Old 05-11-2008, 12:24 PM   #1 (permalink)
tonyvr4 is an unknown quantity at this point
Default part number for VR-4 door lock relay
I am having a problem with the door locks on my 1997 VR-4 going nuts occasionally and locking/unlocking multiple times.
Does anyone know the part number for the door lock relay ? I looked in CAPS and it showed *NO DATA* or something like that, when I clicked on the item.
Any help is greatly appreciated
Thanks
Tony
tonyvr4 is offline   Reply With Quote
Old 05-11-2008, 12:33 PM   #2 (permalink)
Distinctly_Dave
91red_stealth is an unknown quantity at this point
Default Re: part number for VR-4 door lock relay
Mine was doing this recently. It turned out to be the wires that go into the doors from the body that were grounding out or touching other wires. You might check to be sure its not a similar issue. I know I have this problem on multiple occasions since those wires take so much abuse when the door is opened/closed.
91red_stealth is offline   Reply With Quote
