Old 06-11-2008, 06:42 PM   #1 (permalink)
mrappe is an unknown quantity at this point
Default 3 wheel drive ?
I have a 93 VR4 and last weekend I had it up on 4 jack stands with the wheels and tires off. I was trying to rotate the tires and diagnose a sound that seemed to be coming from the back passenger area. I had my son sit in the car with it in 1st gear and push on the accelerator. Three of the wheels were spinning the same amount but the front driver's side wheel was slowly moving and I could stop it with my hand. I know something is not right but not sure what to look at. Any advise would be helpful.
Thank You,
Mike Rappe
mrappe is offline   Reply With Quote
Old 06-11-2008, 07:08 PM   #2 (permalink)
Paid Member
Drives: 92 Sandstone VR4
bert0mac Level 4bert0mac Level 4bert0mac Level 4bert0mac Level 4bert0mac Level 4
Default Re: 3 wheel drive ?
does the car move on its own? i had the exact same issue and it turned out the splines on an axle was stripped
92 sandstone vr4
dr-500 turbos
custom made exhaust
fipk
walbro fuel pump
more to come
bert0mac is online now   Reply With Quote
Old 06-11-2008, 07:34 PM   #3 (permalink)
VR-4 VENEZUELA's Avatar
Drives: black 3000gt VR-4
VR-4 VENEZUELA Negative 4VR-4 VENEZUELA Negative 4
i think is normal... may be because in the front axle of our cars have open diff???????
VR-4 VENEZUELA is offline   Reply With Quote
Old 06-11-2008, 07:37 PM   #4 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
yes its pretty much normal due to the open front diff.
with everything in perfect shape all 4 wheels spin evenly in the air but with the age most oif these cars have i wouldnt be suprised if something is causing just a little drag on that 1 wheel.
my 97 spins all 4 on a lift but my old 91 only spun 3.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
95 montero SR. factory rear locker. 3.5 DOHC
91vr4n00maxima is online now   Reply With Quote
Old 06-12-2008, 08:22 AM   #5 (permalink)
Yes, I can not tell that it moves any different than it always has. Did your's move ?
Old 06-13-2008, 09:25 AM   #6 (permalink)
Breaks all but Xfer case
flyman1981's Avatar
Drives: 08 RAM HEMI, 93 VR-4
Trader Rating: (7)
flyman1981 is an unknown quantity at this point
Normal. There is an open diff in the front. You can try to stop the one front wheel and the other should start turning.
Black 93 VR-4
12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage
11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's
??.?? @ ??? w/ 14b's (26psi)
??.?? @ ??? w/ 14b's (24psi) + NOS (35shot)
Show and Go:
98 rear garnish, EGR block off plates, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, 720cc's, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, 50HP NX Wet Kit, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Prosport gauges, Boomslang harness, Corbeau LG1's, Yogurt's 4" cat-back, dual feed fuel system
flyman1981 is offline   Reply With Quote
