Old 09-21-2007, 03:54 AM   #1 (permalink)
Drives: 93 3kgt SL
blackrooster808 Negative 1
Default testpipe or hi flow cat
ok guys, i did alot of research on this, but i couldnt find out if the hi flow cat takes away that odor the testpipe gives off.
i know that the testpipe has a bigger hp gain, but is it a noticable difference if yu switch to a hi fllow cat?
thanks in advance to whoever answer my questions
93 3000gt SL:Eibach Ground Controls, Downpipe, high flow cat, Apexi n1 Catback, Bomz intake
blackrooster808 is offline   Reply With Quote
Old 09-21-2007, 08:50 AM   #2 (permalink)
Forum user
raven1231's Avatar
Drives: Singleturbo3k/Z31T
raven1231 Level 1raven1231 Level 1
Default Re: testpipe or hi flow cat
yes there is some difference not a huge one but its definatly there however in my opinion high flows sound better and as for the odor it might diffuse it a little but its all coming out either way just one a sec faster
Built and Tuned By RUSH6432,IPS motorsports and myself.
Currently 384whp@wategate 6.8psi
Weight=2890lbs
Tials are in Dyno pull on the way pushing for 10-13 on pump and 15-18 on meth or race fuel....hell maybe even run both and go for 19-22
raven1231 is offline   Reply With Quote
Old 09-21-2007, 12:26 PM   #3 (permalink)
drew93 is an unknown quantity at this point
if ur na tp usually makes exhaust real raspy but if ur just in for performance tp ftw
drew93 is offline   Reply With Quote
Old 09-23-2007, 09:47 PM   #4 (permalink)
Drives: 93 SL 92 Vr4
93/3kgtsl is an unknown quantity at this point
I have a tp and wish I got the high flow. The power is there, but the sound is horrible.
93/3kgtsl is offline   Reply With Quote
