Old 07-04-2008, 02:16 AM   #1 (permalink)
e46m3's Avatar
e46m3 Level 3e46m3 Level 3e46m3 Level 3e46m3 Level 3
Default Stripped out GTO Project.
Hi guys.
I just bought me a '90 twin turbo GTO. Aim is to stirp it out as light as possible (keeping it road legal).
So far on my list I have
Items to be Removed:
Electric Windows………………………………………………………………...1.3 kg
Electric Mirrors…………………………………………………………………….1.3 kg
Cruise Control………………………………...... ….... …………………….1 kg
Rear Wipers………………………………....... ............................1.2 kg
Radio, Speakers and all Associated Wiring..…………………….. 13.6 kg
Antenna and all Associated Wiring………………………………….... 0.8 kg
Cargo Cover………………………………......... ..........................2.2 kg
Spare Tire, Jack, Wheel Chock’s, and Inflator Can……………14.5 kg
Rear Hatch Weight………………………………....... ...................1.3 kg
Rear Tow Hooks………………………………........ ..................... 1.5 kg
PRVR System………………………………....... .......................... 0.5 kg
Center Support Bearing………………………………...……. ...…..... 0.5 kg
Timing Belt Covers………………………………....... ...................1 kg
Fan Shroud………………………………....... .............................1 kg
AIV System………………………………....... ........................ .... 4 kg
Fog Light Air Ducts……………………………..…...... .................. 1 kg
All 4 Strut Actuators ………………………………………….……………... 1 kg
Sound Proofing……………………………………………………………………. 15 kg
Front Carpet w/ Insulation Attached…………………………………. 6.8 kg
Rear Rug and Wooden Spare Cover…………………………………..3.6 kg
ALL Plastic Panels with their Insulation Attached…………….. 10 kg
All Tweed and Carpet Covered Panels………………………………. 4.5 kg
Misc. Insulation………………………………... ........................... 2.2 kg
Rear Pressure Equalizing Vents……………………………….......... 1 kg
All A/C related items …………………………………………………………. 19 kg
Air Bag ……………………………………………………………………………….. 3 kg
EGR System………………………………………………………………………… 2.2 kg
4 wheel steer Remove..........................................….. 17 kg
All wires no longer in use if from items removed…………..… 9 kg
Door Skins………………………………........ ............................. 4 kg
Turbo Deck……………………………………………………………………….. 4.5 kg
Weight saved by lightweight parts:
Seats……………………………..24 kg
Battery…………………………… 1 kg
Cats/pre-cats………………… 7 kg
Fly wheel……................. 3.5 kg
Under drive ……………….... 4 kg
Full SS exhaust ……………. 4 kg
Lightweight racing wheels……4 kg
Fibre Glass Bumpers…………….4kg
Airbox/Induction………….…………....2 kg
Steering Wheel……………………….....2 kg
Anyone think of anything esle? Dont really wanna go down the route of lighter panels etc
anyone here done a stripped out gto??
Perfomance Wise:
TD05 EVOIII Turbos
Supporting Manifolds
680cc injectors
Dual walbro fuel pump
FMIC and hard pipe kit
FPR and uprate fuel lines
Full S/S exhaust / de-cat / pre-cat elim.
Turbo down pipes
K&N Filter
HKS Boost Controller
Apexi SAFC
Meth (if the knock is there)
No doubt I have missed some stuff and will add more
Goal is 600 AWHP.
e46m3 is offline   Reply With Quote
Old 07-04-2008, 02:37 AM   #2 (permalink)
VR-4 broken again.
Malaziel's Avatar
Drives: 1992 3000GT VR-4
Malaziel level 6Malaziel level 6Malaziel level 6Malaziel level 6Malaziel level 6Malaziel level 6
Default Re: Stripped out GTO Project.
A full stainless steel exhaust is definitely going to save you more then 4 kgs. Also the stock rims weigh a shit ton. Change them out if you haven't already. Your list seems pretty complete. What are you going to be using the car for?
"I have no fear of death. It just means dreaming in silence. A dream that lasts for eternity."
Vincent Volaju
Malaziel is offline   Reply With Quote
Old 07-04-2008, 02:59 AM   #3 (permalink)
e46m3's Avatar
I got the car on Sunday, it's 100% stock bar a BOV and Y tube.
Nice to know I can save more than 4kgs on s/s exhaust.
Car is gonna be weekend car, occassional track car.
I don't car how loud or uncomfy it is lol
Wheels are definately on my list.
