Old 05-15-2008, 04:01 PM   #21 (permalink)
SmoothGT's Avatar
Drives: 94 3000gt sl
SmoothGT Negative 3
Default Re: robo lights - painting
why did you use sandpaper on all the metal parts?
check out myspace.com/streetchemistrymusic
tell me what you think =)
NEW SONGS ADDED : "Souljaboy Diss" and "Blowin Up" and "Puttin On My Nikes"
SmoothGT is offline   Reply With Quote
Old 05-17-2008, 01:45 PM   #22 (permalink)
Drives: 1994 3000GT SL
tokki g is an unknown quantity at this point
You gotta sand down the metal so that the primer can stick to it, then you add paint which sticks to the primer.
tokki g is offline   Reply With Quote
Old 05-18-2008, 12:25 PM   #23 (permalink)
SmoothGT's Avatar
SmoothGT Negative 3
how much metal is there inside?just those two rings? or more?...
Old 05-18-2008, 12:43 PM   #24 (permalink)
I sanded the bracket (1/each side) and the light bulb housings (2/each). Actually took a loooong time to sand it down by hand, but it was my first time.
