#1 (permalink) |
i know it would seem stupid to go from a 25 to a 18 but on the car im trying to get running i have an extra transmission and tcase that is a 18 spline... wondering it it will bolt up to motor with no problems?
1994 pearl yellow vr-4
Mod List- 8" k&N intake filter, HKS BOV, Blitz SBC iD III Boost Controller, Fuel Pump Hotwire, Autometer Boost Gauge, TorxMax Front Mount w/Hard Piping, EGR block-off, VAC reduction, Cross drilled and Slotted Rotors, Stillen brake pads, Stillen Downpipe, Stage 3 SPEC clutch,, MSD 8.5mm spark plug wires, and NGK spark plugs Future Mods- Already purchased-gtpro 357 turbos, Torque Max manifolds and 02 housings, walbro 255fp, Safc neo, RC 550CC fuel Injectors, Maximal Solid Motor mounts, Maximal Transfer Case Bracket Need to purchase- A datalogger! leaning towards halo... got a hybrid! ![]() |
#2 (permalink) |
Forest Gump
yes...if both are 5 speed
![]() Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops MAXED out, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, 17" chromies, Nitto 555s Drivetrain: RPS Street Max, M.W. 300m O/S Etc: Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. JEDI MASTER SAFC NARROWBAND BASED TUNER, LORD OF THE DANCE ALSO |
#3 (permalink) | |
Regulator...
18 splines are 5 speeds. You must match the rear end and transfer case.
and the linkage... its a pain. Just sell the 5 speed and hurry the 6 speed.
#4 (permalink) | |
never a dull moment
Coop
![]() To many mods to list. |
#6 (permalink) |
its not for my 94' i bought a parts car that is a 93 that has a bad tranny the guy was a friend of mine ... he also picked up a blown motor with tranny and tcase he was going to have kormex rebuild his and use the extra tranny to put more towards the core charge... but im thiking maybe the extra tranny is still good! worth a shot
#7 (permalink) | |
#8 (permalink) |
est. sept, 2000
itll work just fine.
be sure to tell whoever you sell the car to that it has an early 18 spline in it
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs ![]() |
