#1 (permalink) |
Hi guys.
I just bought me a '90 twin turbo GTO. Aim is to stirp it out as light as possible (keeping it road legal). So far on my list I have Items to be Removed: Electric Windows………………………………………………………………...1.3 kg Electric Mirrors…………………………………………………………………….1.3 kg Cruise Control………………………………...... ….... …………………….1 kg Rear Wipers………………………………....... ............................1.2 kg Radio, Speakers and all Associated Wiring..…………………….. 13.6 kg Antenna and all Associated Wiring………………………………….... 0.8 kg Cargo Cover………………………………......... ..........................2.2 kg Spare Tire, Jack, Wheel Chock’s, and Inflator Can……………14.5 kg Rear Hatch Weight………………………………....... ...................1.3 kg Rear Tow Hooks………………………………........ ..................... 1.5 kg PRVR System………………………………....... .......................... 0.5 kg Center Support Bearing………………………………...……. ...…..... 0.5 kg Timing Belt Covers………………………………....... ...................1 kg Fan Shroud………………………………....... .............................1 kg AIV System………………………………....... ........................ .... 4 kg Fog Light Air Ducts……………………………..…...... .................. 1 kg All 4 Strut Actuators ………………………………………….……………... 1 kg Sound Proofing……………………………………………………………………. 15 kg Front Carpet w/ Insulation Attached…………………………………. 6.8 kg Rear Rug and Wooden Spare Cover…………………………………..3.6 kg ALL Plastic Panels with their Insulation Attached…………….. 10 kg All Tweed and Carpet Covered Panels………………………………. 4.5 kg Misc. Insulation………………………………... ........................... 2.2 kg Rear Pressure Equalizing Vents……………………………….......... 1 kg All A/C related items …………………………………………………………. 19 kg Air Bag ……………………………………………………………………………….. 3 kg EGR System………………………………………………………………………… 2.2 kg 4 wheel steer Remove..........................................….. 17 kg All wires no longer in use if from items removed…………..… 9 kg Door Skins………………………………........ ............................. 4 kg Turbo Deck……………………………………………………………………….. 4.5 kg Weight saved by lightweight parts: Seats……………………………..24 kg Battery…………………………… 1 kg Cats/pre-cats………………… 7 kg Fly wheel……................. 3.5 kg Under drive ……………….... 4 kg Full SS exhaust ……………. 4 kg Lightweight racing wheels……4 kg Fibre Glass Bumpers…………….4kg Airbox/Induction………….…………....2 kg Steering Wheel……………………….....2 kg Anyone think of anything esle? Dont really wanna go down the route of lighter panels etc anyone here done a stripped out gto?? Perfomance Wise: TD05 EVOIII Turbos Supporting Manifolds 680cc injectors Dual walbro fuel pump FMIC and hard pipe kit FPR and uprate fuel lines Full S/S exhaust / de-cat / pre-cat elim. Turbo down pipes K&N Filter HKS Boost Controller Apexi SAFC Meth (if the knock is there) No doubt I have missed some stuff and will add more ![]() Goal is 600 AWHP. Last edited by e46m3 : 08-12-2008 at 07:03 AM. |
#2 (permalink) |
VR-4 broken again.
A full stainless steel exhaust is definitely going to save you more then 4 kgs. Also the stock rims weigh a shit ton. Change them out if you haven't already. Your list seems pretty complete. What are you going to be using the car for?
"I have no fear of death. It just means dreaming in silence. A dream that lasts for eternity."
Vincent Volaju |
#3 (permalink) | |
Nice to know I can save more than 4kgs on s/s exhaust. Car is gonna be weekend car, occassional track car. I don't car how loud or uncomfy it is lol ![]() Wheels are definately on my list. Currently working from back to front on the car in the stripping process. Then I'll give it a good service, then buy some performance parts! |
#4 (permalink) |
Ok started on the project now guys.
Currently removing and stripping out interior and removing any wiring that will not be used. Full list of stuff to be removed is: Floor mats Ariel Spare Wheel Boot carpet Jack Fog lights Front/Rear Active Areo Back Seats Radio Exhaust Servo Rear Wiper & Washer Jet A/C All Speakers and AMP Cruise Control 4WS Parts of Dash Air Bag Cig. Lighter Electric Windows Central Locking All un-used Wiring EGR Sound Proofing clutch booster and lines evap canister spare tire jack ABS Rear Seat Belts To be replaced with lighter Parts: Wheels Seats Battery Steering Wheel Crank Pully Single exit S/S Exhaust/De-cat/Pre-cat Drill out / cheese greater any hidden non structual brackets If anyone can think of any other items, please let me know. I know I have prob missed a lot. Enigne work will be: Engine: Service FMIC and suppourting pipe work Full s/s exhaust system Pre-cat/De-cat/ straight thru single 3" exit K&N Filter Blue Silicon hoses (look pretty lol) Boost Gague A/F Gauge Boost Controller Logging Cable 2 Stage Rev Limiter Up-rated Fuel Pump FRP 550cc Injectors ???? Turbos (DR500/650's?) Interior Light weight Seats Light Weight Steering Wheel White Dials Bling Gear knob Bling Hand brake Exterior Front Bumper Rear Wing Alloys Side Skirts Coilovers I am aiming for 550bhp , and a weight of around (minus driver) 3,100lbs. BHP at the crank btw. Should easily hit 11's in the 1/4 mile. Edit - 1st pic = day or so after got car 2nd pic = Engine after a cleaning 3rd pic = Started on the wiring. At first it look easy then 10 mins later check out pic 4, doh! lol |
#6 (permalink) |
''the professor''
i wouldn't recommend removing the front half of the carpet (you can go and cut off the portion under the seat, however. mainly because the sheetmetal will be very slippery when your shoes are wet.
also, if you don't mind the noise, you can just let the precats dump straight to the ground. you'll save more weight without the exhaust or downpipe. you're definitely on the right track to 3100lbs. do you have a sunroof? don't forget to remove that entire assembly and replace with riveted lexan.
Maddog Performance Engineering
we are not mitsubishi trained technicians nor certified getrag rebuilders ![]() |
#7 (permalink) | |
Also, I did not think about cutting square out of the carpet where the seats are, i add that to my list. Thanks! That's not too bad an idea about the precats actually. I know turbos hate back pressure, but would the enigne on the whole lose out on low down power due to no exhaust? Nope, no sun roof! ![]() |
#9 (permalink) |
Got the dash out and installed some new dails too.
Check pic 3. The blue circle I drew on the pic is the only 3 wires im keeping out of all of that bunch. And those 3 wires might even go anyway (they are for g-shock sensor for ABS, which i prob take out too lol) |
