Old 08-04-2008, 05:32 AM   #21 (permalink)
e46m3's Avatar
Drives: BMW M3 / Mitshi VR4
e46m3 Level 3e46m3 Level 3e46m3 Level 3e46m3 Level 3
Default Re: Stripped out GTO Project.
Originally Posted by shooter83 View Post
e46m3, might be worth your time to pick up a bag of dry ice and and get rid of the tar based sound deadening, heres a video of me removing mine:
and please check out my thread, i'm short of money at the moment, but do you still have these parts? http://www.3si.org/forum/f5/uk-membe...ng-gto-423927/
Good ldea. Any idea how much it weighed?
Checked ya thread, but it wont let me reply to it so i hop you see my message here.
I have the sun visors and radio, if you wanna make me an offer
'90 GTO Twin Turbo - Currently being turned into a Track Car
Progress: http://www.3si.org/forum/vbgarage.php?do=view&id=42862
Coming this month: Manifolds/Headers/More Carbon Fibre!
'03 BMW ///M3
19' Deep dish wheels. Straight Thru exhaust
PS3: ilovegash - Add me up!
e46m3 is offline   Reply With Quote
Old 08-04-2008, 05:41 AM   #22 (permalink)
e46m3's Avatar
Update.
Wiring is now finished
Moved battery to rear of car.
Fitted non-active areo rear spolier, this thing weighs next to nothing, and looks better, imo!
All interior is now stripped of everything I can and want to take out, bar heater and A/C rad, which is next on list!
Check how the left hand corner of my boot changed below:
1st pic > Car is stock form
2nd pic > removed ariel, exhaust servo, active areo and areil ECU's and unsused wiring
3rd pic > Battery new location. (still need make a bracket up to hold batt)
Old 08-04-2008, 05:44 AM   #23 (permalink)
e46m3's Avatar
4th pic > how I joined battey power cable in engine bay
5th pic > new lighter rear spolier
Old 08-12-2008, 07:59 AM   #24 (permalink)
e46m3's Avatar
My goals of performance have changed. edited my first post
Ok an update
1st Pic > interior is now finished
2nd > maybe not haha!
3rd pic > just waiting to get a/c cooling unit out now and can get dash back in. Then interior stripping will be finished!
Old 08-12-2008, 08:21 AM   #25 (permalink)
e46m3's Avatar
Got the Crusie control out too.
Man this thing is heavy! lol
I managaed to re-use the same throttle cable too. Simply just bend it straight and make up to p clips and your away. see pic below
Pic 4 > Crsuie removed and relays for A/C (that biatch is on my list next to come out!)
Pic 5> Original throttle cbale used (bent straight and using home made clips)
The pedal feel is no great, so much better.. The clips work really well and hold the cable in tight. Also took opportunity to re-oil the cable
Pic 6> Engine bay sloooowly starting look better.
I think after I remove A/C (with is next) I will polish the valve cover. Just to pretty it up a bit!
So far eveything is running smoothly. touches wood haha!!
Old 08-12-2008, 09:12 AM   #26 (permalink)
Вanned
i3igpete's Avatar
Drives: GoPigGo v2.0
Trader Rating: (80)
i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7
you're much braver than I was. Too scared to start cutting wires away so I ended up with 4-5 bundled bunches of unused connectors.
HOLY COW I'M TOTALLY GOING SO FAST OH FUCK
give him the stick DONT GIVE HIM THE STICK.
i3igpete is online now   Reply With Quote
Old 08-12-2008, 09:28 AM   #27 (permalink)
e46m3's Avatar
lol its not too bad really! Just takes a long time to check, double check and triple check you are removing the right wires!
4 bags of unsed wiring so far, weighs quite a bit too.
had a scary moment though, when car wouldnt start! forgot to plug turbo timber back in (wont start without it plugged in!)
Old 08-12-2008, 10:15 AM   #28 (permalink)
Вanned
i3igpete's Avatar
Trader Rating: (80)
do you have any pictures of the bags of wire? maybe if i can see the scope of how much there is to remove, i'll have extra incentive to having a clean wiring job.
edit: did you use a relay to bypass the etacs? did you also remove some wires running to the fusebox as well?
Old 08-13-2008, 02:52 AM   #29 (permalink)
e46m3's Avatar
yeah, il take a pic on my next update. Bare in mind i still got ABS and ECS to take out gonna be lot more wirign too.
I didn't try to bypass the etacs in the end. I want to, and still may. But i stil don't know 100% of eveything it does or controls, so would need to find that stuff out. anyone know or where you can get info from?
I didnt remove the wires from the fuse box, a lot of the stuff i took out used a shared fuse and i woulda ponly been removing 3 fuses or so, and to take the fuse box apart and trace wires etc i thought was too much effort to get like couple grams of wire out.
I left in the ECS and ABS. But now ABS light is on (read up prob coz batt been disconnected for a while), so I might just pull the ABS. And might get coilovers now, so ECS be pointless. SO maybe the wiring aint finished just yet lol.
little update>
decided to polish the valve cover as it was annoying me how tacky it looked even in my more or less standard engine bay.
Pic 1 > No more of this
Pic 2 > Paint stripper applied
Pic 3 > how it looked after paint stripping. Thought it would come out A LOT better than this oh well!
Old 08-13-2008, 02:55 AM   #30 (permalink)
e46m3's Avatar
pic 4 > after going over with polisher bit on drill for half hour
So far only spent hour and half on this. And that includes taking it out of engine and waiting 20 mins while i had paint stripper on there.
Still got about another half hour of drill polishing and and hour of sanding and wire wool. Then and hour of polishing it with the right paste and you guys will be amazed of how i got it looking in 4-5 hours! lol
