Old 07-24-2008, 06:47 AM   #11 (permalink)
e46m3's Avatar
Drives: BMW M3 / Mitshi VR4
e46m3 Level 3e46m3 Level 3e46m3 Level 3e46m3 Level 3
Default Re: Stripped out GTO Project.
Good job figuring out what all the wires are for. What did you use to help with that? Do you have a wiring diagram?
Gauges look great.
Rear seatbelts coming out?
Thanks man. I do have a complete service manual and had to refer to that a few times (to work out what relays where for what etc).
The wiring was pretty easy to figure though. I untaped all the harness and say I unplugged the radio, I would just follow all the wires that plugged into the radio and where the wires ended, remove them.
Done that for heater, a/c, cruise, radio, etc etc
yeah, rear seat belts would be out now, but i can't un-do the bolts for them crazy tight!
I will write up a DIY about the gauges, just been so busy removing all this stuff lol.
I have 4 plastic bags full of removed wire, once I get all unused engine wiring out I will measure the lot, I think a few people will be surprised by how heavy it all is lol
e46m3 is offline   Reply With Quote
Old 07-24-2008, 06:50 AM   #12 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (66)
Awesome. Really great stuff - can't wait for the gauge write up and the weight savings summary. Thanks for documenting everything so we can all see it!
I hear ya on the seatbelt bolts. I had to use an enormous breaker bar.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts Nov 2008 ROTM
Old 07-24-2008, 07:57 AM   #13 (permalink)
Вanned
i3igpete's Avatar
Drives: GoPigGo v2.0
Trader Rating: (80)
i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7
Originally Posted by e46m3 View Post
Got the dash out and installed some new dails too.
do you think you could figure out a way to mount the main gauge cluster without the dash? maybe by using only a few select brackets from the dash?
also, did you figure out how to bypass the ETACS unit? i found a way to do it by using a relay, but kept all the wiring because i was afraid i would lose my window control.
HOLY COW I'M TOTALLY GOING SO FAST OH FUCK
give him the stick DONT GIVE HIM THE STICK.
i3igpete is online now   Reply With Quote
Old 07-24-2008, 08:19 AM   #14 (permalink)
e46m3's Avatar
Yeah, well I could def fab a bracket and just use the dials, and no dash, but I wanna keep the dash though lol. It's that too heavy and I don't like the car without the dash in. lol
I was not aware you could bypass the ETCAS unit! How many items does it control? Did you use just one relay to then controll everything?
Thanks
Old 07-24-2008, 08:20 AM   #15 (permalink)
e46m3's Avatar
Thanks man. And I have the write up soon :P
Lol, that will be me on the weekend busting my nuts with a breaker bar lol
Old 07-24-2008, 08:37 AM   #16 (permalink)
Вanned
i3igpete's Avatar
Trader Rating: (80)
Thanks
well the dash i mainly wanted to get rid of because it gets in the way of all the wiring. i like to be able to reach what i want, when i want.
The ETACS you can bypass by grounding one wire. grounding this one wire will enable the doorlocks, windows, and rear defrost simultaneously. the ETACS simply acts as a timer after you have removed the key. I previously tried to leave it always connected, but it drew too much current with the car off (and made the window buttons VERY hot!). If can find the ETACS wiring diagram, I can tell you which one to ground using the ignition relay.
Old 07-24-2008, 10:04 AM   #17 (permalink)
e46m3's Avatar
Fair enough Your car sounds pretty cool, any pics of it anywhere??
Ah ok, I was under the impression the ETACS was a timing module that told any motors or lights how to function themselves , and controlled the wipers, pop-up headlights, etc etc.
So, all it does is allow power to certain items for an amount of time after the user has removed the key?
I am sure it controlled headlights too though, as I could not use my headlights when it was not plugged in?
'90 GTO Twin Turbo - Currently being turned into a Track Car
Progress: http://www.3si.org/forum/vbgarage.php?do=view&id=42862
Coming this month: Manifolds/Headers/More Carbon Fibre!
'03 BMW ///M3
19' Deep dish wheels. Straight Thru exhaust
PS3: ilovegash - Add me up!
Old 07-24-2008, 12:19 PM   #18 (permalink)
Вanned
i3igpete's Avatar
Trader Rating: (80)
right, simply unplugging the ETACS will disable all of those things. as i recall, it only acts as an active timer for the rear defroster. everything else (door light, windows, headlights) should work "reasonably well" with just on/off ignition key control.
Old 07-24-2008, 11:40 PM   #19 (permalink)
Paid Member
shooter83's Avatar
Drives: Z15A Stealth ES!
shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7
i just used the bracket from the dash:
-Evan
My AWD Conversion
^Live in Florida? Join FL3S
clicky clicky
shooter83 is offline   Reply With Quote
Old 07-25-2008, 09:49 AM   #20 (permalink)
Paid Member
shooter83's Avatar
e46m3, might be worth your time to pick up a bag of dry ice and and get rid of the tar based sound deadening, heres a video of me removing mine:
and please check out my thread, i'm short of money at the moment, but do you still have these parts? http://www.3si.org/forum/f5/uk-membe...ng-gto-423927/
