Valve hit a piston... How bad of shape am I in? - Page 3 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 05-16-2003, 01:57 AM   #21 (permalink)
reason for tickets.......
Drives: '92 R/T TT
newfoundglory is an unknown quantity at this point
Feedback Score: 6 reviews
Default
haha. it's fine. is you're a non turbo? Is that why yours are bigger?
'92 dodge stealth r/t twin turbo
o snake-eyes
o hallman mbc
o k&n fipk
o gutted pre-cats
o hks turbo timer type-1
o 3rd Gen Lifters
o autometer boost/afc guages in a dual guage a-pillar pod
newfoundglory is offline   Reply With Quote Quick reply to this message
Old 05-16-2003, 02:00 AM   #22 (permalink)
Eddie N is an unknown quantity at this point
Feedback Score: 3 reviews
Default
yes, non turbo.. by the way, i have been through 2 timing belt mishaps, both times bending valves, and dont have any damage to my pistons... well, none that i can see....
Eddie
Eddie N is offline   Reply With Quote Quick reply to this message
Old 05-17-2003, 09:02 AM   #23 (permalink)
Ninja Performance
Import Power's Avatar
Drives: Vicki Insane
Feedback Score: 224 reviews
Default
Three is literally no chance a valve could actually do damage to the piston other than the small score/scratch marks you can see in that pick (no I am not talking about the valve clearance indentations) you can see the spots where the valve actually made contact. Re use them.
My battle with Multiple Myeloma/Non Curable Blood Cancer
91VR4-3.0L-Stock heads and Cams-835AWHP 747AWTQ Daily Driver 10.31@142mph on street tires
SLTT-10.9 @ 142MPH Stock NA engine and NA heads/Cams
T4 AWD 9.21 @ 154.98 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T2 FWD 10.19 @ 140.31 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T4-159.23 MPH Ran on 6G72 3.1L! (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T4-995AWHP Uncorrected 6G72 3.0L C16 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T2-820FWHP 3.1L 27psi C16 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
Import Power is offline   Reply With Quote Quick reply to this message
Old 05-17-2003, 11:23 AM   #24 (permalink)
Senior Member
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3
Feedback Score: 9 reviews
Default
Eric,
Not knowing the mileage or prior condition of the engine (compression, leakdown, etc.) and assuming it was in reasonable condition you probably can get away with using the pistons. If you had the money, I would suggest a replacement short block. Some of the risks you are taking include a weakened piston, possible pinched top ring land on piston, and scuffed rod bearings. Since you are willing to take that risk. I suggest you get the heads repaired including new valves and valve stem seals. I would then get the top half of the motor together with the new timing belt and do a compression test before you complete the assembly. If you get some abnormal compressions you will have to start over. Good Luck.
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is offline   Reply With Quote Quick reply to this message
Old 05-17-2003, 12:14 PM   #25 (permalink)
Drives: '92 R/T TT
Default
So you don't think that the small score/scratch would make these "hot spots" like people have been saying. That is very reassuring for me, I really am tight on money, and I picked up rebuilt heads today. Thank you ALL for your input!
Old 05-17-2003, 12:51 PM   #26 (permalink)
Default
what did you end up paying? i paid $528, but i needed 16 valves and a few valve springs...
Eddie
Old 05-17-2003, 02:05 PM   #27 (permalink)
Senior Member
defgh1's Avatar
Default
To ensure you do not have any hot spots I would smooth out any dings in the piston with some sandpaper. Be careful to not get any abrasive material in the Cylinder bore.
Old 05-17-2003, 02:18 PM   #28 (permalink)
Drives: '92 R/T TT
Default
They aren't actually "rebuilt". I shouldn't have said that. I paid 125 bucks! YIPEEE! for some good shaped ones off of a friend of mines 3000gt. I had a local engine shop check them out real good and they shaved a layer off of it like people have said to have done.
Thanks again-
Old 05-17-2003, 02:28 PM   #29 (permalink)
Drives: '92 R/T TT
Default
I needed 12 on the front head, not sure about the rear, I never got it checked out at a shop, but on the front head you can SEE the damages. I'm sure all 24 are bent. Hell, the car wouldn't even turn over by hand b/c the valves were so bent...
Old 05-17-2003, 02:51 PM   #30 (permalink)
vr4tek's Avatar
vr4tek is an unknown quantity at this point
Feedback Score: 0 reviews
Default
dude, if your not redoing the hole eng. just put the heads on and forget about it. i did a lot of broken belt jobs and never replaced pistons. no one ever came back. just replace the auto tensioner, idler pulleys, and w- pump. youll be fine.
vr4tek is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
