Old 06-22-2008, 06:34 PM   #1 (permalink)
Black Beast Rebuild 94%
TT4ME's Avatar
Drives: 94 TT, 92 ES, 92 TT
Trader Rating: (10)
TT4ME Level 4TT4ME Level 4TT4ME Level 4TT4ME Level 4TT4ME Level 4
Default Tail light Wiring problems
This is on a '92 TT.
When I got the car, brake lights did not work.. signals did.
Brought it into dealership and they said my car was wired for 3-bulbs and I only have 2??? I know one is a dual-filament and I think the dealership was confused. At the time I was in a rush so they raped me and installed a relay in back to make things work. Signals & brakes function but when you have both on.. the signals blink twice as fast and I'm sick of it. Also, now the hazards do not turn the tails on. So they did a real hack job. I need to make it right.
I NEED A WIRING DIAGRAM FOR REAR LIGHTS. Signals/brake/running/hazard.
I have a test light and experience with auto wiring but need the diagram to see what should be back there.
Thanks
TT4ME is offline   Reply With Quote
Old 06-25-2008, 04:28 PM   #2 (permalink)
TT4ME's Avatar
Trader Rating: (10)
Default Re: Tail light Wiring problems
Anybody have it?
I really need the diagram for the whole rear. There are at least 4 harnesses that are just hanging there...
Old 06-28-2008, 04:59 PM   #3 (permalink)
TT4ME's Avatar
Trader Rating: (10)
Spent a couple hours online today searching through manuals to no avail.
Can somebody point me in the right direction?
Old 06-28-2008, 09:52 PM   #4 (permalink)
Also known as MacGyver
marshallh's Avatar
Drives: 1994 3000GT Base
marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7marshallh Level 7
Not sure if this will help or not but it's what I have.
Click on the yellow bar to see the whole thing.
marshallh is online now   Reply With Quote
Old 06-30-2008, 03:35 PM   #5 (permalink)
TT4ME's Avatar
Trader Rating: (10)
Thanks for the help!
I need more details. Wire color diagrams anybody?
Old 07-08-2008, 06:06 AM   #6 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (12)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
wait. does your car have a 3-socket harness, or a 2-socket harness? r/t's should ALL have 2-socket harnesses. if you have a 3-socket in there, it's either from a 3kgt, or a stealth es/base.
inperfectdarkness is online now   Reply With Quote
Old 07-08-2008, 07:17 AM   #7 (permalink)
TT4ME's Avatar
Trader Rating: (10)
I have 2 bulbs for each light. There appears to be 4 wires running to each side.
Old 07-08-2008, 08:19 AM   #8 (permalink)
Trader Rating: (12)
that's messed up. each side should have 5 wires, 2 light sockets (3 to the big, 2 to the small). that's just the tail/turn.
Old 07-08-2008, 05:23 PM   #9 (permalink)
TT4ME's Avatar
Trader Rating: (10)
Do you know what wire is supposed to go where? Colors etc? I want to know if I'm better off getting a whole new harness from somewhere or piece this one together so it works....
Old 07-08-2008, 05:40 PM   #10 (permalink)
Trader Rating: (12)
the (r/t) harness i hold in my hand has 3 wires at the connector. one green w/ white stripe; one black; one green.
the solid green wire runs to the back of the large bulb.
the white-striped green wire splits in two, and runs to the back of both the large and small bulbs.
the black wire splits, and runs to the back of the small bulb...and the side terminal on the large bulb.
the 3KGT harness i have here has:
-4 wires at the connector: black, yellow, green, green w/ white stripe.
in order from the connector we'll call these three sockets 1,2&3.
-socket 1 has green stripe, yellow (center) and black (side)
-socket 2 has green stripe, green (center) and black (side)
-socket 3 has green stripe, green (center) and black (side)
hope this helps. if you count 4 wires at the connector--instead of three--then it sounds like someone jury-rigged it to work. you may be better off buying a new harness; unless you're handy with solder, electronics, etc.
i just provided you with the wiring setup you need for the bulbs.
hope this helps!
-thadd.
