05-26-2008, 01:51 AM   #130 (permalink)
So I'm a bit out of my league here but why can you not just change the three gears to straight cut without dogboxing ( I showed a mates boss who makes Dog boxes here in Aus, SCEs box he says for the price its too cheap, Good on you guys ) is there a problem with using syncros and straight cut gears?