Currently working from back to front on the car in the stripping process. Then I'll give it a good service, then buy some performance parts!
Old 07-16-2008, 05:28 AM   #4 (permalink)
e46m3's Avatar
Ok started on the project now guys.
Currently removing and stripping out interior and removing any wiring that will not be used.
Full list of stuff to be removed is:
Floor mats
Ariel
Spare Wheel
Boot carpet
Jack
Fog lights
Front/Rear Active Areo
Back Seats
Radio
Exhaust Servo
Rear Wiper & Washer Jet
A/C
All Speakers and AMP
Cruise Control
4WS
Parts of Dash
Air Bag
Cig. Lighter
Electric Windows
Central Locking
All un-used Wiring
EGR
Sound Proofing
clutch booster and lines
evap canister
spare tire
jack
ABS
Rear Seat Belts
To be replaced with lighter Parts:
Wheels
Seats
Battery
Steering Wheel
Crank Pully
Single exit S/S Exhaust/De-cat/Pre-cat
Drill out / cheese greater any hidden non structual brackets
If anyone can think of any other items, please let me know. I know I have prob missed a lot.
Enigne work will be:
Engine:
Service
FMIC and suppourting pipe work
Full s/s exhaust system Pre-cat/De-cat/ straight thru single 3" exit
K&N Filter
Blue Silicon hoses (look pretty lol)
Boost Gague
A/F Gauge
Boost Controller
Logging Cable
2 Stage Rev Limiter
Up-rated Fuel Pump
FRP
550cc Injectors
???? Turbos (DR500/650's?)
Interior
Light weight Seats
Light Weight Steering Wheel
White Dials
Bling Gear knob
Bling Hand brake
Exterior
Front Bumper
Rear Wing
Alloys
Side Skirts
Coilovers
I am aiming for 550bhp , and a weight of around (minus driver) 3,100lbs.
BHP at the crank btw.
Should easily hit 11's in the 1/4 mile.
Edit -
1st pic = day or so after got car
2nd pic = Engine after a cleaning
3rd pic = Started on the wiring. At first it look easy then 10 mins later check out pic 4, doh! lol
Old 07-16-2008, 05:32 AM   #5 (permalink)
e46m3's Avatar
4th pic = wiring nightmare
5th pic = have I biten off more than I can chew
6th pic* = phew its all good again
* = not taken yet because its still a mess lol
Old 07-16-2008, 07:11 AM   #6 (permalink)
''the professor''
i3igpete's Avatar
Drives: GoPigGo v2.0
Trader Rating: (75)
i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7
i wouldn't recommend removing the front half of the carpet (you can go and cut off the portion under the seat, however. mainly because the sheetmetal will be very slippery when your shoes are wet.
also, if you don't mind the noise, you can just let the precats dump straight to the ground. you'll save more weight without the exhaust or downpipe.
you're definitely on the right track to 3100lbs. do you have a sunroof? don't forget to remove that entire assembly and replace with riveted lexan.
Maddog Performance Engineering
we are not mitsubishi trained technicians nor certified getrag rebuilders
i3igpete is online now   Reply With Quote
Old 07-16-2008, 07:35 AM   #7 (permalink)
e46m3's Avatar
I am going to keep the carpet in there, but scrape off all that noise padding underneath. I can imagine it being slippery as ice too when wet, and in London, that will be often :P
Also, I did not think about cutting square out of the carpet where the seats are, i add that to my list. Thanks!
That's not too bad an idea about the precats actually. I know turbos hate back pressure, but would the enigne on the whole lose out on low down power due to no exhaust?
Nope, no sun roof!
Old 07-18-2008, 05:26 AM   #8 (permalink)
e46m3's Avatar
update
back end of car wiring is now done, just need re-tape and install plastic panels back, not too hard really
Old 07-24-2008, 03:43 AM   #9 (permalink)
e46m3's Avatar
Got the dash out and installed some new dails too.
Check pic 3. The blue circle I drew on the pic is the only 3 wires im keeping out of all of that bunch. And those 3 wires might even go anyway (they are for g-shock sensor for ABS, which i prob take out too lol)
Old 07-24-2008, 05:30 AM   #10 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (61)
Good job figuring out what all the wires are for. What did you use to help with that? Do you have a wiring diagram?
Gauges look great.
Rear seatbelts coming out?
2002 WJ -- 1994 VR-4 -- Canon Rebel XTi
Originally Posted by Kenneth Ellis View Post
Every one of you are fools, each and every one.
