#2 (permalink) |
rock on, yeah rock on
are you sure you don't already have a 25 spline tcase? some '92's came with them.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53 1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info 2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD. ![]() ![]() ![]() 305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time 13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack) 13.09@105.08 (1.80 60', same conditions as above) Beyond BPU: (meaning upgraded turbos/fuel/etc) before engine rebuild Mods at that time 12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms) 12.41@115.10(ditto) After Rebuild: Current Mods Dyno Tune by IPS 12.8@108 (12.5 psi dropping to ~11 @redline, 2.0 60', pump gas, my tune) |
#4 (permalink) |
never a dull moment
well I wouldnt go buy build date because the build date they gave out was suppost to have 92 as 25 spline but didnt. Best way is to pull your TC and count the splines. Any perticular reason you want to change to 25? You can get upgraded 18 splines that will hold well over 800awhp. Basicly you will need to either get a diff bellhousing or bore yours out. A diff VCU, and another part I cant remember what its called. All that along with your TC. Now you sure you want to go through all that work?
![]() Coop
![]() To many mods to list. |
#5 (permalink) | |
But Ill look into stonger 18 spline sets ups thanks....Now I have a 25 spline TC lying around.Update! I just checked my TC on the car and it looks like it already has the 25 spline. A felow 3s owner told me if the TC has a fluid check level bolt near the center of the case that has the getrag logo then its a 25 spline. Well mine has the bolt. Last edited by boy_genius94 : 12-03-2007 at 11:35 PM. |
#8 (permalink) | |
As far as I know the only way to know for sure is to pull the case.
-Ron
'91 Stealth TT purchased Aug 2004 ![]() |
#9 (permalink) | |
Thank you. I was waiting for someone to answer that question.
